Recently I bought a NVIDIA GeForce RTX 5080 Founders Edition card for my gaming PC and I decided to try it with the Orion O6 before it makes its way to its ultimate destination. I managed to get it working; in fact it works better than the other discrete GPU that I have tried (AMD Radeon RX 6700 XT), which is not surprising given that NVIDIA supports the Arm architecture officially with their own driver and gives the same quality guarantees as with, say, their Windows x64 driver. For instance, I haven’t experienced any lock-ups such as the ones that I reported here, though I get some spam in the kernel log like this:
[ 5.987966] arm-smmu-v3 arm-smmu-v3.0.auto: event 0x10 received:
[ 5.994057] arm-smmu-v3 arm-smmu-v3.0.auto: 0x0000c10000000010
[ 5.994059] arm-smmu-v3 arm-smmu-v3.0.auto: 0x0000020000000000
[ 5.994061] arm-smmu-v3 arm-smmu-v3.0.auto: 0x0000000000000000
[ 5.994062] arm-smmu-v3 arm-smmu-v3.0.auto: 0x0000000000000000
[ 5.994064] arm-smmu-v3 arm-smmu-v3.0.auto: event: F_TRANSLATION client: 0000:c1:00.0 sid: 0xc100 ssid: 0x0 iova: 0x0 ipa: 0x0
[ 5.994067] arm-smmu-v3 arm-smmu-v3.0.auto: unpriv data write s1 "Input address caused fault" stag: 0x0
As before, I am running the firmware in ACPI mode and I am using Ubuntu 25.04 with the Wayland windowing system, but with the stock kernel release 6.14.0-29-generic. The driver is the proprietary one provided by Ubuntu, in particular the open kernel variant, i.e. nvidia-driver-580-open, which corresponds to version 580.65.06. The upstream driver, nouveau, does not work because the revision associated with my kernel does not support the graphics card. Also, I don’t think that the Mesa 3D graphics software stack is able to function with the driver that I am using. I tried various applications such as GravityMark on top of both the OpenGL and the Vulkan APIs (with ray tracing and the various other render options; results here and there), the Raymarching - Primitives demo from the Shadertoy Web site on Mozilla Firefox, llama.cpp with both CUDA and Vulkan, the Geekbench 6.5.0 GPU benchmark (results here), and others; all of them worked fine.
However, the most complicated detail is the firmware version. The latest release as of this writing, 0.3.0-1, does not work - I think that the board was not even being detected as a PCIe device. Instead, I built revision 5834abe860ab7e38acb266a0e87e749d9f0ff016 manually on another machine (x64-based). Unfortunately, the repository seemed to be in a messy state, so some manual fixes were also necessary. First of all, I removed all occurences of $(PACKAGE_TOOL_ARCH) from the src/Makefile file that the commit that I linked to had added before that. Then I changed to the src/edk2-platforms directory, which is actually a submodule, and I fixed the unsuccessful attempt to add support for resizable BAR. As a side note, the symptoms of that issue were errors such as:
[ 8.378753] NVRM: kbusVerifyBar2_GB202: MMUTest BAR0 window offset 0x70e000 returned garbage 0x0
[ 8.378773] NVRM: nvAssertOkFailedNoLog: Assertion failed: Generic memory error [NV_ERR_MEMORY_ERROR] (0x00000072) returned from kbusVerifyBar2_HAL(pGpu, pKernelBus, NULL, NULL, 0, 0) @ kern_bus_gm107.c:360
[ 8.378786] NVRM: nvAssertOkFailedNoLog: Assertion failed: Generic memory error [NV_ERR_MEMORY_ERROR] (0x00000072) returned from kbusStateInitLockedKernel_HAL(pGpu, pKernelBus) @ kern_bus_gm107.c:465
[ 8.378794] NVRM: RmInitNvDevice: *** Cannot initialize the device
[ 8.378796] NVRM: RmInitAdapter: RmInitNvDevice failed, bailing out of RmInitAdapter
[ 8.378813] NVRM: rmapiReportLeakedDevices: Device object leak: (0xc1e00003, 0xcaf00000). Please file a bug against RM-core.
[ 8.378815] NVRM: nvAssertFailedNoLog: Assertion failed: 0 @ rmapi.c:935
[ 8.379702] NVRM: rmapiReportLeakedDevices: Device object leak: (0xc1e00004, 0xcaf00000). Please file a bug against RM-core.
[ 8.379706] NVRM: nvAssertFailedNoLog: Assertion failed: 0 @ rmapi.c:935
[ 8.380777] NVRM: nvAssertFailedNoLog: Assertion failed: listCount(&pKernelBus->virtualBar2[gfid].usedMapList) == 0 @ kern_bus_vbar2.c:346
[ 8.381014] NVOC: __nvoc_objDelete: Child class KernelVideoEngine not freed from parent class OBJGPU.NVRM: iovaspaceDestruct_IMPL: 4 left-over mappings in IOVAS 0xc100
[ 8.381052] NVRM: GPU 0000:c1:00.0: RmInitAdapter failed! (0x24:0x72:1185)
[ 8.383402] NVRM: GPU 0000:c1:00.0: rm_init_adapter failed, device minor number 0
[ 8.383734] [drm:nv_drm_dev_load [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x0000c100] Failed to allocate NvKmsKapiDevice
[ 8.396638] [drm:nv_drm_register_drm_device [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x0000c100] Failed to load device
The machine continued running and remained accessible afterwards, just without any display output.
There are 2 options for the fix:
- Revert commit 4dcd18ee1e4e8d1f5ae222044f462c4e7d231f2a.
- Checkout commit fe3c0636b03523f2e5ec35700a18ec2db2c8e0f4 - that would enable support for the memory tagging extension as well; I haven’t tested it properly myself, but I believe that it should be OK.
Just checking out the latest revision doesn’t seem to work and results in build failures. In both cases the firmware version would include support for x86 emulation, so I was able to see the UEFI setup screens, for example.
