RK3399 Maskrom Boot Failed
Hello everyone,
I have PX6 RK3399 Android Car Headunit without any psyhical buttons(except RST). I by accident i flashed wrong update.zip(A11 not A10) and my headunit got bricked.
SOM is HCT-RK3399-REV08
I readed a lot of stuff on XDA forum, and found a MASKROM mode, so i tried.
Here is a list of equipment which i used:
  • Laptop with Win11 and USB3.0
  • Laptop with Ubuntu 22.04 and USB3.0
  • Laptop with Win7(x86) and USB2.0 and USB3.0
  • OTG cable with 12k and 15k which i connect to SOM board
  • Male to Male USB cable and connect it to both ports on Headunit
After several tries i already built good cable and get into MASKROM, but i can do nothing there, everytime i got errors on every device which i mentioned above.
Here you have LOG from RKDevtool v2.65, where i tried to “TestDevice” or “Upgrade” a firmware for HCT_Rk3399_8.1.img
|22:48:45 905|Error:RKU_Write-->WriteFile failed,bRet=0,err=995,size=31,write=0|
|22:48:47 912|ERROR:RKU_ResetPipe-->DeviceIoControl failed,err=31|
|22:48:47 912|<LAYER 2-1> ERROR:TestDevice-->RKU_TestDeviceReady failed,RetCode(-3),path=\\?\USB#VID_2207&PID_330C#5&1C80A72C&0&1#{a5dcbf10-6530-11d2-901f-00c04fb951ed}|
|22:48:53 944|Error:RKU_Write-->WriteFile failed,bRet=0,err=995,size=31,write=0|
|22:48:55 948|ERROR:RKU_ResetPipe-->DeviceIoControl failed,err=31|
|22:48:55 948|<LAYER 2-1> ERROR:TestDevice-->RKU_TestDeviceReady failed,RetCode(-3),path=\\?\USB#VID_2207&PID_330C#5&1C80A72C&0&1#{a5dcbf10-6530-11d2-901f-00c04fb951ed}|
|22:49:01 972|Error:RKU_Write-->WriteFile failed,bRet=0,err=995,size=31,write=0|
|22:49:03 984|ERROR:RKU_ResetPipe-->DeviceIoControl failed,err=31|
|22:49:03 984|<LAYER 2-1> ERROR:TestDevice-->RKU_TestDeviceReady failed,RetCode(-3),path=\\?\USB#VID_2207&PID_330C#5&1C80A72C&0&1#{a5dcbf10-6530-11d2-901f-00c04fb951ed}|
|22:50:07 816|Layer<2-1>:Download Boot Start|
|22:50:07 882|<LAYER 2-1> ERROR:Boot_VendorRequest-->DeviceIoControl failed,Total(71682),Sended(0),bRet(0),err(1f)|
|22:50:07 882|<LAYER 2-1> ERROR:DownloadBoot-->Boot_VendorRequest471 failed,index(0)|
|22:50:07 893|Error:Layer<2-1>:Download Boot Fail|
Any suggestions what else can i do ? Im figthing with this around a week, i built over 3 cables and on all have same errors(on all SOM is connecting in maskrom mode after short circut two pins on SOM)
Same problem here. Did you ever figure it out?
