Hi , I have flashed radxa-zero3_debian_bullseye_xfce_b6.img.xz as well as armbian images for radxa zero 3w in a uSD, always getting the same result, not booting at all
Any idea how to try to solve this problem?
Thanks!
Thanks!
Have you tried other uSD with high speed to try?
Hi, I have tried 4 different microSDs, three of them are Class 10.
Is there any command/s I can use to get some diagnostic information, so I can verify if there is some chance to get the board up and running? It is a new one so I did not expect to run into this kind of issue that early. Thanks in advance
I will try with rkdeveloptool
Solution:
push the boot button and power up the board ![]()
$ rkdeveloptool ld
DevNo=1 Vid=0x2207,Pid=0x350a,LocationID=102 Maskrom
$ sudo rkdeveloptool db rk356x_spl_loader_ddr1056_v1.12.109_no_check_todly.bin
Downloading bootloader succeeded.
$ sudo rkdeveloptool wl 0 radxa-zero3_debian_bullseye_xfce_b6.img
Write LBA from file (100%)
$ sudo rkdeveloptool rd
now the board boots =)
It seems the microSD card hardware/driver does not work. So how is the product tested before shipping? is it ever tested? I continue testing
