My device did boot once with an SD card burned using default System image for MicroSD card [rk3576_bookworm_kde_512.img.xz], I could play with kde/hdmi/audio/ network … great! But trying to install image to eMMC I probably did something wrong with dd (crashing SPI perhaps) … No way to boot now, light stay green.
What can I do? Is there a way to reset device flashing from USB or TTY?
Radxa eMMC Module, model: VA001-16GB, suggested to buy together with Rock 4D by Arace Tech’s shop, is not supposed to work??
However even removing eMMC Module it is not booting anymore.
Please help…
Thank you for you help @Nasca.
I did follow this guide for “Installing System to MicroSD Card” but can’t boot anymore… I’d love to follow “Flashing SPI Boot Firmware” but the only way documented is to boot an SD card and use RSETUP so I’m stuck
Could you please provide instructions for flashing SPI Boot Firmware another way?
Thanks.
Denis
sudo bash setup.sh maskrom_update_spinor
Building Rockchip RK35 SPI U-Boot…
680+0 records in
680+0 records out
348160 bytes (348 kB, 340 KiB) copied, 0,00815873 s, 42,7 MB/s
3040+0 records in
3040+0 records out
1556480 bytes (1,6 MB, 1,5 MiB) copied, 0,0339956 s, 45,8 MB/s
Starting to erase flash…
Getting flash info from device failed!
Thanks again @Nasca but I can’t boot from the sd card since it doesn’t … light stay green .
Also tried from another PC running Windows. RkDevTool is detecting a maskrom device but no advanced functions works (ReadFlashID, ReadFlashInfo, ReadChipInfo, … fails).
Another idea?
To add also: It is permanently in maskrom mode, no need to push button when powering up, whether I plug a bootable SD Card or not. Referring to documentation could be because SPI is not there…
@Nasca I don’t have any serial cable/connection, only usb. Nothing I can do using a tool via usb? If you confirm I’ll get a usefull serial log I can oder a cable.
Denis
@Nasca Also as you suggested I unplugged the ufs/sd card and other storage device, powered the device and using Tabby thru a serial port (as documented in quick start), got serial port connected but no output…
If there is no serial output without SD card/UFS/eMMC, you need to check if the SPI flash is clean or part of the SPI code already ran and died.
If you the SPI Flash is empty/clean, the ROCK 4D has nothing to run and will go to maskrom mode without pressing the maskrom key. You can check the maskrom mode:
Finally it works!! After first downloading and running the Loader file, I was able to flash the SPI and then boot again from SD. I was probably missing the first step (loader)…
Many thanks for your help @jack.
