Recommended external GPU for o6
What is the recommended external GPU that we can hook up to the PCIe slot on tho o6 system?
Thanks
Right now, from the Nvidia cards everything up to RTX 3000 works and AMD Polaris GPUs.
RTX4000+ are the ones that are having issues. As well as AMD RDNA gpus (altrought a kernel patch is on the way).
I’ve seen people running RTX 4070Ti and RTX 4090 in 6.1 DT BSP kernel. So it should be another mainline driver issue.
I am using amd rx580. it works well
GT1030 runs well without needing additional power.
I managed to get AMD Radeon RX 6700 XT working - details here.
Using a AMD Pro WX 8200 which works pretty darn good, so everything AMD VEGA based should be fine, be aware though to unplug your board completely after shutdown, there is still a Bios bug that will not turn off your GPU and it will cook it self.
