[ 0.000000] Linux version 5.10.103-v7l+ (dom@buildbot) (arm-linux-gnueabihf-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #1529 SMP Tue Mar 8 12:24:00 GMT 2022
[ 0.000000] OF: fdt: Machine model: Raspberry Pi 4 Model B Rev 1.2
[ 0.000000] random: fast init done
[ 0.000000] Reserved memory: created CMA memory pool at 0x000000002ac00000, size 64 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000000000000-0x000000002fffffff]
[ 0.000000] Normal empty
[ 0.000000] HighMem [mem 0x0000000030000000-0x00000000fbffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000000000000-0x000000003e5fffff]
[ 0.000000] node 0: [mem 0x0000000040000000-0x00000000fbffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x00000000fbffffff]
[ 0.000000] On node 0 totalpages: 1025536
[ 0.000000] DMA zone: 1728 pages used for memmap
[ 0.000000] HighMem zone: 828928 pages, LIFO batch:63
[ 0.000000] percpu: Embedded 20 pages/cpu s50828 r8192 d22900 u81920
[ 0.000000] pcpu-alloc: s50828 r8192 d22900 u81920 alloc=20*4096
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 1023808
[ 0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 bcm2708_fb.fbwidth=0 bcm2708_fb.fbheight=0 bcm2708_fb.fbdepth=16 bcm2708_fb.fbswap=1 smsc95xx.macaddr=DC:A6:32:AC:5B:A4 vc_mem.mem_base=0x3f000000 vc_mem.mem_size=0x3f600000 console=tty1 root=PARTUUID=2fed7fee-02 rootfstype=ext4 fsck.repair=yes rootwait quiet net.ifnames=0
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] software IO TLB: mapped [mem 0x0000000024890000-0x0000000028890000] (64MB)
[ 0.000000] Memory: 3914528K/4102144K available (10240K kernel code, 1366K rwdata, 3196K rodata, 2048K init, 882K bss, 122080K reserved, 65536K cma-reserved, 3315712K highmem)
[ 0.000000] ftrace: allocating 34355 entries in 101 pages
[ 0.000000] ftrace: allocated 101 pages with 4 groups
[ 0.000000] Rude variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
[ 0.000000] random: get_random_bytes called from start_kernel+0x3c8/0x59c with crng_init=1
[ 0.000004] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 2147483647500ns
[ 0.000011] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns
[ 0.000040] bcm2835: system timer (irq = 25)
[ 0.000303] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
[ 0.000310] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
[ 0.000317] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
[ 0.000323] Switching to timer-based delay loop, resolution 18ns
[ 0.000437] Console: colour dummy device 80x30
[ 0.000468] printk: console [tty1] enabled
[ 0.000492] Calibrating delay loop (skipped), value calculated using timer frequency.. 108.00 BogoMIPS (lpj=540000)
[ 0.000506] pid_max: default: 32768 minimum: 301
[ 0.000579] LSM: Security Framework initializing
[ 0.000661] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[ 0.000673] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[ 0.001339] cgroup: Disabling memory control group subsystem
[ 0.001444] CPU: Testing write buffer coherency: ok
[ 0.001661] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.002170] Setting up static identity map for 0x200000 - 0x20003c
[ 0.002253] rcu: Hierarchical SRCU implementation.
[ 0.002651] smp: Bringing up secondary CPUs …
[ 0.003212] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.003827] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[ 0.004400] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[ 0.004464] smp: Brought up 1 node, 4 CPUs
[ 0.004473] SMP: Total of 4 processors activated (432.00 BogoMIPS).
[ 0.004479] CPU: All CPU(s) started in HYP mode.
[ 0.004485] CPU: Virtualization extensions available.
[ 0.004900] devtmpfs: initialized
[ 0.010897] VFP support v0.3: implementor 41 architecture 3 part 40 variant 8 rev 0
[ 0.010998] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.011012] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.011953] pinctrl core: initialized pinctrl subsystem
[ 0.012427] NET: Registered protocol family 16
[ 0.014163] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[ 0.014489] audit: initializing netlink subsys (disabled)
[ 0.014611] audit: type=2000 audit(0.010:1): state=initialized audit_enabled=0 res=1
[ 0.014852] thermal_sys: Registered thermal governor ‘step_wise’
[ 0.015172] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.015179] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.015402] Serial: AMBA PL011 UART driver
[ 0.028001] bcm2835-mbox fe00b880.mailbox: mailbox enabled
[ 0.040332] raspberrypi-firmware soc:firmware: Attached to firmware from 2021-12-01T15:02:10, variant start_cd
[ 0.050336] raspberrypi-firmware soc:firmware: Firmware hash is 71bd3109023a0c8575585ba87cbb374d2eeb038f
[ 0.072723] Kprobes globally optimized
[ 0.075088] bcm2835-dma fe007000.dma: DMA legacy API manager, dmachans=0x1
[ 0.076821] vgaarb: loaded
[ 0.077018] SCSI subsystem initialized
[ 0.077116] usbcore: registered new interface driver usbfs
[ 0.077141] usbcore: registered new interface driver hub
[ 0.077172] usbcore: registered new device driver usb
[ 0.077314] usb_phy_generic phy: supply vcc not found, using dummy regulator
[ 0.078173] clocksource: Switched to clocksource arch_sys_counter
[ 0.458953] VFS: Disk quotas dquot_6.6.0
[ 0.458996] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.459067] FS-Cache: Loaded
[ 0.459172] CacheFiles: Loaded
[ 0.463369] NET: Registered protocol family 2
[ 0.463492] IP idents hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.464163] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[ 0.464181] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
[ 0.464208] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.464237] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.464320] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 0.464341] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 0.464446] NET: Registered protocol family 1
[ 0.464751] RPC: Registered named UNIX socket transport module.
[ 0.464758] RPC: Registered udp transport module.
[ 0.464764] RPC: Registered tcp transport module.
[ 0.464770] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.464781] PCI: CLS 0 bytes, default 64
[ 0.466256] Initialise system trusted keyrings
[ 0.466367] workingset: timestamp_bits=14 max_order=20 bucket_order=6
[ 0.469884] zbud: loaded
[ 0.470655] FS-Cache: Netfs ‘nfs’ registered for caching
[ 0.470988] NFS: Registering the id_resolver key type
[ 0.471007] Key type id_resolver registered
[ 0.471013] Key type id_legacy registered
[ 0.471074] nfs4filelayout_init: NFSv4 File Layout Driver Registering…
[ 0.471081] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering…
[ 0.471529] Key type asymmetric registered
[ 0.471536] Asymmetric key parser ‘x509’ registered
[ 0.471615] bounce: pool size: 64 pages
[ 0.471635] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
[ 0.471730] io scheduler mq-deadline registered
[ 0.471737] io scheduler kyber registered
[ 0.473590] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
[ 0.473604] brcm-pcie fd500000.pcie: No bus range found for /scb/pcie@7d500000, using [bus 00-ff]
[ 0.473637] brcm-pcie fd500000.pcie: MEM 0x0600000000..0x063fffffff → 0x00c0000000
[ 0.473672] brcm-pcie fd500000.pcie: IB MEM 0x0000000000..0x00bfffffff → 0x0400000000
[ 0.530253] brcm-pcie fd500000.pcie: link up, 5.0 GT/s PCIe x1 (SSC)
[ 0.530435] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
[ 0.530444] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 0.530453] pci_bus 0000:00: root bus resource [mem 0x600000000-0x63fffffff] (bus address [0xc0000000-0xffffffff])
[ 0.530494] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
[ 0.530602] pci 0000:00:00.0: PME# supported from D0 D3hot
[ 0.532016] PCI: bus0: Fast back to back transfers disabled
[ 0.532181] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
[ 0.532274] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
[ 0.532559] pci 0000:01:00.0: PME# supported from D0 D3cold
[ 0.533978] PCI: bus1: Fast back to back transfers disabled
[ 0.534006] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
[ 0.534016] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
[ 0.534075] pci 0000:00:00.0: PCI bridge to [bus 01]
[ 0.534086] pci 0000:00:00.0: bridge window [mem 0x600000000-0x6000fffff]
[ 0.534258] pcieport 0000:00:00.0: enabling device (0140 → 0142)
[ 0.534351] pcieport 0000:00:00.0: PME: Signaling with IRQ 62
[ 0.534735] bcm2708_fb soc:fb: Unable to determine number of FBs. Disabling driver.
[ 0.534757] bcm2708_fb: probe of soc:fb failed with error -2
[ 0.537932] iproc-rng200 fe104000.rng: hwrng registered
[ 0.538046] vc-mem: phys_addr:0x00000000 mem_base=0x3f000000 mem_size:0x3f600000(1014 MiB)
[ 0.538451] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
[ 0.543497] brd: module loaded
[ 0.549001] loop: module loaded
[ 0.549797] Loading iSCSI transport class v2.0-870.
[ 0.551852] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000
[ 0.648239] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus
[ 0.648760] usbcore: registered new interface driver r8152
[ 0.648792] usbcore: registered new interface driver lan78xx
[ 0.648817] usbcore: registered new interface driver smsc95xx
[ 0.650156] xhci_hcd 0000:01:00.0: enabling device (0140 → 0142)
[ 0.650268] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ 0.650283] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
[ 0.652023] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0000060000000890
[ 0.652610] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[ 0.652618] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.652625] usb usb1: Product: xHCI Host Controller
[ 0.652632] usb usb1: Manufacturer: Linux 5.10.103-v7l+ xhci-hcd
[ 0.652639] usb usb1: SerialNumber: 0000:01:00.0
[ 0.652967] hub 1-0:1.0: USB hub found
[ 0.653026] hub 1-0:1.0: 1 port detected
[ 0.653347] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ 0.653359] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
[ 0.653369] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
[ 0.653621] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[ 0.653629] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.653636] usb usb2: Product: xHCI Host Controller
[ 0.653642] usb usb2: Manufacturer: Linux 5.10.103-v7l+ xhci-hcd
[ 0.653649] usb usb2: SerialNumber: 0000:01:00.0
[ 0.653930] hub 2-0:1.0: USB hub found
[ 0.653988] hub 2-0:1.0: 4 ports detected
[ 0.654762] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 0.654881] dwc_otg: FIQ enabled
[ 0.654887] dwc_otg: NAK holdoff enabled
[ 0.654893] dwc_otg: FIQ split-transaction FSM enabled
[ 0.654900] Module dwc_common_port init
[ 0.655089] usbcore: registered new interface driver uas
[ 0.655134] usbcore: registered new interface driver usb-storage
[ 0.655217] mousedev: PS/2 mouse device common for all mice
[ 0.655922] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[ 0.657292] sdhci: Secure Digital Host Controller Interface driver
[ 0.657299] sdhci: Copyright(c) Pierre Ossman
[ 0.657597] mmc-bcm2835 fe300000.mmcnr: could not get clk, deferring probe
[ 0.657827] sdhci-pltfm: SDHCI platform and OF driver helper
[ 0.660227] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.660374] hid: raw HID events driver (C) Jiri Kosina
[ 0.660452] usbcore: registered new interface driver usbhid
[ 0.660458] usbhid: USB HID core driver
[ 0.662968] Initializing XFRM netlink socket
[ 0.662986] NET: Registered protocol family 17
[ 0.663049] Key type dns_resolver registered
[ 0.663227] Registering SWP/SWPB emulation handler
[ 0.663304] registered taskstats version 1
[ 0.663318] Loading compiled-in X.509 certificates
[ 0.663703] Key type ._fscrypt registered
[ 0.663710] Key type .fscrypt registered
[ 0.663717] Key type fscrypt-provisioning registered
[ 0.668579] uart-pl011 fe201000.serial: there is not valid maps for state default
[ 0.668717] uart-pl011 fe201000.serial: cts_event_workaround enabled
[ 0.668756] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 36, base_baud = 0) is a PL011 rev2
[ 0.673151] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
[ 0.673604] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
[ 0.673611] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
[ 0.700210] of_cfs_init
[ 0.700332] of_cfs_init: OK
[ 0.719686] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[ 0.721222] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 0.722762] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 0.725662] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ 0.727199] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 0.737866] mmc0: SDHCI controller on fe340000.mmc [fe340000.mmc] using ADMA
[ 0.738180] Waiting for root device PARTUUID=2fed7fee-02…
[ 0.789845] mmc1: new high speed SDIO card at address 0001
[ 0.842594] mmc0: new ultra high speed DDR50 SDXC card at address aaaa
[ 0.843022] mmcblk0: mmc0:aaaa SC64G 59.5 GiB
[ 0.845148] mmcblk0: p1 p2
[ 0.869921] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 0.869960] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 0.874314] devtmpfs: mounted
[ 0.878451] Freeing unused kernel memory: 2048K
[ 0.928312] Run /sbin/init as init process
[ 0.928318] with arguments:
[ 0.928324] /sbin/init
[ 0.928330] with environment:
[ 0.928336] HOME=/
[ 0.928341] TERM=linux
[ 0.938193] usb 1-1: new high-speed USB device number 2 using xhci_hcd
[ 1.120791] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21
[ 1.120800] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 1.120808] usb 1-1: Product: USB2.0 Hub
[ 1.122163] hub 1-1:1.0: USB hub found
[ 1.122452] hub 1-1:1.0: 4 ports detected
[ 1.297219] systemd[1]: System time before build time, advancing clock.
[ 1.379798] NET: Registered protocol family 10
[ 1.380440] Segment Routing with IPv6
[ 1.423891] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 1.424304] systemd[1]: Detected architecture arm.
[ 1.492571] systemd[1]: Set hostname to .
[ 1.754391] random: systemd: uninitialized urandom read (16 bytes read)
[ 1.850781] random: systemd: uninitialized urandom read (16 bytes read)
[ 1.852198] systemd[1]: Created slice system-systemd\x2dfsck.slice.
[ 1.852335] random: systemd: uninitialized urandom read (16 bytes read)
[ 1.852479] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ 1.852778] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 1.853112] systemd[1]: Listening on Journal Socket.
[ 1.857540] systemd[1]: Starting Load Kernel Modules…
[ 1.857810] systemd[1]: Reached target Swap.
[ 1.858115] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ 2.192606] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 2.347527] systemd-journald[122]: Received request to flush runtime journal from PID 1
[ 2.493294] rpivid-mem feb00000.hevc-decoder: rpivid-hevcmem initialised: Registers at 0xfeb00000 length 0x00010000
[ 2.493581] rpivid-mem feb10000.rpivid-local-intc: rpivid-intcmem initialised: Registers at 0xfeb10000 length 0x00001000
[ 2.493815] rpivid-mem feb20000.h264-decoder: rpivid-h264mem initialised: Registers at 0xfeb20000 length 0x00010000
[ 2.494159] rpivid-mem feb30000.vp9-decoder: rpivid-vp9mem initialised: Registers at 0xfeb30000 length 0x00010000
[ 2.494448] Driver for 1-wire Dallas network protocol.
[ 2.499059] gpio-4 (onewire@0): enforced open drain please flag it properly in DT/ACPI DSDT/board file
[ 2.737393] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 2.760298] cfg80211: Loaded X.509 cert ‘sforshee: 00b28ddf47aef9cea7’
[ 2.798109] brcmfmac: F1 signature read @0x18000000=0x15264345
[ 2.804230] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 2.804663] usbcore: registered new interface driver brcmfmac
[ 3.026218] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 3.027444] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 3.034617] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Jan 4 2021 19:56:29 version 7.45.229 (617f1f5 CY) FWID 01-2dbd9d2e
[ 3.679039] random: crng init done
[ 3.679050] random: 7 urandom warning(s) missed due to ratelimiting
[ 4.348647] bcmgenet fd580000.ethernet: configuring instance for external RGMII (RX delay)
[ 4.348925] bcmgenet fd580000.ethernet eth0: Link is Down
[ 4.359874] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save disabled
[ 4.987207] i2c /dev entries driver
[ 8.488361] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[ 8.488391] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 9.038476] usb 2-2: new SuperSpeed Gen 1 USB device number 2 using xhci_hcd
[ 9.069648] usb 2-2: New USB device found, idVendor=1058, idProduct=0a10, bcdDevice=80.34
[ 9.069658] usb 2-2: New USB device strings: Mfr=1, Product=2, SerialNumber=5
[ 9.069665] usb 2-2: Product: Go To Final Lap
[ 9.069672] usb 2-2: SerialNumber: 1234567890123
[ 9.085492] scsi host0: uas
[ 9.086546] scsi 0:0:0:0: Direct-Access ACASIS 8034 PQ: 0 ANSI: 6
[ 9.088774] scsi 0:0:0:1: Direct-Access ACASIS 8034 PQ: 0 ANSI: 6
[ 9.091075] sd 0:0:0:1: [sdb] 3907029168 512-byte logical blocks: (2.00 TB/1.82 TiB)
[ 9.091320] sd 0:0:0:1: [sdb] Write Protect is off
[ 9.091329] sd 0:0:0:1: [sdb] Mode Sense: 67 00 10 08
[ 9.091682] sd 0:0:0:0: [sda] 3907029168 512-byte logical blocks: (2.00 TB/1.82 TiB)
[ 9.091793] sd 0:0:0:1: [sdb] Write cache: enabled, read cache: enabled, supports DPO and FUA
[ 9.091914] sd 0:0:0:0: [sda] Write Protect is off
[ 9.091923] sd 0:0:0:0: [sda] Mode Sense: 67 00 10 08
[ 9.092527] sd 0:0:0:1: [sdb] Optimal transfer size 33553920 bytes
[ 9.092658] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, supports DPO and FUA
[ 9.093362] sd 0:0:0:0: [sda] Optimal transfer size 33553920 bytes
[ 9.113390] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 9.113479] sd 0:0:0:1: Attached scsi generic sg1 type 0
[ 9.216558] sda: sda1
[ 9.274397] sd 0:0:0:0: [sda] Attached SCSI disk
[ 9.274527] sdb: sdb1
[ 9.277210] sd 0:0:0:1: [sdb] Attached SCSI disk
[ 9.666122] md/raid1:md0: active with 2 out of 2 mirrors
[ 9.668909] md0: detected capacity change from 0 to 2000262529024
[ 9.700419] md0: p1
[ 33.452253] EXT4-fs (md0p1): recovery complete
[ 33.452787] EXT4-fs (md0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 41.909314] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
Maik
