Radxa zero won't appear as a USB storage device (eMMC)
I have tried pretty much everything at this stage. Using Windows computer. No matter in what order I flash, erase eMMC or whatever, radxa won’t pop up as a USB device. Please, help.
Thank you.
Try eMMC not detected by radxa-zero-erase-emmc.bin or rz-udisk-loader.bin
The simplest way I found is that
  1. follow the instruction on
    https://wiki.radxa.com/Zero/dev/maskrom#Enable_maskrom
  2. do not download the loaders listed on the page
  3. instead click the “Radxa website” link above the list of loaders
  4. download u-boot-2021.01-00042-g1e3a71b1dd.bin
After flashing it to the board, the board will disconnect automatically and reconnect as an USB drive.
Incredible! It worked. Thank you so so much. I just don’t know what to say. What exactly is the support team doing while laymen are doing all the work.
Appreciate it very much.
after flashing u-boot-2021.01-00042-g1e3a71b1dd.bin my eMMC appeared only once, the trick to see it as a USB was to use rufus image flasher.
work like a charm
