Dear Sir,
Thank for the reply. I intentionally pressed the keyboard to stop the loop process to get print out/screen dump. If i didnt press the key it would continue eternally. I later installed latest manjaro Gnome to find that it boots but wifi does not work and when wifi does not connect or turn on. The program freezes if not used for more than a minute and when connceting to HDMI the mouse and keyboard doesnt work after a minute.
Just 1/2 hour ago i downloaded https://github.com/radxa/radxa-zero-images-released/releases/download/radxa-zero-v20211028/zero_debian_buster_xfce4_arm64_20211028_1030-mbr.img.gz
unpacked with peazip7 . Used win32_diskimager 1.0 software to write the image file on the 32GB SD card. connected my usbserial dongle to the RADXA 512mb non EMCC board on one end and the other to my windows laptop. Opened Terraterm with baud selected to 115200. On powering up the board I found the board boots up with out any issue. . With instructions from web page https://wiki.radxa.com/Zero/Debian sucessfully connected to wifihotspot on my mobile telephone. I didnt upgrade as I was afraid of failure. I instaled python , PIP, numpy etc successfully. Also downloaded the bluetooth package and got bluetooth working. The web address from where i downloaded the image is https://github.com/radxa/radxa-zero-images-released/releases . Please find below the entire screen dump of the serial console if it might be useful to any novice like me in future. I will update here any issues after connecting via HDMI as i dont have the HDMI screen at present. All this what is discribed above was through serial console.
login : rock
password rock
The seller of the boar SPOTPEAR.COM was really helpful and acted promptly on my request
Thanks and regards
Sajeev Sankaran
Œ¤ãˆþü2Z
´å@`L@@VI14¤0²”@Œ! úm•
[ ý²@ÿÐ×ÎéVVC
Ë€@@wþý;ˆ!%2ê‚ üÌùû ŽÃìâ°‘cÑ„Zîpnâ°‘ÃM3Œ„ †ÃãÃð|hd†
óÐöhìªÿDÔöŠ&DûÒFôÜØ”HŠ>ˆÉÐè¨wö¦ð•ŽÜw
S²Á+©4±ªÀ€ˆA € |¨‹F
ÑD!Ó–%-€òøP„{à6]*<þô[ 3.847709] meson-vrtc ff8000a8.rtc: registered as rtc0
[ 3.847792] meson-vrtc ff8000a8.rtc: setting system clock to 1970-01-01T00:00:03 UTC (3)
Begin: Loading essential drivers … done.
Begin: Running /scripts/init-premount … done.
Begin: Mounting root file system … Begin: Running /scripts/local-top … done.
Begin: Running /scripts/local-premount … done.
Warning: fsck not present, so skipping root file system
[ 4.106096] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Opts: (null)
done.
Begin: Running /scripts/local-bottom … done.
Begin: Running /scripts/init-bottom … done.
[ 4.742857] systemd[1]: System time before build time, advancing clock.
[ 4.834373] systemd[1]: Inserted module ‘autofs4’
[ 4.890160] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 4.906130] systemd[1]: Detected architecture arm64.
Welcome to Debian GNU/Linux 10 (buster)!
[ 4.956624] systemd[1]: Set hostname to .
[ 5.420865] random: systemd: uninitialized urandom read (16 bytes read)
[ 5.425045] random: systemd: uninitialized urandom read (16 bytes read)
[ 5.431621] systemd[1]: Set up automount boot.automount.
[ OK ] Set up automount boot.automount.
[ 5.450167] random: systemd: uninitialized urandom read (16 bytes read)
[ 5.451306] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ OK ] Started Dispatch Password …ts to Console Directory Watch.
[ 5.480235] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ OK ] Created slice system-serial\x2dgetty.slice.
[ 5.498674] systemd[1]: Listening on Journal Socket.
[ OK ] Listening on Journal Socket.
[ 5.519597] systemd[1]: Starting Restore / save the current clock…
[ 5.541347] systemd[1]: Starting Create list of required static device nodes for the current kernel…
Starting Create list of re…odes for the current kernel…
[ 5.565378] systemd[1]: Mounting Kernel Debug File System…
Starting Nameserver information manager…
[ OK ] Listening on Journal Socket (/dev/log).
[ OK ] Listening on udev Kernel Socket.
[ OK ] Reached target Swap.
Mounting POSIX Message Queue File System…
Starting Remount Root and Kernel File Systems…
Mounting Huge Pages File System…
[ OK ] Started Forward Password R…uests to Wall Directory Watch.
[ 5.691055] EXT4-fs (mmcblk1p2): re-mounted. Opts: (null)
[ OK ] Reached target Local Encrypted Volumes.
[ OK ] Reached target Paths.
[ OK ] Listening on initctl Compatibility Named Pipe.
[ OK ] Reached target System Time Synchronized.
[ OK ] Reached target Remote File Systems.
[ OK ] Created slice User and Session Slice.
[ OK ] Reached target Slices.
[ OK ] Created slice system-getty.slice.
[ OK ] Listening on Journal Audit Socket.
Starting Journal Service…
[ OK ] Set up automount Arbitrary…s File System Automount Point.
Starting Load Kernel Modules…
[ OK ] Listening on udev Control Socket.
Starting udev Coldplug all Devices…
[ OK ] Started Restore / save the current clock.
[ OK ] Started Journal Service.
[ OK ] Started Create list of req… nodes for the current kernel.
[ OK ] Mounted Kernel Debug File System.
[ OK ] Mounted POSIX Message Queue File System.
[ OK ] Started Remount Root and Kernel File Systems.
[ OK ] Mounted Huge Pages File System.
[ OK ] Started Load Kernel Modules.
[ OK ] Started Nameserver information manager.
Starting Apply Kernel Variables…
Mounting Kernel Configuration File System…
Mounting FUSE Control File System…
Starting Load/Save Random Seed…
Starting Create System Users…
Starting Flush Journal to Persistent Storage…
[ OK ] Started udev Coldplug all Devices.
[ OK ] Started Apply Kernel Variables.
[ OK ] Mounted Kernel Configuration File System.
[ OK ] Mounted FUSE Control File System.
[ OK ] Started Load/Save Random Seed.
Starting Helper to synchronize boot up for ifupdown…
[ 6.226930] systemd-journald[1446]: Received request to flush runtime journal from PID 1
[ OK ] Started Helper to synchronize boot up for ifupdown.
[ OK ] Started Create System Users.
[ OK ] Started Flush Journal to Persistent Storage.
Starting Create Static Device Nodes in /dev…
[ OK ] Started Create Static Device Nodes in /dev.
Starting udev Kernel Device Manager…
[ OK ] Reached target Local File Systems (Pre).
[ OK ] Reached target Local File Systems.
Starting Create Volatile Files and Directories…
Starting Raise network interfaces…
[ OK ] Started Create Volatile Files and Directories.
Starting Update UTMP about System Boot/Shutdown…
[ OK ] Started Update UTMP about System Boot/Shutdown.
[ OK ] Started udev Kernel Device Manager.
[ OK ] Reached target System Initialization.
[ OK ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
[ OK ] Listening on D-Bus System Message Bus Socket.
[ OK ] Reached target Sockets.
[ OK ] Reached target Basic System.
Starting Resize root files…to fit available disk space…
Starting Resets System Activity Data Collector…
Starting LSB: Set sysfs variables from /etc/sysfs.conf…
Starting DHCP Client Daemon…
[ OK ] Started Daily man-db regeneration.
Starting Login Service…
Starting Avahi mDNS/DNS-SD Stack…
[ OK ] Started D-Bus System Message Bus.
Starting WPA supplicant…
Starting Network Manager…
[ OK ] Started Daily apt download activities.
[ OK ] Started Daily apt upgrade and clean activities.
[ OK ] Started Daily Cleanup of Temporary Directories.
[ OK ] Reached target Timers.
[ OK ] Started Raise network interfaces.
[ OK ] Started Resets System Activity Data Collector.
[ 7.035519] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 7.046327] mc: Linux media interface: v0.10
[ 7.052410] cfg80211: Loaded X.509 cert ‘sforshee: 00b28ddf47aef9cea7’
[ OK ] Started DHCP Client Daemon.
[ 7.084281] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[ 7.087396] cfg80211: failed to load regulatory.db
[ 7.127921] videodev: Linux video capture interface: v2.00
[ 7.155616] meson-drm ff900000.vpu: Queued 2 outputs on vpu
[ 7.195760] meson-drm ff900000.vpu: CVBS Output connector not available
[ 7.222167] meson-dw-hdmi ff600000.hdmi-tx: Detected HDMI TX controller v2.01a with HDCP (meson_dw_hdmi_phy)
[ 7.227674] meson-dw-hdmi ff600000.hdmi-tx: registered DesignWare HDMI I2C bus driver
[ 7.237774] meson-drm ff900000.vpu: bound ff600000.hdmi-tx (ops meson_dw_hdmi_ops [meson_dw_hdmi])
[ 7.246427] [drm] Initialized meson 1.0.0 20161109 for ff900000.vpu on minor 0
[ 7.252108] alloc_contig_range: [b100, b400) PFNs busy
[ 7.263296] alloc_contig_range: [b200, b500) PFNs busy
[ 7.426349] meson_vdec: module is from the staging directory, the quality is unknown, you have been warned.
[ 7.435030] Console: switching to colour frame buffer device 128x48
[ 7.472331] panfrost ffe40000.gpu: clock rate = 24000000
[ 7.472424] panfrost ffe40000.gpu: dev_pm_opp_set_regulators: no regulator (mali) found: -19
[ 7.473400] panfrost ffe40000.gpu: mali-g31 id 0x7093 major 0x0 minor 0x0 status 0x0
[ 7.473409] panfrost ffe40000.gpu: features: 00000000,3fde77ff, issues: 00000000,00000400
[ 7.473414] panfrost ffe40000.gpu: Features: L2:0x07100206 Shader:0x00000000 Tiler:0x00000209 Mem:0x1 MMU:0x00002821 AS:0xff JS:0x7
[ 7.473417] panfrost ffe40000.gpu: shader_present=0x1 l2_present=0x1
[ 7.490748] [drm] Initialized panfrost 1.1.0 20180908 for ffe40000.gpu on minor 1
[ 7.497668] meson-drm ff900000.vpu: [drm] fb0: mesondrmfb frame buffer device
[ 7.621337] Bluetooth: Core ver 2.22
[ 7.622798] NET: Registered protocol family 31
[ 7.623776] Bluetooth: HCI device and connection manager initialized
[ 7.631666] Bluetooth: HCI socket layer initialized
[ 7.635427] Bluetooth: L2CAP socket layer initialized
[ 7.640121] Bluetooth: SCO socket layer initialized
[ 7.710013] brcmfmac: brcmf_of_probe: interrupt could not be mapped
[ 7.711930] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43430-sdio for chip BCM43430/1
[ 7.723731] usbcore: registered new interface driver brcmfmac
[ 7.772590] brcmfmac mmc2:0001:1: Direct firmware load for brcm/brcmfmac43430-sdio.radxa,zero.txt failed with error -2
[ OK ] Started LSB: Set sysfs variables from /etc/sysfs.conf.
[ 7.804248] alloc_contig_range: [b100, b200) PFNs busy
[ 7.809301] alloc_contig_range: [b200, b300) PFNs busy
[ 7.817080] alloc_contig_range: [b100, b200) PFNs busy
[ 7.822868] alloc_contig_range: [b200, b300) PFNs busy
[ 7.829523] alloc_contig_range: [b100, b200) PFNs busy
[ 7.846380] alloc_contig_range: [b200, b300) PFNs busy
[ 7.850817] Bluetooth: HCI UART driver ver 2.3
[ 7.854134] Bluetooth: HCI UART protocol H4 registered
[ 7.859260] Bluetooth: HCI UART protocol BCSP registered
[ 7.864243] Bluetooth: HCI UART protocol LL registered
[ 7.868875] Bluetooth: HCI UART protocol ATH3K registered
[ 7.874622] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ OK ] Found device 7.880845] Bluetooth: HCI UART protocol Intel registered
39m/dev/ttyAML0.
[ 7.889124] Bluetooth: HCI UART protocol Broadcom registered
[ 7.889639] hci_uart_bcm serial0-0: supply vbat not found, using dummy regulator
[ 7.896221] Bluetooth: HCI UART protocol QCA registered
[ 7.904257] hci_uart_bcm serial0-0: supply vddio not found, using dummy regulator
[ 7.908669] Bluetooth: HCI UART protocol AG6XX registered
[ 7.908765] Bluetooth: HCI UART protocol Marvell registered
[ 8.082271] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43430-sdio for chip BCM43430/1
[ 8.088160] brcmfmac: brcmf_c_process_clm_blob: no clm_blob available (err=-2), device may have limited channels available
[ OK ] Started Login Service.
[ 8.110285] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM43430/1 wl0: Mar 30 2016 11:30:56 version 7.45.77.h8.4 FWID 01-ee8a6268
[ OK ] Started WPA supplicant.
[ OK ] Started Avahi mDNS/DNS-SD Stack.
Starting Bluetooth service…
[ OK ] Started Manage Sound Card State (restore and store).
Starting Save/Restore Sound Card State…
[ 8.255826] Bluetooth: hci0: BCM: chip id 94
[ 8.262801] Bluetooth: hci0: BCM: features 0x2e
[ 8.268506] Bluetooth: hci0: BCM43430A1
[ 8.271268] Bluetooth: hci0: BCM43430A1 (001.002.009) build 0000
[ 8.276547] Bluetooth: hci0: BCM: firmware Patch file not found, tried:
[ 8.283079] Bluetooth: hci0: BCM: ‘brcm/BCM43430A1.hcd’
[ 8.288170] Bluetooth: hci0: BCM: ‘brcm/BCM.hcd’
[ OK ] Listening on Load/Save RF …itch Status /dev/rfkill Watch.
Starting Load/Save RF Kill Switch Status…
[ OK ] Started Load/Save RF Kill Switch Status.
[ OK ] Started Bluetooth service.
[ 8.537307] random: crng init done
[ 8.539823] random: 7 urandom warning(s) missed due to ratelimiting
[ OK ] Reached target Bluetooth.
[ 8.622273] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 8.624824] Bluetooth: BNEP filters: protocol multicast
[ 8.629510] Bluetooth: BNEP socket layer initialized
Starting Hostname Service…
[ OK ] Started Network Manager.
[ OK ] Reached target Network.
Starting OpenBSD Secure Shell server…
Starting /etc/rc.local Compatibility…
Starting Rockchip adb…
Starting Network Time Service…
Starting Permit User Sessions…
[ OK ] Started Save/Restore Sound Card State.
[ OK ] Started /etc/rc.local Compatibility.
[ OK ] Started Permit User Sessions.
[ OK ] Started Hostname Service.
Starting Light Display Manager…
[ OK ] Started Getty on tty1.
[ 8.890542] file system registered
[ OK ] Started Serial Getty on ttyAML0.
[ OK ] Reached target Login Prompts.
[ OK ] Reached target Sound Card.
Starting Network Manager Script Dispatcher Service…
[ OK ] Started Network Time Service.
[ 9.072324] read descriptors
[ 9.074613] read strings
[ OK ] Started OpenBSD Secure Shell server.
[ OK ] Started Network Manager Script Dispatcher Service.
[ OK ] Started Light Display Manager.
[ 9.230540] EXT4-fs (mmcblk1p2): resizing filesystem from 597253 to 7656332 blocks
[ 10.025540] dwc2 ff400000.usb: bound driver configfs-gadget
[ OK ] Started Rockchip adb.
[ OK ] Reached target Multi-User System.
[ OK ] Reached target Graphical Interface.
Starting Update UTMP about System Runlevel Changes…
[ OK ] Started Update UTMP about System Runlevel Changes.
[ 10.184365] dwc2 ff400000.usb: new device is high-speed
[ 10.217730] dwc2 ff400000.usb: new address 2
Starting Authorization Manager…
[ 10.478551] alloc_contig_range: [b060, b080) PFNs busy
[ OK ] Started Authorization Manager.
[ 11.012443] EXT4-fs (mmcblk1p2): resized filesystem to 7656332
[ 12.529088] broken atomic modeset userspace detected, disabling atomic
[ OK ] Started Resize root filesy…m to fit available disk space.
Debian GNU/Linux 10 zero ttyAML0
zero login: 1234
Password:
Login incorrect
zero login: root
Login incorrect
zero login: 1234
Password:
Login timed out after 60 seconds.
zero login: radxa
Password:
Login incorrect
zero login: 1234
Password:
Login incorrect
zero login: root
Login incorrect
zero login: radxa
Password:
Login incorrect
zero login:
zero login: rock
Password:
Linux zero 5.10.69-6-amlogic-g775a46783ad8 #g775a46783ad8 SMP PREEMPT Thu Oct 28 14:57:18 CST 2021 aarch64
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
rock@zero:~$ bluetoothctl
[bluetooth]# power on
No default controller available
[bluetooth]# list
[bluetooth]# help
Menu main:
Available commands:
advertise Advertise Options Submenu
scan Scan Options Submenu
gatt Generic Attribute Submenu
list List available controllers
show [ctrl] Controller information
select Select default controller
devices List available devices
paired-devices List paired devices
system-alias Set controller alias
reset-alias Reset controller alias
power <on/off> Set controller power
pairable <on/off> Set controller pairable mode
discoverable <on/off> Set controller discoverable mode
agent <on/off/capability> Enable/disable agent with given capability
default-agent Set agent as the default one
advertise <on/off/type> Enable/disable advertising with given type
set-alias Set device alias
scan <on/off> Scan for devices
info [dev] Device information
pair [dev] Pair with device
trust [dev] Trust device
untrust [dev] Untrust device
block [dev] Block device
unblock [dev] Unblock device
remove Remove device
connect Connect device
disconnect [dev] Disconnect device
menu Select submenu
version Display version
quit Quit program
exit Quit program
help Display help about this program
export Print evironment variables
[bluetooth]# advertise
Missing on/off/type argument
[bluetooth]# advertise on
LEAdvertisingManager not found
Segmentation fault
rock@zero:~$ list
-bash: list: command not found
rock@zero:~$ ping ip-of-device
ping: ip-of-device: Temporary failure in name resolution
rock@zero:~$ ssh rock@ip-of-device
ssh: Could not resolve hostname ip-of-device: Temporary failure in name resolution
rock@zero:~$ nmcli
wlan0: disconnected
“Broadcom BCM43438 combo and Bluetooth Low Energy”
wifi (brcmfmac), EA:96:48:5D:5A:AB, hw, mtu 1500
lo: unmanaged
“lo”
loopback (unknown), 00:00:00:00:00:00, sw, mtu 65536
Use “nmcli device show” to get complete information about known devices and
“nmcli connection show” to get an overview on active connection profiles.
Consult nmcli(1) and nmcli-examples(5) manual pages for complete usage details.
rock@zero:~$ nmcli device show
GENERAL.DEVICE: wlan0
GENERAL.TYPE: wifi
GENERAL.HWADDR: EA:96:48:5D:5A:AB
GENERAL.MTU: 1500
GENERAL.STATE: 30 (disconnected)
GENERAL.CONNECTION: –
GENERAL.CON-PATH: –
GENERAL.DEVICE: lo
GENERAL.TYPE: loopback
GENERAL.HWADDR: 00:00:00:00:00:00
GENERAL.MTU: 65536
GENERAL.STATE: 10 (unmanaged)
GENERAL.CON-PATH: –
IP4.ADDRESS[1]: 127.0.0.1/8
IP4.GATEWAY: –
IP6.ADDRESS[1]: ::1/128
IP6.GATEWAY: –
IP6.ROUTE[1]: dst = ::1/128, nh = ::, mt = 256
rock@zero:~$ connect
-bash: connect: command not found
rock@zero:~$ sudo su
We trust you have received the usual lecture from the local System
Administrator. It usually boils down to these three things:
#1) Respect the privacy of others.
#2) Think before you type.
#3) With great power comes great responsibility.
[sudo] password for rock:
root@zero:/home/rock# nmcli r wifi on
root@zero:/home/rock# nmcli dev wifi
IN-USE SSID MODE CHAN RATE SIGNAL BARS SECURITY
Galaxy A33 5G D587 Infra 1 65
Mbit/s 74 â–‚â–„â–†_ WPA2
moto g(40) fusion_9614g Infra 11 11
7 Mbit/s 65 â–‚â–„â–†_ WPA2
Zain Broadband_04D9 Infra 5 27
0 Mbit/s 25 â–‚___ WPA2
root@zero:/home/rock# nmcli dev wifi connect “moto g(40) fusion_9614g” password “Pattipal1@”
[ 1437.506289] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
Device ‘wlan0’ successfully activated with ‘3a31883c-2564-4e89-b957-0494a6a3fc35’.
root@zero:/home/rock# pip install python3
bash: pip: command not found
root@zero:/home/rock# python --version
bash: python: command not found
root@zero:/home/rock# bluetooth
bash: bluetooth: command not found
root@zero:/home/rock# update
bash: update: command not found
root@zero:/home/rock# ping ip-of-device
ping: ip-of-device: Name or service not known
root@zero:/home/rock# ssh rock@ip-of-device
ssh: Could not resolve hostname ip-of-device: Name or service not known
root@zero:/home/rock# sudo apt get update
E: Invalid operation get
root@zero:/home/rock# sudo apt-get update
Get:1 http://security.debian.org buster/updates InRelease [34.8 kB]
Get:2 http://httpredir.debian.org/debian buster InRelease [122 kB]
Get:3 http://apt.radxa.com/buster-stable buster InRelease [2363 B]
Get:4 http://security.debian.org buster/updates/main arm64 Packages [580 kB]
Get:5 http://httpredir.debian.org/debian buster-updates InRelease [56.6 kB]
Err:3 http://apt.radxa.com/buster-stable buster InRelease
The following signatures couldn’t be verified because the public key is not available: NO_PUBKEY 9B98116C9AA302C7
Get:6 http://httpredir.debian.org/debian buster-backports InRelease [51.4 kB]
Get:7 http://security.debian.org buster/updates/main Translation-en [320 kB]
Get:8 http://httpredir.debian.org/debian buster/main arm64 Packages [7737 kB]
Get:9 http://security.debian.org buster/updates/contrib arm64 Packages [3452 B]
Get:10 http://security.debian.org buster/updates/contrib Translation-en [1488 B]
Get:11 http://security.debian.org buster/updates/non-free arm64 Packages [5500 B]
Get:12 http://security.debian.org buster/updates/non-free Translation-en [24.8 kB]
Get:13 http://httpredir.debian.org/debian buster/main Translation-en [5969 kB]
Get:14 http://httpredir.debian.org/debian buster/contrib arm64 Packages [38.4 kB]
Get:15 http://httpredir.debian.org/debian buster/contrib Translation-en [44.2 kB]
Get:16 http://httpredir.debian.org/debian buster/non-free arm64 Packages [53.9 kB]
Get:17 http://httpredir.debian.org/debian buster/non-free Translation-en [88.9 kB]
Get:18 http://httpredir.debian.org/debian buster-updates/main arm64 Packages [8780 B]
Get:19 http://httpredir.debian.org/debian buster-updates/main Translation-en [6915 B]
Get:20 http://httpredir.debian.org/debian buster-backports/main arm64 Packages [476 kB]
Get:21 http://httpredir.debian.org/debian buster-backports/main Translation-en [410 kB]
Get:22 http://httpredir.debian.org/debian buster-backports/contrib arm64 Packages [8520 B]
Get:23 http://httpredir.debian.org/debian buster-backports/contrib Translation-en [8088 B]
Get:24 http://httpredir.debian.org/debian buster-backports/non-free arm64 Packages [23.8 kB]
Get:25 http://httpredir.debian.org/debian buster-backports/non-free Translation-en [39.1 kB]
Reading package lists… Done
W: GPG error: http://apt.radxa.com/buster-stable buster InRelease: The following signatures couldn’t be verified because the public key is not available: NO_PUBKEY 9B98116C9AA302C7
E: The repository ‘http://apt.radxa.com/buster-stable buster InRelease’ is not signed.
N: Updating from such a repository can’t be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
root@zero:/home/rock# sudo apt-get python
E: Invalid operation python
root@zero:/home/rock# sudo apt-get pip
E: Invalid operation pip
root@zero:/home/rock# --version
bash: --version: command not found
root@zero:/home/rock# help
GNU bash, version 5.0.3(1)-release (aarch64-unknown-linux-gnu)
These shell commands are defined internally. Type help' to see this list. Type help name’ to find out more about the function name'. Use info bash’ to find out more about the shell in general.
Use man -k' or info’ to find out more about commands not in this list.
A star (*) next to a name means that the command is disabled.
job_spec [&] history [-c] [-d offset] [n] or hist>
(( expression )) if COMMANDS; then COMMANDS; [ elif C>
. filename [arguments] jobs [-lnprs] [jobspec …] or jobs >
: kill [-s sigspec | -n signum | -sigs>
[ arg… ] let arg [arg …]
[[ expression ]] local [option] name[=value] …
alias [-p] [name[=value] … ] logout [n]
bg [job_spec …] mapfile [-d delim] [-n count] [-O or>
bind [-lpsvPSVX] [-m keymap] [-f file> popd [-n] [+N | -N]
break [n] printf [-v var] format [arguments]
builtin [shell-builtin [arg …]] pushd [-n] [+N | -N | dir]
caller [expr] pwd [-LP]
case WORD in [PATTERN [| PATTERN]…)> read [-ers] [-a array] [-d delim] [->
cd [-L|[-P [-e]] [-@]] [dir] readarray [-d delim] [-n count] [-O >
command [-pVv] command [arg …] readonly [-aAf] [name[=value] …] o>
compgen [-abcdefgjksuv] [-o option] [> return [n]
complete [-abcdefgjksuv] [-pr] [-DEI]> select NAME [in WORDS … ;] do COMM>
compopt [-o|+o option] [-DEI] [name .> set [-abefhkmnptuvxBCHP] [-o option->
continue [n] shift [n]
coproc [NAME] command [redirections] shopt [-pqsu] [-o] [optname …]
declare [-aAfFgilnrtux] [-p] [name[=v> source filename [arguments]
dirs [-clpv] [+N] [-N] suspend [-f]
disown [-h] [-ar] [jobspec … | pid > test [expr]
echo [-neE] [arg …] time [-p] pipeline
enable [-a] [-dnps] [-f filename] [na> times
eval [arg …] trap [-lp] [[arg] signal_spec …]
exec [-cl] [-a name] [command [argume> true
exit [n] type [-afptP] name [name …]
export [-fn] [name[=value] …] or ex> typeset [-aAfFgilnrtux] [-p] name[=v>
false ulimit [-SHabcdefiklmnpqrstuvxPT] [l>
fc [-e ename] [-lnr] [first] [last] o> umask [-p] [-S] [mode]
fg [job_spec] unalias [-a] name [name …]
for NAME [in WORDS … ] ; do COMMAND> unset [-f] [-v] [-n] [name …]
for (( exp1; exp2; exp3 )); do COMMAN> until COMMANDS; do COMMANDS; done
function name { COMMANDS ; } or name > variables - Names and meanings of so>
getopts optstring name [arg] wait [-fn] [id …]
hash [-lr] [-p pathname] [-dt] [name > while COMMANDS; do COMMANDS; done
help [-dms] [pattern …] { COMMANDS ; }
root@zero:/home/rock# cd …
root@zero:/home# cd …
root@zero:/# python
root@zero:/# lst
bash: lst: command not found
root@zero:/# ls
bin dev home lost+found mnt proc run script sys usr
boot etc lib media opt root sbin srv tmp var
root@zero:/# sudo apt-get python
root@zero:/# sudo apt install python
Building dependency tree
The following additional packages will be installed:
libpython-stdlib libpython2-stdlib libpython2.7-minimal libpython2.7-stdlib
python-minimal python2 python2-minimal python2.7 python2.7-minimal
Suggested packages:
python-doc python-tk python2-doc python2.7-doc binfmt-support
The following NEW packages will be installed:
python python-minimal python2 python2-minimal python2.7 python2.7-minimal
0 upgraded, 10 newly installed, 0 to remove and 163 not upgraded.
Need to get 4068 kB of archives.
After this operation, 16.5 MB of additional disk space will be used.
Do you want to continue? [Y/n] Y
Get:1 http://security.debian.org buster/updates/main arm64 libpython2.7-minimal arm64 2.7.16-2+deb10u4 [397 kB]
Get:2 http://httpredir.debian.org/debian buster/main arm64 python2-minimal arm64 2.7.16-1 [41.4 kB]
Get:3 http://httpredir.debian.org/debian buster/main arm64 python-minimal arm64 2.7.16-1 [21.0 kB]
Get:4 http://httpredir.debian.org/debian buster/main arm64 libpython2-stdlib arm64 2.7.16-1 [20.8 kB]
Get:5 http://httpredir.debian.org/debian buster/main arm64 libpython-stdlib arm64 2.7.16-1 [20.8 kB]
Get:6 http://httpredir.debian.org/debian buster/main arm64 python2 arm64 2.7.16-1 [41.6 kB]
Get:7 http://security.debian.org buster/updates/main arm64 python2.7-minimal arm64 2.7.16-2+deb10u4 [1304 kB]
Get:8 http://httpredir.debian.org/debian buster/main arm64 python arm64 2.7.16-1 [22.8 kB]
Get:9 http://security.debian.org buster/updates/main arm64 libpython2.7-stdlib arm64 2.7.16-2+deb10u4 [1893 kB]
