hi all,
My company want to evaluate Rockchip platform, particularly the RK3566 SOC platform for our next gen Linux-based product. We mainly utilize the Yocto project to build up Linux images for our products
As the first step, I follow this guide (https://docs.radxa.com/en/rock5/rock5b/other-os/yocto) to successfully build up a core-image-weston image running in a microSD card in my radxa-zero-3w board
Next, I want to make the board runs systemd-boot so that it can support different boot menus of a product and one menu is to load the kernel with a ramdisk image to perform a new image installation to the internal eMMC drive of the board. I follow this guide about the boot partitions of Rockchip SOC (https://opensource.rock-chips.com/wiki_Partitions) to make a new image-installer.wks.in file in my Yocto environment in order to generate a WIC image with required partitions:
part loader1 --offset 64s --fixed-size 3552K --fstype=none --part-name loader1 --source rawcopy --sourceparams="file=${SPL_BINARY}"
part v_storage --offset 7168s --fixed-size 256K --fstype=none --part-name v_storage
part reserved --offset 7680s --fixed-size 192K --fstype=none --part-name reserved
part reserved1 --offset 8064s --fixed-size 32K --fstype=none --part-name reserved1
part uboot_env --offset 8128s --fixed-size 32K --fstype=none --part-name uboot_env ${RK_UBOOT_ENV}
part reserved2 --offset 8192s --fixed-size 4096K --fstype=none --part-name reserved2
part loader2 --offset 16384s --fixed-size 4096K --fstype=none --part-name loader2 --source rawcopy --sourceparams="file=u-boot.${UBOOT_SUFFIX}"
part atf --offset 24576s --fixed-size 4096K --fstype=none --part-name atf
part /boot --offset 32768s --fixed-size 400M --source bootimg-efi --sourceparams="loader=${EFI_PROVIDER},title=n_install,label=install-efi,initrd=${INITRD_IMAGE_LIVE}-${MACHINE}.${INITRAMFS_FSTYPES}" --ondisk sda --label h_install --active --align 1024 --use-uuid
part / --source bootimg-partition --ondisk sda --fstype=ext4 --label image --use-uuid --align 1024
bootloader --ptable gpt --timeout=5 --append=" rootfstype=ext4"
So in the boot partition, I use bootimg-efi of Yocto which runs systemd-boot with this boot.conf:
title install
linux /fitImage
options LABEL=install-efi rootfstype=ext4
initrd /core-image-minimal-initramfs-radxa-zero-3w.cpio.gz
It is expected that it will run the kernel image fitImage with the initramdisk core-image-minimal-initramfs-radxa-zero-3w.cpio.gz in which new image installation code to be executed.
However, systemd-boot failed to load the fitImage with this error message:
Not a PE-COFF file
Error loading \fitImage: Load error
Here is the boot log:
U-Boot 2024.07-rc3 (Mar 28 2025 - 08:31:33 +0000)
Model: Radxa ZERO 3W
DRAM: 2 GiB
PMIC: RK8170 (on=0x40, off=0x00)
Core: 299 devices, 28 uclasses, devicetree: separate
MMC: mmc@fe2b0000: 1, mmc@fe2c0000: 2, mmc@fe310000: 0
In: serial@fe660000
Out: serial@fe660000
Err: serial@fe660000
Net: No ethernet found.
Scanning for bootflows in all bootdevs
Seq Method State Uclass Part Name Filename
Scanning global bootmeth 'efi_mgr':
No EFI system partition
Failed to persist EFI variables
Scanning bootdev '[email protected]':
1 efi ready mmc 9 [email protected] /EFI/BOOT/BOOTAA64.EFI
** Booting bootflow '[email protected]_9' with efi
Booting /\EFI\BOOT\BOOTAA64.EFI
Not a PE-COFF file
## Application failed, r = 1
Boot failed (err=-22)
Unknown uclass 'nvme' in label
Unknown uclass 'scsi' in label
Bus usb@fd000000: Register 2000140 NbrPorts 2
Starting the controller
USB XHCI 1.10
scanning bus usb@fd000000 for devices... 1 USB Device(s) found
No ethernet found.
No ethernet found.
No more bootdevs
(2 bootflows, 2 valid)
Can anyone support me what is the reason why systemd-boot could not load the fitImage here?
Thank you,
Huy
