Recommended connectors for CM3i
Hello Sir / Madam,
I am trying to develop a carrier board for industrial application that shall use the Radxa CM3i SOM. I am unable to find details pertaining to the connector used on the CM3i or the part no. of the same.
In the datasheet, it only specifies 100 pin 0.4mm pitch B2B connector. Now i am aware of two part nos of different makes that have similar specs.
DF40C-100DS-0.4V(51) - From Hirose Electric used on the Raspberry Pi CM4 carrier board.
10164227-1004A1RLF - From Amphenol used on the Raspberry Pi CM5 carrier board.
Could you kindly share part number of which connector is used on the CM3i and what is recommended part number that I can use on my carrier board.
Thanks with regards,
Gaurav
I belive it’s DF40C-100DS-0.4V(51) . you can check the BOM of cm3i carrier board.
