Ok so after getting frustrated and leaving the NAS unplugged for 24 hours, I just plugged in it and the RAID was recognized lol. Not sure what happened, not sure why it fixed itself randomly.
[ 0.000000] Linux version 5.4.79-v7l+ (dom@buildbot) (gcc version 8.4.0 (Ubuntu/Linaro 8.4.0-3ubuntu1)) #1373 SMP Mon Nov 23 13:27:40 GMT 2020
[ 0.000000] OF: fdt: Machine model: Raspberry Pi 4 Model B Rev 1.1
[ 0.000000] Reserved memory: created CMA memory pool at 0x000000001ec00000, size 256 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] On node 0 totalpages: 1012736
[ 0.000000] DMA zone: 2304 pages used for memmap
[ 0.000000] HighMem zone: 816128 pages, LIFO batch:63
[ 0.000000] percpu: Embedded 20 pages/cpu s49804 r8192 d23924 u81920
[ 0.000000] pcpu-alloc: s49804 r8192 d23924 u81920 alloc=20*4096
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 1010432
[ 0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 video=HDMI-A-1:1920x1080M@60,margin_left=48,margin_right=48,margin_top=48,margin_bottom=48 smsc95xx.macaddr=DC:A6:32:5C:5C:4C vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 console=ttyS0,115200 console=tty1 root=PARTUUID=8b05e31d-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] software IO TLB: mapped [mem 0x17cc0000-0x1bcc0000] (64MB)
[ 0.000000] Memory: 3655600K/4050944K available (10240K kernel code, 739K rwdata, 2816K rodata, 2048K init, 854K bss, 133200K reserved, 262144K cma-reserved, 3264512K highmem)
[ 0.000000] ftrace: allocating 31111 entries in 61 pages
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
[ 0.000000] random: get_random_bytes called from start_kernel+0x344/0x518 with crng_init=0
[ 0.000008] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 2147483647500ns
[ 0.000031] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns
[ 0.000116] bcm2835: system timer (irq = 17)
[ 0.000774] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
[ 0.000794] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
[ 0.000812] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
[ 0.000828] Switching to timer-based delay loop, resolution 18ns
[ 0.001080] Console: colour dummy device 80x30
[ 0.001597] printk: console [tty1] enabled
[ 0.001663] Calibrating delay loop (skipped), value calculated using timer frequency.. 108.00 BogoMIPS (lpj=540000)
[ 0.001707] pid_max: default: 32768 minimum: 301
[ 0.001869] LSM: Security Framework initializing
[ 0.002085] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[ 0.002127] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[ 0.003543] Disabling memory control group subsystem
[ 0.003687] CPU: Testing write buffer coherency: ok
[ 0.004233] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.005178] Setting up static identity map for 0x200000 - 0x20003c
[ 0.005406] rcu: Hierarchical SRCU implementation.
[ 0.006122] smp: Bringing up secondary CPUs …
[ 0.007389] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.008755] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[ 0.010060] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[ 0.010217] smp: Brought up 1 node, 4 CPUs
[ 0.010291] SMP: Total of 4 processors activated (432.00 BogoMIPS).
[ 0.010318] CPU: All CPU(s) started in HYP mode.
[ 0.010343] CPU: Virtualization extensions available.
[ 0.011327] devtmpfs: initialized
[ 0.025273] VFP support v0.3: implementor 41 architecture 3 part 40 variant 8 rev 0
[ 0.025591] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.025643] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.032709] pinctrl core: initialized pinctrl subsystem
[ 0.033774] NET: Registered protocol family 16
[ 0.037803] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[ 0.038423] audit: initializing netlink subsys (disabled)
[ 0.038697] audit: type=2000 audit(0.030:1): state=initialized audit_enabled=0 res=1
[ 0.039813] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.039849] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.040211] Serial: AMBA PL011 UART driver
[ 0.044143] bcm2835-mbox fe00b880.mailbox: mailbox enabled
[ 0.070877] raspberrypi-firmware soc:firmware: Attached to firmware from 2020-11-30 22:12, variant start
[ 0.080892] raspberrypi-firmware soc:firmware: Firmware hash is ab1181cc0cb6df52bfae3b1d3fef0ce7c325166c
[ 0.136180] bcm2835-dma fe007000.dma: DMA legacy API manager, dmachans=0x1
[ 0.141458] vgaarb: loaded
[ 0.141962] SCSI subsystem initialized
[ 0.142209] usbcore: registered new interface driver usbfs
[ 0.142295] usbcore: registered new interface driver hub
[ 0.142435] usbcore: registered new device driver usb
[ 0.142794] usb_phy_generic phy: phy supply vcc not found, using dummy regulator
[ 0.144679] clocksource: Switched to clocksource arch_sys_counter
[ 0.905912] VFS: Disk quotas dquot_6.6.0
[ 0.906040] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.906242] FS-Cache: Loaded
[ 0.906469] CacheFiles: Loaded
[ 0.907477] simple-framebuffer 3e4e0000.framebuffer: framebuffer at 0x3e4e0000, 0x6e7000 bytes, mapped to 0x(ptrval)
[ 0.907521] simple-framebuffer 3e4e0000.framebuffer: format=a8r8g8b8, mode=1824x984x32, linelength=7296
[ 0.917166] Console: switching to colour frame buffer device 228x61
[ 0.925995] simple-framebuffer 3e4e0000.framebuffer: fb0: simplefb registered!
[ 0.936427] thermal_sys: Registered thermal governor ‘step_wise’
[ 0.936801] NET: Registered protocol family 2
[ 0.937696] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[ 0.937818] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
[ 0.937953] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.938095] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.938323] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 0.938425] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 0.938762] NET: Registered protocol family 1
[ 0.939584] RPC: Registered named UNIX socket transport module.
[ 0.939661] RPC: Registered udp transport module.
[ 0.939723] RPC: Registered tcp transport module.
[ 0.939787] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.939871] PCI: CLS 0 bytes, default 64
[ 0.941869] hw perfevents: enabled with armv7_cortex_a15 PMU driver, 7 counters available
[ 0.944244] Initialise system trusted keyrings
[ 0.944539] workingset: timestamp_bits=14 max_order=20 bucket_order=6
[ 0.955642] FS-Cache: Netfs ‘nfs’ registered for caching
[ 0.956461] NFS: Registering the id_resolver key type
[ 0.956555] Key type id_resolver registered
[ 0.956615] Key type id_legacy registered
[ 0.956683] nfs4filelayout_init: NFSv4 File Layout Driver Registering…
[ 0.957947] Key type asymmetric registered
[ 0.958012] Asymmetric key parser ‘x509’ registered
[ 0.958251] bounce: pool size: 64 pages
[ 0.961025] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
[ 0.963864] io scheduler mq-deadline registered
[ 0.966609] io scheduler kyber registered
[ 0.973504] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
[ 0.976284] brcm-pcie fd500000.pcie: No bus range found for /scb/pcie@7d500000, using [bus 00-ff]
[ 0.979008] brcm-pcie fd500000.pcie: MEM 0x0600000000..0x0603ffffff → 0x00f8000000
[ 0.981654] brcm-pcie fd500000.pcie: IB MEM 0x0000000000..0x00bfffffff → 0x0000000000
[ 1.046792] brcm-pcie fd500000.pcie: link up, 5 GT/s x1 (SSC)
[ 1.049736] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
[ 1.052373] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 1.055054] pci_bus 0000:00: root bus resource [mem 0x600000000-0x603ffffff] (bus address [0xf8000000-0xfbffffff])
[ 1.057739] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
[ 1.060601] pci 0000:00:00.0: PME# supported from D0 D3hot
[ 1.066518] PCI: bus0: Fast back to back transfers disabled
[ 1.069387] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
[ 1.072147] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
[ 1.075272] pci 0000:01:00.0: PME# supported from D0 D3cold
[ 1.081281] PCI: bus1: Fast back to back transfers disabled
[ 1.083972] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
[ 1.086656] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
[ 1.089362] pci 0000:00:00.0: PCI bridge to [bus 01]
[ 1.092005] pci 0000:00:00.0: bridge window [mem 0x600000000-0x6000fffff]
[ 1.094983] pcieport 0000:00:00.0: enabling device (0140 → 0142)
[ 1.097727] pcieport 0000:00:00.0: PME: Signaling with IRQ 56
[ 1.100731] pcieport 0000:00:00.0: AER: enabled with IRQ 56
[ 1.103658] pci 0000:01:00.0: enabling device (0140 → 0142)
[ 1.113685] iproc-rng200 fe104000.rng: hwrng registered
[ 1.116725] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
[ 1.120060] vc-sm: Videocore shared memory driver
[ 1.123241] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
[ 1.138343] brd: module loaded
[ 1.153693] loop: module loaded
[ 1.157838] Loading iSCSI transport class v2.0-870.
[ 1.162479] libphy: Fixed MDIO Bus: probed
[ 1.165580] bcmgenet fd580000.ethernet: failed to get enet clock
[ 1.168084] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000
[ 1.170541] bcmgenet fd580000.ethernet: failed to get enet-wol clock
[ 1.172975] bcmgenet fd580000.ethernet: failed to get enet-eee clock
[ 1.175445] bcmgenet: Skipping UMAC reset
[ 1.194725] libphy: bcmgenet MII bus: probed
[ 1.274795] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus
[ 1.278254] usbcore: registered new interface driver r8152
[ 1.280638] usbcore: registered new interface driver lan78xx
[ 1.283093] usbcore: registered new interface driver smsc95xx
[ 1.285985] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ 1.288377] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
[ 1.293202] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0000003000000890
[ 1.296876] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
[ 1.299235] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.301616] usb usb1: Product: xHCI Host Controller
[ 1.304024] usb usb1: Manufacturer: Linux 5.4.79-v7l+ xhci-hcd
[ 1.306460] usb usb1: SerialNumber: 0000:01:00.0
[ 1.309464] hub 1-0:1.0: USB hub found
[ 1.311908] hub 1-0:1.0: 1 port detected
[ 1.314754] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ 1.317106] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
[ 1.319459] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
[ 1.322306] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.04
[ 1.324731] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.327087] usb usb2: Product: xHCI Host Controller
[ 1.329371] usb usb2: Manufacturer: Linux 5.4.79-v7l+ xhci-hcd
[ 1.331624] usb usb2: SerialNumber: 0000:01:00.0
[ 1.334592] hub 2-0:1.0: USB hub found
[ 1.337011] hub 2-0:1.0: 4 ports detected
[ 1.340945] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 1.343596] dwc_otg: FIQ enabled
[ 1.343609] dwc_otg: NAK holdoff enabled
[ 1.343622] dwc_otg: FIQ split-transaction FSM enabled
[ 1.343639] Module dwc_common_port init
[ 1.344103] usbcore: registered new interface driver uas
[ 1.346511] usbcore: registered new interface driver usb-storage
[ 1.348932] mousedev: PS/2 mouse device common for all mice
[ 1.353182] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[ 1.359165] sdhci: Secure Digital Host Controller Interface driver
[ 1.361494] sdhci: Copyright(c) Pierre Ossman
[ 1.364314] mmc-bcm2835 fe300000.mmcnr: could not get clk, deferring probe
[ 1.367353] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.373608] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.376278] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.378826] usbcore: registered new interface driver usbhid
[ 1.381067] usbhid: USB HID core driver
[ 1.384475] vchiq: vchiq_init_state: slot_zero = (ptrval)
[ 1.388971] [vc_sm_connected_init]: start
[ 1.398952] [vc_sm_connected_init]: end - returning 0
[ 1.403553] Initializing XFRM netlink socket
[ 1.405962] NET: Registered protocol family 17
[ 1.408371] Key type dns_resolver registered
[ 1.411003] Registering SWP/SWPB emulation handler
[ 1.413507] registered taskstats version 1
[ 1.415745] Loading compiled-in X.509 certificates
[ 1.418722] Key type ._fscrypt registered
[ 1.420977] Key type .fscrypt registered
[ 1.434117] uart-pl011 fe201000.serial: cts_event_workaround enabled
[ 1.436502] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 29, base_baud = 0) is a PL011 rev2
[ 1.445054] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
[ 1.448269] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
[ 1.450587] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
[ 1.504692] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[ 1.508689] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 1.512672] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 1.517874] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ 1.520148] mmc0: SDHCI controller on fe340000.emmc2 [fe340000.emmc2] using ADMA
[ 1.523998] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 1.525539] of_cfs_init
[ 1.528936] of_cfs_init: OK
[ 1.532399] Waiting for root device PARTUUID=8b05e31d-02…
[ 1.573808] random: fast init done
[ 1.626340] mmc1: new high speed SDIO card at address 0001
[ 1.635373] mmc0: new ultra high speed DDR50 SDHC card at address 0001
[ 1.638590] mmcblk0: mmc0:0001 EB1QT 29.8 GiB
[ 1.642886] mmcblk0: p1 p2
[ 1.664619] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 1.667097] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 1.674715] devtmpfs: mounted
[ 1.684746] usb 1-1: new high-speed USB device number 2 using xhci_hcd
[ 1.685966] Freeing unused kernel memory: 2048K
[ 1.705000] Run /sbin/init as init process
[ 1.867416] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21
[ 1.869848] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 1.872184] usb 1-1: Product: USB2.0 Hub
[ 1.877089] hub 1-1:1.0: USB hub found
[ 1.879755] hub 1-1:1.0: 4 ports detected
[ 2.152991] systemd[1]: System time before build time, advancing clock.
[ 2.245981] NET: Registered protocol family 10
[ 2.249671] Segment Routing with IPv6
[ 2.279925] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 2.292714] systemd[1]: Detected architecture arm.
[ 2.378496] systemd[1]: Set hostname to .
[ 2.967166] systemd[1]: /lib/systemd/system/smbd.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/samba/smbd.pid → /run/samba/smbd.pid; please update the unit file accordingly.
[ 2.999067] systemd[1]: /lib/systemd/system/nmbd.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/samba/nmbd.pid → /run/samba/nmbd.pid; please update the unit file accordingly.
[ 3.088258] random: systemd: uninitialized urandom read (16 bytes read)
[ 3.096259] systemd[1]: sockets.target: Found ordering cycle on triggerhappy.socket/start
[ 3.099031] systemd[1]: sockets.target: Found dependency on sysinit.target/start
[ 3.101831] systemd[1]: sockets.target: Found dependency on local-fs.target/start
[ 3.104587] systemd[1]: sockets.target: Found dependency on mnt.mount/start
[ 3.107388] systemd[1]: sockets.target: Found dependency on rockpi-sata.service/start
[ 3.124290] random: systemd: uninitialized urandom read (16 bytes read)
[ 3.136500] random: systemd: uninitialized urandom read (16 bytes read)
[ 3.939629] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 4.049365] systemd-journald[111]: Received request to flush runtime journal from PID 1
[ 4.921270] random: crng init done
[ 4.921287] random: 7 urandom warning(s) missed due to ratelimiting
[ 5.096719] rpivid-mem feb00000.hevc-decoder: rpivid-hevcmem initialised: Registers at 0xfeb00000 length 0x00010000
[ 5.104577] rpivid-mem feb10000.rpivid-local-intc: rpivid-intcmem initialised: Registers at 0xfeb10000 length 0x00001000
[ 5.113048] rpivid-mem feb20000.h264-decoder: rpivid-h264mem initialised: Registers at 0xfeb20000 length 0x00010000
[ 5.114465] rpivid-mem feb30000.vp9-decoder: rpivid-vp9mem initialised: Registers at 0xfeb30000 length 0x00010000
[ 5.123044] Driver for 1-wire Dallas network protocol.
[ 5.124738] Adding 102396k swap on /var/swap. Priority:-2 extents:2 across:307200k SSFS
[ 5.158023] gpio-4 (onewire@0): enforced open drain please flag it properly in DT/ACPI DSDT/board file
[ 5.185349] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
[ 5.186318] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
[ 5.186351] [vc_sm_connected_init]: start
[ 5.189855] [vc_sm_connected_init]: installed successfully
[ 5.227950] mc: Linux media interface: v0.10
[ 5.270471] videodev: Linux video capture interface: v2.00
[ 5.342794] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
[ 5.352098] uart-pl011 fe201000.serial: no DMA platform data
[ 5.355420] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 0
[ 5.387331] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 5.389344] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 5.391379] bcm2835_audio bcm2835_audio: card created with 4 channels
[ 5.393113] bcm2835_audio bcm2835_audio: card created with 4 channels
[ 5.405364] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
[ 5.405967] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
[ 5.411741] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
[ 5.437455] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 5.454820] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
[ 5.454849] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
[ 5.455051] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
[ 5.456213] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
[ 5.457298] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
[ 5.457517] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
[ 5.457530] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
[ 5.457539] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
[ 5.457554] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
[ 5.457563] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
[ 5.457688] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
[ 5.459541] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
[ 5.459562] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
[ 5.485968] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
[ 5.485993] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
[ 5.536742] vc4-drm gpu: bound fe600000.firmwarekms (ops vc4_fkms_ops [vc4])
[ 5.536753] checking generic (3e4e0000 6e7000) vs hw (0 ffffffffffffffff)
[ 5.536760] fb0: switching to vc4drmfb from simple
[ 5.537135] Console: switching to colour dummy device 80x30
[ 5.537277] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 5.537283] [drm] No driver support for vblank timestamp query.
[ 5.537288] [drm] Setting vblank_disable_immediate to false because get_vblank_timestamp == NULL
[ 5.537642] [drm] Initialized vc4 0.0.0 20140616 for gpu on minor 1
[ 5.541749] vc4-drm gpu: HDMI-A-1: EDID is invalid:
[ 5.541761] [00] ZERO 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 5.541767] [00] ZERO 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 5.541773] [00] ZERO 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 5.541778] [00] ZERO 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 5.541785] [00] ZERO 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 5.541790] [00] ZERO 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 5.541797] [00] ZERO 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 5.541805] [00] ZERO 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 5.555750] 8021q: 802.1Q VLAN Support v1.8
[ 5.560708] cfg80211: Loaded X.509 cert ‘sforshee: 00b28ddf47aef9cea7’
[ 5.613418] brcmfmac: F1 signature read @0x18000000=0x15264345
[ 5.619865] bcmgenet: Skipping UMAC reset
[ 5.622696] bcmgenet fd580000.ethernet: configuring instance for external RGMII
[ 5.622927] bcmgenet fd580000.ethernet eth0: Link is Down
[ 5.624440] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 5.625928] usbcore: registered new interface driver brcmfmac
[ 5.641991] brcmfmac mmc1:0001:1: Direct firmware load for brcm/brcmfmac43455-sdio.raspberrypi,4-model-b.txt failed with error -2
[ 5.687107] Console: switching to colour frame buffer device 240x67
[ 5.709153] vc4-drm gpu: fb0: vc4drmfb frame buffer device
[ 5.854578] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 5.861688] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Mar 23 2020 02:19:54 version 7.45.206 (r725000 CY) FWID 01-88ee44ea
[ 6.107614] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
[ 6.413300] i2c /dev entries driver
[ 10.794869] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
[ 10.794916] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 11.965071] usb 2-2: new SuperSpeed Gen 1 USB device number 2 using xhci_hcd
[ 11.996395] usb 2-2: New USB device found, idVendor=1058, idProduct=0a10, bcdDevice=81.36
[ 11.996413] usb 2-2: New USB device strings: Mfr=1, Product=2, SerialNumber=5
[ 11.996432] usb 2-2: Product: JMS56x Series
[ 11.996447] usb 2-2: Manufacturer: JMicron
[ 11.996460] usb 2-2: SerialNumber: 1234567890123
[ 12.032605] scsi host0: uas
[ 12.036236] scsi 0:0:0:0: Direct-Access WDC WD10 JFCX-68N6GN0 8136 PQ: 0 ANSI: 6
[ 12.039967] sd 0:0:0:0: [sda] 1953525168 512-byte logical blocks: (1.00 TB/932 GiB)
[ 12.040229] sd 0:0:0:0: [sda] Write Protect is off
[ 12.040247] sd 0:0:0:0: [sda] Mode Sense: 67 00 10 08
[ 12.040695] scsi 0:0:0:1: Direct-Access WDC WD10 JFCX-68N6GN0 8136 PQ: 0 ANSI: 6
[ 12.040773] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, supports DPO and FUA
[ 12.041889] sd 0:0:0:0: [sda] Optimal transfer size 33553920 bytes
[ 12.044780] sd 0:0:0:1: [sdb] 1953525168 512-byte logical blocks: (1.00 TB/932 GiB)
[ 12.045045] sd 0:0:0:1: [sdb] Write Protect is off
[ 12.045062] sd 0:0:0:1: [sdb] Mode Sense: 67 00 10 08
[ 12.045555] sd 0:0:0:1: [sdb] Write cache: enabled, read cache: enabled, supports DPO and FUA
[ 12.046350] sd 0:0:0:1: [sdb] Optimal transfer size 33553920 bytes
[ 12.053326] Bluetooth: Core ver 2.22
[ 12.053392] NET: Registered protocol family 31
[ 12.053405] Bluetooth: HCI device and connection manager initialized
[ 12.053428] Bluetooth: HCI socket layer initialized
[ 12.053445] Bluetooth: L2CAP socket layer initialized
[ 12.053475] Bluetooth: SCO socket layer initialized
[ 12.065033] Bluetooth: HCI UART driver ver 2.3
[ 12.065051] Bluetooth: HCI UART protocol H4 registered
[ 12.065125] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 12.065555] Bluetooth: HCI UART protocol Broadcom registered
[ 12.098135] sda: sda1
[ 12.101149] sd 0:0:0:0: [sda] Attached SCSI disk
[ 12.114747] sdb: sdb1
[ 12.117536] sd 0:0:0:1: [sdb] Attached SCSI disk
[ 12.137675] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 12.138471] sd 0:0:0:1: Attached scsi generic sg1 type 0
[ 12.253728] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 12.253736] Bluetooth: BNEP filters: protocol multicast
[ 12.253749] Bluetooth: BNEP socket layer initialized
[ 12.584978] usb 2-1: new SuperSpeed Gen 1 USB device number 3 using xhci_hcd
[ 12.616144] usb 2-1: New USB device found, idVendor=1058, idProduct=0a10, bcdDevice=81.36
[ 12.616153] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=5
[ 12.616160] usb 2-1: Product: JMS56x Series
[ 12.616166] usb 2-1: Manufacturer: JMicron
[ 12.616173] usb 2-1: SerialNumber: 1234567890123
[ 12.630647] scsi host1: uas
[ 12.631654] scsi 1:0:0:0: Direct-Access WDC WD10 JFCX-68N6GN0 8136 PQ: 0 ANSI: 6
[ 12.632809] sd 1:0:0:0: Attached scsi generic sg2 type 0
[ 12.633869] sd 1:0:0:0: [sdc] 1953525168 512-byte logical blocks: (1.00 TB/932 GiB)
[ 12.634026] scsi 1:0:0:1: Direct-Access WDC WD10 JFCX-68N6GN0 8136 PQ: 0 ANSI: 6
[ 12.634143] sd 1:0:0:0: [sdc] Write Protect is off
[ 12.634151] sd 1:0:0:0: [sdc] Mode Sense: 67 00 10 08
[ 12.634724] sd 1:0:0:0: [sdc] Write cache: enabled, read cache: enabled, supports DPO and FUA
[ 12.635487] sd 1:0:0:0: [sdc] Optimal transfer size 33553920 bytes
[ 12.636459] sd 1:0:0:1: Attached scsi generic sg3 type 0
[ 12.637681] sd 1:0:0:1: [sdd] 1953525168 512-byte logical blocks: (1.00 TB/932 GiB)
[ 12.637933] sd 1:0:0:1: [sdd] Write Protect is off
[ 12.637941] sd 1:0:0:1: [sdd] Mode Sense: 67 00 10 08
[ 12.638428] sd 1:0:0:1: [sdd] Write cache: enabled, read cache: enabled, supports DPO and FUA
[ 12.639113] sd 1:0:0:1: [sdd] Optimal transfer size 33553920 bytes
[ 12.680189] sdc: sdc1
[ 12.682936] sd 1:0:0:0: [sdc] Attached SCSI disk
[ 12.699146] sdd: sdd1
[ 12.702073] sd 1:0:0:1: [sdd] Attached SCSI disk
[ 13.072178] md127: Warning: Device sdd1 is misaligned
[ 13.072189] md/raid10:md127: not clean – starting background reconstruction
[ 13.072194] md/raid10:md127: active with 4 out of 4 devices
[ 13.072446] md127: bitmap file is out of date (6954 < 7035) – forcing full recovery
[ 13.072538] md127: bitmap file is out of date, doing full recovery
[ 13.105896] md127: detected capacity change from 0 to 2000071688192
[ 13.437187] md: resync of RAID array md127
[ 13.596758] EXT4-fs (md127): mounted filesystem with ordered data mode. Opts: (null)
