Request for Android image / fix for portrait HDMI + USB touch on ROCK 5B+
Hi Radxa team,
I need help with ROCK 5B+ Android for a portrait kiosk setup.
Hardware setup
  • Board: Radxa ROCK 5B+
  • OS: Official Android image for ROCK 5B+
  • Display: 27-inch HDMI display mounted in portrait
  • Touch: USB touch connected to the board
  • Touch controller detected as:
    • Vendor: 0EEF
    • Product: C000
    • Version: 0111
    • Name: eGalax Inc. eGalaxTouch EXC3189-8014-08.00.00.00
Problem
The display output comes, but portrait mode is not working correctly on this Android image.
What I see:
  • launcher/app icons are not placed correctly
  • navigation buttons are misaligned
  • search bar is also misplaced
  • overall screen composition looks wrong in portrait mode
  • USB touch does not match the UI
  • touch behaves like landscape / swapped / opposite mapping
Important note
The same display and touch hardware works correctly on another RK3588 Android board, so the issue seems specific to the ROCK 5B+ Android image / vendor configuration.
What I already tried
  • display orientation from Android settings
  • ADB rotation commands
  • wm size / wm density
  • HDMI rotation properties
  • IDC file tests for the eGalax touch controller
Still, the issue remains.
Request
Please help with one of these:
  1. a correct Android image for ROCK 5B+ supporting portrait HDMI + USB touch
  2. a patch / config fix for:
    • proper portrait HDMI composition
    • correct touch mapping for eGalax 0EEF:C000:0111
    • correct external display + external touch association
If needed, I can share:
  • photos
  • video
  • ADB outputs
  • full logs
This is for a production Android kiosk, so proper portrait display and touch support are required.
Thanks.
Hi Sazzad,
I own the Rock5t and Rock5c; I just solved the following problem on Android 12 and 14.
Touchscreen Mapping Correction
You need to create an ‘.idc’ file for your touchscreen in the directory path ‘/system/usr/idc’.
File name:
Vendor_xxxx_Product_xxxx.idc
(You must replace the ‘xxxx’ for Vendor and Product with your specific touchscreen data; note that case sensitivity matters—use lowercase for hexadecimal letters.)
For your device:
Vendor_0eef_Product_c000.idc
File content:
device.internal=1
touch.deviceType = touchScreen
touch.orientation = 180 # customize to your Screen
# device.internal = 1 (0= externes Gerät/1 = internes Gerät)
# touch.deviceType = touchScreen
# touch.orientation = 0 (Natural)
# touch.orientation = 90 (Clockwise)
# touch.orientation = 180 (Upside down)
# touch.orientation = 270 (Counterclockwise)
Procedure for transferring to the Rock device:
I established an ADB connection (via USB or network using the connect command):
1.: adb root
The following enables read/write access to the system:
If ADB is already running as root, ‘su’ is not required in the shell command.
2.: adb remount
Alternative command:
adb shell ‘mount -o rw,remount /’
Transfer your IDC config to the Radxa device (Source PC = Windows; please adjust the file path):
3.: adb push D:\FilePath\ADB\idc\Vendor_xxxx_Product_xxxx.idc /system/usr/idc
adb reboot
