If you get a type error when running tests
failed to open rknpu module, need to insmod rknpudriver! and failed to open run device!
- Check if there is an NPU in DMESG
sudo dmesg | grep rknpu
You should get something like:
[ 11.732651] OF: reserved mem: initialized node rknpu, compatible id shared-dma-pool [ 14.747633] RKNPU fde40000.npu: RKNPU: rknpu iommu is enabled, using iommu mode [ 14.747732] RKNPU fde40000.npu: Looking up rknpu-supply from device tree [ 14.749181] [drm] Initialized rknpu 0.8.8 20230428 for fde40000.npu on minor 1 [ 14.749492] RKNPU fde40000.npu: Looking up rknpu-supply from device tree
If the NPU is present or nothing if it is not. - To activate NPU, do the following:
2.1. sudo apt update
2.2. sudo apt full-upgrade
2.3. sudo reboot
2.4. Then run rsetup
2.5. Select Overlays -> Yes -> Manage overlays -> Enable NPU -> Ok - Exit the program
2.6. sudo reboot
2.7. After the reboot, check if the NPU - sudo dmesg | grep rknpu has appeared
If the NPU has appeared, good luck - everything should work.
Don’t forget to install the libraries themselves:
apt update
wget https://github.com/radxa-pkg/rknn2/releases/download/2.2.0-1/python3-rknnlite2-example_2.2.0-1_all.deb
wget https://github.com/radxa-pkg/rknn2/releases/download/2.2.0-1/python3-rknnlite2_2.2.0-1_arm64.deb
wget https://github.com/radxa-pkg/rknn2/releases/download/2.2.0-1/rknpu2-rk356x_2.2.0-1_arm64.deb
wget https://github.com/radxa-pkg/rknn2/releases/download/2.2.0-1/rknpu2-rk3588_2.2.0-1_arm64.deb
For rk356x -> apt install ./rknpu2-rk356x_2.2.0-1_amd64.deb ./python3-rknnlite2_2.2.0-1_amd64.deb ./python3-rknnlite2-example_2.2.0-1_all.deb
For rk3588 -> apt install ./rknpu2-rk3588_2.2.0-1_amd64.deb ./python3-rknnlite2_2.2.0-1_amd64.deb ./python3-rknnlite2-example_2.2.0-1_all.deb
The examples are now in /usr/share/python3-rknnlite2
If the examples don’t run
According to the documentation https://docs.radxa.com/en/zero/zero3/app-development/rknn_install
- Make a git clone https://github.com/airockchip/rknn-toolkit2.git
- python -V
- Install pip install rknn-toolkit2/packages/rknn_toolkit2-…- cp3x-cp3x-linux_x86_64.whl for your python version
Then everything should work
Be happy!
