I am struggling to get UART working on the Radxa Zero. It seems that the RX pin has a pull-down resistor on it as the voltage is 0. Is there any way to swap this pin so that the RX pin has a pull-up resistor? I am trying to use an open drain system.
Did you get to the bottom of this? I was trying to do some similar with overlays:
/dts-v1/;
/plugin/;
compatible = "radxa,zero", "amlogic,g12a";
fragment@0 {
target = <&uart_ao_a_pins>;
__overlay__ {
mux {
groups = "uart_ao_a_tx",
"uart_ao_a_rx";
function = "uart_ao_a";
/delete-property/ bias-disable;
bias-pull-down;
