The rule of thumb is looking at what is in the devicetree for the zero3 … and there is no other chip, so everything will have the ap6212.
If you need anything bigger, go for the radxa zero 2pro, or a cm3
What do you mean by radxa zero 2 PRO? Also CM3 is way overkill for me, I just wanted stable wifi with higher bandwidth. I don’t think it is expensive or anything. Orange Pi zero 2 w also has wifi 5 but it doesn’t have integrated emmc option (and it is very cheap, but i would pay more for integrated emmc), so I thought that zero 3 will be what i need, but it seems like SBC world doesn’t go where it is logical.
Can you grab some more information about zero 2 pro from device tree? I really hope they are changing the wifi chip in that device, because there was a thread (Random wifi speed drops) where I was talking with RadxaYuntian and he said that it is “faulty” by design, and they are working on a solution with the manufacturer, but maybe using a faulty chip in an upcoming device would be a bad idea, but I can imagine that scenario.
Currently there is only AP6212 version for ZERO 3W. We are looking for potential replacement for it though.
ZERO 2 PRO uses AP6256 instead of CM256 used on ZERO.
We all have different perspectives but I sort of follow Raspberries lead where a ‘Zero’ is a low cost, low peripheral based board that is that 80/20 that creates low cost than fuller 100% boards do not.
I don’t actually like soldered on eMMC as sooner or later it creates eWaste, Raspberry don’t see the need and neither do I to be honest.
The $19 board for me is just about perfect and I have always wondered about this from the likes of Radxa is how do they manage any economies of sale with so many variations that is a huge influence of why Raspberry have so few variations.
Also I just purchased the 2gb no emmc version as it was only 2$ more that 1Gb but just been back on and the 1gb is now a $16.00 sbc and I think personally there is a huge array of maker products at that level.
The GPU is a cut down G52 and that SoC RK3566 is all about low cost and it fits perfectly as a zero.
From Magic Mirror, Squeezlite/Snapcast Audio, Sec Cam, Mic Beamformer and a hole load of edge maker projects are avail and cheaper the base the better as I have been using PiZero2.
I also think that is where they are aiming at and yeah they have created a better product as I am switching from RpiZero2, but no I don’t really care to much about the idea of gaming on such a device or would even think of it.
I do hope Radxa might think of creating a Zero3-M2 though with the bigger RK3568 and extend its length so its just enough to fit a 2280 M.2 on its base and likely top side there is now enough room for a Nic.
You can get Nvme for the price of eMMC in fact its cheaper as 1st click Google is
https://www.stuff-uk.net/p-2248472.aspx £7.86 but its biggest factor is its not soldered onto the board, just as is a SD card.
I can not even see the point in eMMC anymore especially soldered on varieties and likely Radxa could of done themselves a favor and increased economies of sale by not even offering it as higher end boards do, even if it is strange when they also can fit NVME.
I sort of get it as Radxa isn’t just manufacturer the are also a custom desgn house and they are showing off what they can do, as quite a few SBC manufacturers are.
I would love to see a Zero3-M2 likely with better WiFi still budget priced, but obviously it costs more.
Everybody has different takes but for me but where they have placed the Zero3 is perfect and I have no interest in versions above the 2gb no-emmc.
Mali-G52 1-Core-2EE is also sometimes refferred to a G52-Lite as its not even full GL and inferior to even the G31-MP2 on the original Zero.
If I remember correctly because Arm calls ‘shader cores’ ‘Execution Engines’ the Mali-G52 2EE is called so because its a single core with only 2EE when the G52 usually has x4.
Its likely you need a Zero with a WiFi fix or wait for the Zero2-Pro that whispers have it is going to be soon with a Amlogic A311D with a full blown ARM MaliTM-G52 MP4(6EE).
Now I have seen the 1gb for $16 I guess I should buy one of those also to bench directly against the Rpi02.
You are right about soldered emmc, it could be swappable, or there is 2240 m.2 which is low in size, but high in price (but i think it will be lower if steamdeck will be outdated). Although i like the soldered emmc, because it surely cheaper to produce, but waaay faster and reliable than a microsd of all kind, and I don’t know why would it be waste (pls explain it further, i don’t get it). A fully m.2 2280 would take so much space that zero form factor would be ruined. Also i think they can manage the versions pretty good for zero 2, because there is no more version for the zero 2 than the zero 3, but the wifi chip is not changed for the pricier one.
For the gaming part: I would use it for all other kind of media too, because tv stick are just lamely low in performance, but the problem was coming for the zero 2 in streaming games from my pc to my tv (which is far from each other, big house problems). So you are right about the need of zero 2 pro for me, and I’m all excited about it.
Also, thanks for the good news @RadxaYuntian!
eMMC will wear out and when soldered you can not replace. Also its not that true about SD being slow or unreliable and there are many utils to stop wear.
I never really bother about speed as its still only a quad core A55 not a threadripper. Also from the new Pi benchmarks with UHS SD there is still plenty of mileage.
Its only the newer bigger models RK3588(s) even then the CPU is only entry level desktop and many NVME are really still an odd match…
Dunno when the Zero2 Pro arrives, but likely a much better choice.
More important… is to know if Joshuas will port ubuntu for it with all the amazing fate perks and all.
Nope he is sticking just to RK3588 as far as I know all rk3588 boards and its quite a list but none stray very far from the EVB.
There is no amazing fate perks for rk3566 or A311D or need as far as I know.
The reason why I like those images apart from nessacary function they are pretty much vanilla without a load of userside scripts.
It pretty much the default Ubuntu you get with a distro minimal desktop install or minimal server install of ubuntu as for me it should.
Lets see… because if the pros dont optimise said chromium browsers… u might face some struggle to hit the quality level of enjoyment…
I am not sure really about the state of the rk3566 image but both the rk3566 & A311D have full blown Mesa drivers.
I will not be running any desktop on a $16 1gb SBC, maybe hook up a camera and run some sort of Yolo detection and any other Edge AI things I can think of.
I tend to use them as a big microcontroller where I can be slack and just hack some python together without need or worry of constraints and optimisation I might need to do on a microcontroller.
I have been meaning for some time to have another look at Snapcast audio clients, Keyword 2 mic Beamformer and a few other items but nothing desktop orientated, but haven’t been really watching what the state of play is like with the rk3566 and have 2 on order and will see when they arrive.
PS just as I go on a rant about eMMC I have started thinking about how to employ a distributed cam AI system where each node records to SD card. I realise I want eMMC for the system partition as I am going to record until they die and just replace.
Doh and I ordered x2 without!
