这是串口工具的输出,这些输出一直在循环
B1:e0f83180
TE: 143640
Board ID = 2
Set cpu clk to 24M
Set clk81 to 24M
CPU clk: 1200 MHz
Set clk81 to 166.6M
eMMC boot @ 0
sw8 s
board id: 2
Load FIP HDR from eMMC, src: 0x00010200, des: 0xfffd0000, size: 0x00004000, part: 0
fw parse done
Load ddrfw from eMMC, src: 0x00060200, des: 0xfffd0000, size: 0x0000c000, part: 0
Load ddrfw from eMMC, src: 0x00038200, des: 0xfffd0000, size: 0x00004000, part: 0
PIEI prepare done
fastboot data load
00000000
emmc switch 1 ok
00000000
emmc switch 2 ok
fastboot data verify
verify result: 265
LPDDR4 probe
ddr clk to 792MHz
Load ddrfw from eMMC, src: 0x0003c200, des: 0xfffd0000, size: 0x0000c000, part: 0
00000000
emmc switch 0 ok
dmc_version 0000
Check phy result
INFO : End of CA training
INFO : End of initialization
Check phy result
1D training failed
LPDDR4 probe
ddr clk to 792MHz
dmc_version 0000
Check phy result
Check phy result
1D training failed
All ddr config failed…
Reset…
boot times 0
