Yes, you just need to compile TvSettings on the normal android version.
Yes, No Windows version
So I have to build android with linux PC with the settings inside? No chance to change to 8bit with sdk command over my PC while the rockpi is connected?
Im sorry for all this questions, its just that I’m an absolutly noob. Im learning but, building android system with linux is just to much for my brain right now. ![]()
The instructions are in the readme:
No brain power required.
Are you shure man? ![]()
I mean how to put the settings from anroid tv version in that code before building? I even dont know which code I have to extract.
Thats just one thing from many problems ![]()
You have to know the code to work with it.
I only now 1 percent.
Anyway thanks for your help bro. ![]()
I really want to switch to Linux but one Linux doesn’t seem to be enough because I need Debian AND Ubuntu for the RockPi stuff and an additionally distro for my music production - it makes me sick ![]()
TunerSettings->Display->HDMI->Color
is that can flash on car’s head unit? this line " ${recovery_path}" need to change ?
請問PX6的車用音響主機可以用嗎? recovery_path 是否要改成什麼入徑?
按理来说rk3399平台都可以用,recovery_path是你下载/编译的recovery镜像。
請問 您的意思 是我可以用在 RK3399 chip 上其它 ANDROID 裝置 使用一樣的方法?
我的裝置是NANO PI M4 A , 一直無法得到ANDROID SU授權非常困擾, FriendlyARM 更新速度慢, 我想以後也不會有 ANDROID 鏡像 內建 TWRP/magisk
不知道您提供的方法是否相容
謝謝~
Write the recovery.
adb shell reboot loader
upgrade_tool di -recovery ${recovery_path}
upgrade_tool rd
Reboot to recovery
adb shell reboot recovery
这个我不肯定,不能保证能用,你可以试试,如果不行你重新刷回原来的固件就好。
买个rockpi4吧,Android经常不定期更新:
这个是最新的版本:
好的 我會試試看 謝謝!
到時候再回報能不能開機
ROCK PI ANDROID 確實比較多更新
NANO PI ANDROID 前幾版 bug也是不少 深感困擾
以後會優先考慮 RADXA的產品
光是論壇回應速度就令人讚賞了!
请问可以用在Rock Pi 4C上面吗?
Can I use this on Rock Pi 4C?
Options for 4C feels terrible right now - only android 10(Q) available, and no Root/Magisk support?
I install unofficial “android_9_radxa_zero_twrp_magisk.img” on my radxa zero, and at any reboot or power on, my device goes to twrp menu, only after many reboots goes to system android, also after install this android image my device not boot any image from sdcard.
Can you you help me with a solution ???
Can you make one for the rock 5b android 12?
@Elden No one is going to make one.
