Issue: Unable to detect Raspberry Pi Camera v1.3 on Radxa Zero 3 running Ubuntu 22.04 LTS. (Joshua-Riek image)
Steps followed:
Downloaded and Installed Required Packages:
- I installed
rsetupfrom GitHub - radxa-pkg/rsetup: Radxa system setup utilty usingsudo apt-get install ./rsetup_0.4.11_all.deb. - I also installed
librtuifrom GitHub - radxa-pkg/librtui: Radxa TUI library usingsudo apt-get install ./librtui_0.1.6_all.deb. - After installing
rsetup, I gained access to theu-boot-updatecommand, thoughrsetupitself didn’t list any overlays as it typically does in Radxa OS.
- I installed
Followed Camera Overlay Instructions:
- I referred to Ubuntu 22.04 LTS · Joshua-Riek/ubuntu-rockchip Wiki · GitHub for guidance.
- Created a directory for device-tree overlays:
/lib/firmware/device-tree/rockchip/overlay/. - Copied the camera overlay file
radxa-zero3-rpi-camera-v1.3.dtbointo this new folder.
Modified U-Boot and Updated Configuration:
- Edited the U-Boot configuration file as per the instructions.
- Ran
sudo u-boot-update, which resulted in the message “updating /boot/extlinux/extlinux.conf…”.
Current Issue:
- Despite these steps, the camera is still not detected when I check with
ls /dev/video.
Request for Assistance:
I would appreciate any guidance on additional steps I might need to enable the camera on this setup or troubleshoot the overlay configuration. Thank you!
