Hi all.
There was a problem with the new board out of the box.
After power is applied, the process stops with the following messages (in UART Console):
Starting kernel …
[ 11.412587] fiq_debugger fiq_debugger.0: IRQ fiq not found
[ 11.412650] fiq_debugger fiq_debugger.0: IRQ wakeup not found
[ 11.412684] fiq_debugger_probe: could not install nmi irq handler
[ 12.883703] mpp-iep2 fdef0000.iep: allocate roi buffer failed
[ 12.903745] arm-scmi firmware:scmi: Failed. SCMI protocol 22 not active.
[ 12.925711] dwhdmi-rockchip fe0a0000.hdmi: IRQ index 1 not found
[ 12.929282] no ATF memory for init
[ 12.950011] no ATF memory for init
[ 12.961611] rk_gmac-dwmac fe010000.ethernet: no regulator found
[ 13.358542] rk817-battery rk817-battery: Failed to find matching dt id
[ 13.358957] rk817-charger rk817-charger: Failed to find matching dt id
[ 13.369679] OF: graph: no port node found in /i2c@fe5c0000/fusb302@22
[ 13.401358] arm-scmi firmware:scmi: Failed. SCMI protocol 17 not active.
[ 13.408060] rksfc_base v1.1 2016-01-08
[ 13.456515] mpp_rkvenc fdf40000.rkvenc: Failed to get leakage
[ 13.457105] mpp_rkvenc fdf40000.rkvenc: failed to find power_model node
[ 13.457130] mpp_rkvenc fdf40000.rkvenc: failed to initialize power model
[ 13.457144] mpp_rkvenc fdf40000.rkvenc: failed to get dynamic-coefficient
[ 13.458828] mpp_rkvdec2 fdf80200.rkvdec: shared_niu_a is not found!
[ 13.458856] rkvdec2_init:1022: No niu aclk reset resource define
[ 13.458872] mpp_rkvdec2 fdf80200.rkvdec: shared_niu_h is not found!
[ 13.458884] rkvdec2_init:1025: No niu hclk reset resource define
[ 13.459736] mpp_rkvdec2 fdf80200.rkvdec: failed to find power_model node
[ 13.459760] mpp_rkvdec2 fdf80200.rkvdec: failed to initialize power model
[ 13.459774] mpp_rkvdec2 fdf80200.rkvdec: failed to get dynamic-coefficient
[ 13.462915] rockchip-dmc dmc: failed to get vop pn to msch rl
[ 13.463211] rockchip-dmc dmc: could not find power_model node
[ 14.031624] mmc1: delay init for 600 ms to enable UHS mode
I use Debian CLI R3. Tried different cards and power supplies, but the result is the same.
Has anyone had similar problems
