Radxa Zero uart could not connect
Hi, i have radxa zero and i want to use uart port to connect with 3D printer, i have followed the process to enable UART . I enabled “overlays=meson-g12a-uart-ao-a-on-gpioao-0-gpioao-1”,
deleted “console=ttyAML0,115200” in /boot/Env.txt.
and connected the 3D printer to Pin#8 and Pin#10,
but my Radxa Zero won’t boot.
Other UART options are OK such as meson-g12a-uart-ao-b-on-gpioao-2-gpioao-3, meson-g12a-uart-ao-b-on-gpioao-8-gpioao-9 and connected the printer to pin# 7 &11 and pin # 35,37 respectively , however still radxa couldn’t communicate to 3d printer,
Please advise how i can make it working, note that my 3d printer is working fine with raspberry pi using URAT but not with radxa, I tried with with gpioao-3,2 and gpioao-8-9
Here you can see the available uart ports
rock@radxa-zero:~$ dmesg | grep tty
[ 0.000000] Kernel command line: initrd=initrd.img-5.10.69-12-amlogic-g98700611d064 root=UUID=730575af-8654-46cc-a99d-231c6837336d rootwait rw rootfstype=ext4 console=tty1 console=both panic=10 consoleblank=0 loglevel=7 cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory swapaccount=1
[ 0.000581] printk: console [tty1] enabled
[ 1.873799] ff804000.serial: ttyAML1 at MMIO 0xff804000 (irq = 21, base_baud = 1500000) is a meson_uart
[ 1.874780] ffd24000.serial: ttyAML2 at MMIO 0xffd24000 (irq = 27, base_baud = 1500000) is a meson_uart
[ 1.874955] serial serial0: tty port ttyAML2 registered
