Radxa Zero Height
Hello, I am considering purchasing a Radxa Zero for a project. The Radxa would be housed inside an enclosure that is 1 inch in height. What is the height of the Zero board with the 40-pin headers installed?
Thank you.
-DB
The headers are the tallest feature. On mine, distance from the bottom of the PCB substrate to the tip of the pins is a hair over 10mm.
Looks like this will work for me then. Thanks for your help!
Absolute height from the top of the header to the bottom is about 11.6mm. Still less than 1" though.
