Radxa Zero3W NPU dtbo Related Question
I followed the official tutorial to start the NPU. When the system version was Linux radxa-zero3 5.10.160-39-rk356x #3a8f7930a SMP Tue Dec 31 07:03:59 UTC 2024 aarch64 GNU/Linux, I failed many times to enable the NPU via the overlay in rsetup and rebooted. Then I tried to directly operate the dtbo file under /boot/dtbo to enable the NPU. After removing the “disable” suffix from rk3568-npu-enable.dtbo.disable and re-enabling U-Boot, I rebooted and executed the following command:
radxa@radxa-zero3:~$ sudo dmesg | grep "Initialized rknpu"
[   14.495806] [drm] Initialized rknpu 0.8.8 20230428 for fde40000.npu on minor 1
The driver was correctly identified, but I found that the dtbo file didn’t configure the power supply and memory allocation code. The error logs are as follows:
radxa@radxa-zero3:~$ sudo dmesg | grep -i "npu\|rknpu"
[sudo] password for radxa:
[   11.707601] OF: reserved mem: initialized node rknpu, compatible id shared-dma-pool
[   12.243791] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up npu-supply from device tree
[   12.243833] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up npu-supply property in node /power-management@fdd90000/power-controller failed
[   14.385866] input: rk805 pwrkey as /devices/platform/fdd40000.i2c/i2c-0/0-0020/rk805-pwrkey/input/input0
[   14.427722] rockchip,bus bus-npu: Looking up bus-supply from device tree
[   14.427949] rockchip,bus bus-npu: bin=0
[   14.427962] rockchip,bus bus-npu: Failed to get leakage
[   14.428065] rockchip,bus bus-npu: pvtm = 88810, from nvmem
[   14.428080] rockchip,bus bus-npu: pvtm-volt-sel=1
[   14.428394] rockchip,bus bus-npu: avs=0
[   14.493410] RKNPU fde40000.npu: Adding to iommu group 0
[   14.494287] RKNPU fde40000.npu: RKNPU: rknpu iommu is enabled, using iommu mode
[   14.494367] RKNPU fde40000.npu: Looking up rknpu-supply from device tree
[   14.494657] RKNPU fde40000.npu: Looking up mem-supply from device tree
[   14.494684] RKNPU fde40000.npu: Looking up mem-supply property in node /npu@fde40000 failed
[   14.494766] RKNPU fde40000.npu: can't request region for resource [mem 0xfde40000-0xfde4ffff]
[   14.496110] RKNPU fde40000.npu: Looking up rknpu-supply from device tree
[   14.496151] vdd_gpu: could not add device link fde40000.npu: -EEXIST
[   14.496197] RKNPU fde40000.npu: bin=0
[   14.496414] RKNPU fde40000.npu: leakage=4
[   14.496459] RKNPU fde40000.npu: pvtm = 88810, from nvmem
[   14.496479] RKNPU fde40000.npu: pvtm-volt-sel=2
[   14.497457] RKNPU fde40000.npu: avs=0
[   14.497774] RKNPU fde40000.npu: l=0 h=2147483647 hyst=5000 l_limit=0 h_limit=0 h_table=0
[   14.498425] RKNPU fde40000.npu: failed to find power_model node
[   14.498501] RKNPU fde40000.npu: RKNPU: failed to initialize power model
[   14.498523] RKNPU fde40000.npu: RKNPU: failed to get dynamic-coefficient
[   15.749690] input: dw_hdmi as /devices/platform/fe0a0000.hdmi/rc/rc0/input1
[   15.750933] input: hdmi_cec_key as /devices/platform/fe0a0000.hdmi/dw-hdmi-cec.1.auto/input/input2
I checked the rk3568-npu-enable.dtbo file as follows:
radxa@radxa-zero3:/boot/dtbo$ cat npu-overlay.dts
/dts-v1/;
        metadata {
                title = "Enable NPU";
                compatible = "radxa,rock-3a\0radxa,rock-3b\0radxa,rock-3c\0radxa,cm3-io\0radxa,cm3-rpi-cm4-io\0radxa,e23\0radxa,e25\0radxa,cm3i-io\0radxa,zero3";
                category = "misc";
                exclusive = "rknpu";
                description = "Enable NPU.";
        fragment@0 {
                target = <0xffffffff>;
                __overlay__ {
                        bus-supply = <0xffffffff>;
                        pvtm-supply = <0xffffffff>;
                        status = "okay";
        fragment@1 {
                __overlay__ {
                        memory-region = <0x01>;
                        status = "okay";
        fragment@2 {
                __overlay__ {
                        status = "okay";
        fragment@3 {
                __overlay__ {
                        rknpu {
                                compatible = "shared-dma-pool";
                                inactive;
                                reusable;
                                size = <0x00 0x8000000>;
                                alignment = <0x00 0x1000>;
                                phandle = <0x01>;
        __symbols__ {
                rknpu_reserved = "/fragment@3/__overlay__/rknpu";
        __fixups__ {
                bus_npu = "/fragment@0:target:0";
                vdd_logic = "/fragment@0/__overlay__:bus-supply:0";
                vdd_cpu = "/fragment@0/__overlay__:pvtm-supply:0";
                rknpu = "/fragment@1:target:0";
                rknpu_mmu = "/fragment@2:target:0";
                reserved_memory = "/fragment@3:target:0";
        __local_fixups__ {
                fragment@1 {
                        __overlay__ {
                                memory-region = <0x00>;
How should I configure the dtbo file to properly enable the NPU? Thank you!
You might take a look here: https://github.com/Qengineering/Radxa-Zero-3-NPU-Ubuntu22/wiki
Thanks a lot! I’ll try as soon as possible!
Hi @Helium648,
You can also do system updates via rsetup:
rsetup —> System —> System Update
Once the update is complete, the system will have the dtbo file for the npu, then use rsetup to open the overlay for the npu.
https://docs.radxa.com/zero/zero3/os-config/rsetup#overlays
Thanks a lot. I’ve already solved this problem. It’s caused by my stupid mistake. I should use space to select NPU option and then enter to enable NPU. Now it’s totally OK.
