I’m having issue with the USB 3 port where my Gigabit USB Ethernet only get USB 2 speed, 480M.
I’ve tried flip the port and for some times it getting 5000M speed but after 10-20 minutes, the connection lost and didn’t appear in my LAN network. Then if I flip back the port its working fine with 480M speed.
I cant upload the log as I’m new here, so below is the dmesg | grep -i usb
dmesg | grep -i usb
[ 11.398014] usbcore: registered new interface driver usbfs
[ 11.398097] usbcore: registered new interface driver hub
[ 11.398162] usbcore: registered new device driver usb
[ 12.267989] phy phy-fe8a0000.usb2-phy.0: Looking up phy-supply from device tree
[ 12.268026] phy phy-fe8a0000.usb2-phy.0: Looking up phy-supply property in node /usb2-phy@fe8a0000/host-port failed
[ 12.268230] phy phy-fe8a0000.usb2-phy.1: Looking up phy-supply from device tree
[ 12.268251] phy phy-fe8a0000.usb2-phy.1: Looking up phy-supply property in node /usb2-phy@fe8a0000/otg-port failed
[ 12.268400] phy phy-fe8a0000.usb2-phy.1: Looking up vbus-supply from device tree
[ 12.268422] phy phy-fe8a0000.usb2-phy.1: Looking up vbus-supply property in node /usb2-phy@fe8a0000/otg-port failed
[ 12.270632] phy phy-fe8b0000.usb2-phy.2: Looking up phy-supply from device tree
[ 12.270663] phy phy-fe8b0000.usb2-phy.2: Looking up phy-supply property in node /usb2-phy@fe8b0000/host-port failed
[ 12.270850] phy phy-fe8b0000.usb2-phy.3: Looking up phy-supply from device tree
[ 12.270872] phy phy-fe8b0000.usb2-phy.3: Looking up phy-supply property in node /usb2-phy@fe8b0000/otg-port failed
[ 12.271038] phy phy-fe8b0000.usb2-phy.3: Looking up vbus-supply from device tree
[ 12.271059] phy phy-fe8b0000.usb2-phy.3: Looking up vbus-supply property in node /usb2-phy@fe8b0000/otg-port failed
[ 12.570163] usbcore: registered new interface driver rndis_wlan
[ 12.570265] usbcore: registered new interface driver asix
[ 12.570337] usbcore: registered new interface driver cdc_ether
[ 12.570420] usbcore: registered new interface driver rndis_host
[ 12.570509] usbcore: registered new interface driver cdc_ncm
[ 12.586097] phy phy-fe8b0000.usb2-phy.3: illegal mode
[ 12.587013] xhci-hcd xhci-hcd.4.auto: new USB bus registered, assigned bus number 1
[ 12.587605] xhci-hcd xhci-hcd.4.auto: new USB bus registered, assigned bus number 2
[ 12.587634] xhci-hcd xhci-hcd.4.auto: Host supports USB 3.0 SuperSpeed
[ 12.588040] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.01
[ 12.588063] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 12.588079] usb usb1: Product: xHCI Host Controller
[ 12.588092] usb usb1: Manufacturer: Linux 6.1.75-vendor-rk35xx xhci-hcd
[ 12.588105] usb usb1: SerialNumber: xhci-hcd.4.auto
[ 12.588211] ehci-platform fd800000.usb: EHCI Host Controller
[ 12.588246] phy phy-fe8b0000.usb2-phy.3: illegal mode
[ 12.588269] ohci-platform fd840000.usb: Generic Platform OHCI controller
[ 12.588285] ehci-platform fd880000.usb: EHCI Host Controller
[ 12.588304] ohci-platform fd8c0000.usb: Generic Platform OHCI controller
[ 12.589079] hub 1-0:1.0: USB hub found
[ 12.589995] usb usb2: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 12.590296] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.01
[ 12.590320] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 12.590336] usb usb2: Product: xHCI Host Controller
[ 12.590349] usb usb2: Manufacturer: Linux 6.1.75-vendor-rk35xx xhci-hcd
[ 12.590362] usb usb2: SerialNumber: xhci-hcd.4.auto
[ 12.591191] hub 2-0:1.0: USB hub found
[ 12.591967] ohci-platform fd840000.usb: new USB bus registered, assigned bus number 3
[ 12.592010] ehci-platform fd880000.usb: new USB bus registered, assigned bus number 4
[ 12.592064] ohci-platform fd8c0000.usb: new USB bus registered, assigned bus number 5
[ 12.592209] usbcore: registered new interface driver cdc_acm
[ 12.592225] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 12.592231] ohci-platform fd840000.usb: irq 48, io mem 0xfd840000
[ 12.592257] ehci-platform fd880000.usb: irq 47, io mem 0xfd880000
[ 12.592291] ohci-platform fd8c0000.usb: irq 49, io mem 0xfd8c0000
[ 12.592337] ehci-platform fd800000.usb: new USB bus registered, assigned bus number 6
[ 12.592540] ehci-platform fd800000.usb: irq 46, io mem 0xfd800000
[ 12.592693] usbcore: registered new interface driver uas
[ 12.592842] usbcore: registered new interface driver usb-storage
[ 12.605553] ehci-platform fd880000.usb: USB 2.0 started, EHCI 1.00
[ 12.606336] usb usb4: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.01
[ 12.606361] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 12.606378] usb usb4: Product: EHCI Host Controller
[ 12.606390] usb usb4: Manufacturer: Linux 6.1.75-vendor-rk35xx ehci_hcd
[ 12.606403] usb usb4: SerialNumber: fd880000.usb
[ 12.607295] hub 4-0:1.0: USB hub found
[ 12.618857] ehci-platform fd800000.usb: USB 2.0 started, EHCI 1.00
[ 12.619293] usb usb6: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.01
[ 12.619317] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 12.619333] usb usb6: Product: EHCI Host Controller
[ 12.619347] usb usb6: Manufacturer: Linux 6.1.75-vendor-rk35xx ehci_hcd
[ 12.619360] usb usb6: SerialNumber: fd800000.usb
[ 12.620173] hub 6-0:1.0: USB hub found
[ 12.653247] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 6.01
[ 12.653272] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 12.653288] usb usb3: Product: Generic Platform OHCI controller
[ 12.653302] usb usb3: Manufacturer: Linux 6.1.75-vendor-rk35xx ohci_hcd
[ 12.653314] usb usb3: SerialNumber: fd840000.usb
[ 12.654200] hub 3-0:1.0: USB hub found
[ 12.655334] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 6.01
[ 12.655360] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 12.655376] usb usb5: Product: Generic Platform OHCI controller
[ 12.655388] usb usb5: Manufacturer: Linux 6.1.75-vendor-rk35xx ohci_hcd
[ 12.655401] usb usb5: SerialNumber: fd8c0000.usb
[ 12.656352] hub 5-0:1.0: USB hub found
[ 12.669738] typec_fusb302 3-0022: Looking up vbus-supply from device tree
[ 12.669771] typec_fusb302 3-0022: Looking up vbus-supply property in node /i2c@fe5c0000/fusb302@22 failed
[ 12.669831] typec_fusb302 3-0022: supply vbus not found, using dummy regulator
[ 12.670977] OF: graph: no port node found in /i2c@fe5c0000/fusb302@22
[ 12.691260] usbcore: registered new interface driver uvcvideo
[ 12.710457] usbcore: registered new interface driver usbhid
[ 12.710464] usbhid: USB HID core driver
[ 12.720312] usbcore: registered new interface driver snd-usb-audio
[ 12.848233] usb 1-1: new full-speed USB device number 2 using xhci-hcd
[ 12.972579] usb 1-1: device descriptor read/64, error -71
[ 13.202374] usb 1-1: device descriptor read/64, error -71
[ 13.432274] usb 1-1: new full-speed USB device number 3 using xhci-hcd
[ 13.555787] usb 1-1: device descriptor read/64, error -71
[ 13.785617] usb 1-1: device descriptor read/64, error -71
[ 13.893000] usb usb1-port1: attempt power cycle
[ 14.295842] usb 1-1: new full-speed USB device number 4 using xhci-hcd
[ 14.296095] usb 1-1: Device not responding to setup address.
[ 14.502673] usb 1-1: Device not responding to setup address.
[ 14.709169] usb 1-1: device not accepting address 4, error -71
[ 14.832501] usb 1-1: new full-speed USB device number 5 using xhci-hcd
[ 14.832719] usb 1-1: Device not responding to setup address.
[ 15.039513] usb 1-1: Device not responding to setup address.
[ 15.245882] usb 1-1: device not accepting address 5, error -71
[ 15.246413] usb usb1-port1: unable to enumerate USB device
[ 18.448936] systemd[1]: Reached target usb-gadget.target - Hardware activated USB gadget.
[ 134.935751] usb 1-1: new high-speed USB device number 6 using xhci-hcd
[ 135.077662] usb 1-1: New USB device found, idVendor=0bda, idProduct=8153, bcdDevice=30.00
[ 135.077731] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=6
[ 135.077765] usb 1-1: Product: USB 10/100/1000 LAN
[ 135.077791] usb 1-1: Manufacturer: Realtek
[ 135.077815] usb 1-1: SerialNumber: 000001000000
[ 135.216430] usbcore: registered new device driver r8152-cfgselector
[ 135.436382] r8152-cfgselector 1-1: reset high-speed USB device number 6 using xhci-hcd
[ 135.707052] usbcore: registered new interface driver r8152
[ 135.714154] usbcore: registered new interface driver r8153_ecm
I’m using Armbian v24.8.4 6.1.75-vendor-rk35xx https://dl.armbian.com/radxa-zero3/Bookworm_vendor_minimal with 20W UGreen adapter
*There was a post in Armbian forum but no reply from them, hopefully I get some help here
