Radxa zero wont-boot
temp1: 35
ddr tsensor avg: 0x1fcc, u_efuse: 0x806a
temp2: 35
device cool done
CONFIG_SYSTEM_AS_ROOT: systemroot
system_mode: 1
Start read misc partition datas!
Cannot find dev.
amlmmc cmd failed
store - STORE sub-system
Usage:
store init flag
store read name addr off|partition size
read ‘size’ bytes starting at offset ‘off’
to/from memory address ‘addr’, skipping bad blocks.
store write name addr off|partition size
write ‘size’ bytes starting at offset ‘off’
store rom_write add off size.
write uboot to the boot device
store erase boot/data:
erase the area which is uboot or data
store erase partition <partition_name>:
erase the area which partition in u-boot
store erase dtb
store erase key
store disprotect key
store rom_protect on/off
store scrub off|partition size
scrub the area from offset and size
store dtb iread/read/write addr
read/write dtb, size is optional
store key read/write addr
read/write key, size is optional
store ddr_parameter read/write addr
read/write ddr parameter, size is optional
store mbr addr
update mbr/partition table by dtb
[burnup]Err:store_read_ops,L84:cmd failed, ret=1, [store read misc 0xd3e7d090 0x0 0x820]
failed to store read misc.
info->magic =
info->version_major = 0
info->version_minor = 0
info->slots[0].priority = 0
info->slots[0].tries_remaining = 0
info->slots[0].successful_boot = 0
info->slots[1].priority = 0
info->slots[1].tries_remaining = 0
info->slots[1].successful_boot = 0
info->crc32 = 0
Magic is incorrect.
boot-info is invalid. Resetting.
save boot-info
info->magic =
info->version_major = 1
info->slots[0].priority = 15
info->slots[0].tries_remaining = 7
info->slots[1].priority = 14
info->slots[1].tries_remaining = 7
info->crc32 = -1075449479
Cannot find dev.
amlmmc cmd failed
Usage:
store init flag
store erase dtb
store erase key
store mbr addr
[burnup]Err:store_write_ops,L148:cmd [store write misc 0xd3e7d090 0x0 0x820] failed active slot = 0
CONFIG_AVB2: null
active_slot: normal
Cannot find dev.
amlmmc cmd failed
Usage:
store init flag
store erase dtb
store erase key
store mbr addr
[burnup]Err:store_read_ops,L84:cmd failed, ret=1, [store read boot 0x1080000 0x0 0x100000]
Err imgread(L328):Fail to read 0x100000B from part[boot] at offset 0
[KM]Error:f[keymanage_dts_parse]L307:not a fdt at 0x0000000001000000
InUsbBurn
noSof
sof timeout, reset usb phy tuning
card out
[MSG]mmcinfo failed!
card out
(Re)start USB…
USB0: USB3.0 XHCI init start
Register 3000140 NbrPorts 2
Starting the controller
USB XHCI 1.10
scanning bus 0 for devices… 1 USB Device(s) found
scanning usb for storage devices… 0 Storage Device(s) found
** Bad device usb 0 **
Cannot find dev.
amlmmc cmd failed
Usage:
store init flag
store erase dtb
store erase key
store mbr addr
[burnup]Err:store_read_ops,L84:cmd failed, ret=1, [store read misc 0xd3e7cb90 0x0 0x820]
info->magic =
info->crc32 = 0
Magic is incorrect.
save boot-info
info->magic =
Cannot find dev.
amlmmc cmd failed
Usage:
store init flag
store erase dtb
store erase key
store mbr addr
[burnup]Err:store_write_ops,L148:cmd [store write misc 0xd3e7cb90 0x0 0x820] failed active slot = 0
active_slot: normal
Cannot find dev.
amlmmc cmd failed
Usage:
store init flag
store erase dtb
store erase key
store mbr addr
[burnup]Err:store_read_ops,L84:cmd failed, ret=1, [store read recovery 0x1080000 0x0 0x100000]
Err imgread(L328):Fail to read 0x100000B from part[recovery] at offset 0
