boot log follows.
I built the kernel with bsp using wsl2 + Ubuntu 22.
There is no further output on the console after ‘Starting Kernel …’
Boot Log Follows:
[ 452.186648] reboot: Restarting system
INFO: PSCI Power Domain Map:
INFO: Domain Node : Level 2, parent_node -1, State ON (0x0)
INFO: Domain Node : Level 1, parent_node 0, State ON (0x0)
INFO: Domain Node : Level 0, parent_node 0, State ON (0x0)
INFO: CPU Node : MPID 0x0, parent_node 1, State ON (0x0)
INFO: CPU Node : MPID 0x1, parent_node 1, State ON (0x0)
INFO: CPU Node : MPID 0x2, parent_node 1, State ON (0x0)
INFO: CPU Node : MPID 0x3, parent_node 1, State ON (0x0)
DDR V2.07 6ede97a868 wesley.yao 22/11/29-19:27:02
08
REG2C: 0x00000034, 0x00000034
In
589MHz
DDR3
Col=10 Bank=3 Row=15 Size=512MB
OUT: sdram_init finish.
Boot1 Release Time: Mar 24 2022 08:28:57, version: 1.36
ROM VER:0x56323030, 19
chip_id:330800,0
ChipType = 0x13, 514
DPLL = 1300 MHz
…nandc_flash_init enter…
No.1 FLASH ID:ff ff ff ff ff ff
DPLL = 1300 MHz
sfc nor id: ff ff ff
DPLL = 1300 MHz
sfc_nand id: ff ff ff
NeedKHz=200KHz,clock=12000KHz
mmc2:cmd8,20
mmc2:cmd5,20
mmc2:cmd55,20
DPLL = 1300 MHz
NeedKHz=18000KHz,clock=650000KHz
DPLL = 1300 MHz
NeedKHz=48000KHz,clock=650000KHz
mmc2:cmd19,100
SdmmcInit=2 0
BootCapSize=2000
UserCapSize=7456MB
FwPartOffset=2000 , 2000
SdmmcInit=0 NOT PRESENT
StorageInit ok = 13634
SecureMode = 0
Secure read PBA: 0x4
Secure read PBA: 0x404
Secure read PBA: 0x804
Secure read PBA: 0xc04
Secure read PBA: 0x1004
SecureInit ret = 0, SecureMode = 0
atags_set_bootdev: ret:(0)
GPT part: 0, name: config, start:0x8000, size:0x8000
GPT part: 1, name: boot, start:0x10000, size:0x96000
GPT part: 2, name: rootfs, start:0xa6000, size:0xde9fdf
no find partition:uboot.
LoadTrust Addr:0x4000
No find bl30.bin
No find bl32.bin
Load uboot, ReadLba = 2000
Load OK, addr=0x600000, size=0xa54f8
RunBL31 0x40000 @ 49342 us
INFO: Preloader serial: 0
NOTICE: BL31: v1.3(release):0252d5c8f
NOTICE: BL31: Built : 07:51:11, Sep 28 2022
INFO: Lastlog: last=0x100000, realtime=0x102000, size=0x2000
INFO: ARM GICv2 driver initialized
INFO: boot cpu mask: 1
INFO: plat_rockchip_pmu_init: pd status 0xe b
INFO: Entry point address = 0x600000
INFO: SPSR = 0x3c9
U-Boot latest-2023.10-8-eed05a18-geed05a18 (Jan 10 2024 - 03:39:03 +0000)
Model: Radxa ROCK S0
DRAM: 512 MiB (effective 510 MiB)
Core: 279 devices, 24 uclasses, devicetree: separate
MMC: mmc@ff480000: 1, mmc@ff490000: 0
Loading Environment from nowhere… OK
rockchip_dnl_key_pressed read board id failed
Net: eth0: ethernet@ff4e0000
starting USB…
No working controllers found
Unknown command ‘pci’ - try ‘help’
Hit Ctrl+C key in 0 seconds to stop autoboot…
** Booting bootflow ‘[email protected]_3’ with extlinux
U-Boot menu
1: Debian GNU/Linux 12 (bookworm) 6.1.68-20-stable
2: Debian GNU/Linux 12 (bookworm) 6.1.68-20-stable (rescue target)
3: Debian GNU/Linux 12 (bookworm) 6.1.68-1-stable
4: Debian GNU/Linux 12 (bookworm) 6.1.68-1-stable (rescue target)
Enter choice: 1: Debian GNU/Linux 12 (bookworm) 6.1.68-20-stable
Retrieving file: /boot/vmlinuz-6.1.68-20-stable
Retrieving file: /boot/initrd.img-6.1.68-20-stable
append: root=UUID=07e09376-a70a-4161-8ba0-0b5dc372a857 console=ttyS0,1500000n8 quiet splash loglevel=4 rw earlycon consoleblank=0 console=tty1 coherent_pool=2M irqchip.gicv3_pseudo_nmi=0 cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory swapaccount=1
Moving Image from 0x2080000 to 0x2200000, end=3790000
Flattened Device Tree blob at 1df211f0
Booting using the fdt blob at 0x1df211f0
Working FDT set to 1df211f0
Loading Ramdisk to 1d33e000, end 1df1b277 … OK
Loading Device Tree to 000000001d32f000, end 000000001d33db97 … OK
Working FDT set to 1d32f000
Starting kernel …
