Has anyone had tried running Raspberry Pi OS on the CM3 and if so did you have success? I have tried the both full desktop versions and lite versions of both the 32-bit and 64-bit images an none of them boot. I’m assuming the device tree needs to be totally changed for the OS to run but is that all would need to be changed or is this not at all possible?
I have the CM mounted on a Raspberry Pi CM4 IO Board.
