Re: Automatic hanging of Rock3A after couple of days of working
I am working with Rock3A, initially it was working fine for a week. Later automatically it hanged up, when I tried to reboot it is displaying the logs related to PCIE. Please help me out with this issue?
1.224380] mmc3 mmc_send_io_op_cond err: -110
[ 1.224767] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 1.226148] cfg80211: Loaded X.509 cert ‘sforshee: 00b28ddf47aef9cea7’
[ 1.226242] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[ 1.226264] cfg80211: failed to load regulatory.db
[ 1.227718] I : [File] : drivers/gpu/arm/mali400/mali/linux/mali_kernel_linux.c; [Line] : 417; [Func] : mali_module_init(); svn_rev_string_from_arm of this mali_ko is ‘’, rk_ko_ver is ‘5’, .
[ 1.228078] Mali:
[ 1.228080] Mali device driver loaded
[ 1.228226] ALSA device list:
[ 1.228241] #0: rockchip,hdmi
[ 1.228253] #1: rockchip,rk809-codec
[ 1.231787] mmcblk0: p1 p2
[ 1.233722] RAMDISK: lz4 image found at block 0
[ 1.281966] RAMDISK: incomplete write (4194304 != 8388608)
[ 1.284378] Waiting for root device UUID=ee2ce23a-e0b1-4625-a54b-6ce12c167e97…
[ 1.303772] vendor storage:20190527 ret = 0
[ 1.311621] devfreq fde60000.gpu: Couldn’t update frequency transition information.
[ 1.577738] rk-pcie 3c0800000.pcie: PCIe Linking… LTSSM is 0x0
[ 1.577776] rk-pcie 3c0000000.pcie: PCIe Linking… LTSSM is 0x0
[ 2.591060] rk-pcie 3c0800000.pcie: PCIe Linking… LTSSM is 0x0
[ 2.591133] rk-pcie 3c0000000.pcie: PCIe Linking… LTSSM is 0x0
[ 3.604392] rk-pcie 3c0800000.pcie: PCIe Linking… LTSSM is 0x0
[ 3.604443] rk-pcie 3c0000000.pcie: PCIe Linking… LTSSM is 0x0
[ 4.617731] rk-pcie 3c0800000.pcie: PCIe Linking… LTSSM is 0x0
[ 4.617856] rk-pcie 3c0000000.pcie: PCIe Linking… LTSSM is 0x0
[ 5.630989] rk-pcie 3c0000000.pcie: PCIe Linking… LTSSM is 0x0
[ 5.631086] rk-pcie 3c0800000.pcie: PCIe Linking… LTSSM is 0x1
[ 6.644318] rk-pcie 3c0000000.pcie: PCIe Linking… LTSSM is 0x0
[ 6.644395] rk-pcie 3c0800000.pcie: PCIe Linking… LTSSM is 0x0
[ 7.657650] rk-pcie 3c0000000.pcie: PCIe Linking… LTSSM is 0x0
[ 7.657728] rk-pcie 3c0800000.pcie: PCIe Linking… LTSSM is 0x0
[ 8.670985] rk-pcie 3c0000000.pcie: PCIe Linking… LTSSM is 0x0
[ 8.671060] rk-pcie 3c0800000.pcie: PCIe Linking… LTSSM is 0x0
[ 9.684318] rk-pcie 3c0000000.pcie: PCIe Linking… LTSSM is 0x1
[ 9.684394] rk-pcie 3c0800000.pcie: PCIe Linking… LTSSM is 0x0
[ 10.697650] rk-pcie 3c0000000.pcie: PCIe Linking… LTSSM is 0x0
[ 10.697725] rk-pcie 3c0800000.pcie: PCIe Linking… LTSSM is 0x0
[ 11.710979] rk-pcie 3c0000000.pcie: PCIe Link Fail
[ 11.711051] rk-pcie 3c0800000.pcie: PCIe Link Fail
[ 11.711070] rk-pcie 3c0800000.pcie: failed to initialize host
[ 11.711104] rk-pcie 3c0000000.pcie: failed to initialize host
What system are You using? There were some issues on reboot with rock 3A, but they are already fixed in last version.
I am using Ubuntu 20.04 . Is there any other way you could help me from this issue?
Please let me know more on this, what images You downloaded or compiled on what version, have You used debos from radxa older than one week?
Good Morning, Sorry for the inconvenience.
I’ve downloaded Ubuntu 20.04 Focal version from official 3 weeks before.
Yes, The debos from radxa older than one week.
The Kernal Version is 4.19.193-24-rockchip-g526c758e05e0
Would you please upgrade kernel to 4.19.193-31?
sudo rm /var/lib/apt/lists/apt.radxa.com* # optional
sudo apt update
sudo apt install -y linux-4.19-rock-3-latest
