Radxa Zero - 2GB RAm with 8GB EMMC - no WIFI
Hello Yuntian,
is there any news? It’s quite frustrating that I can’t use my Wi-Fi on the zero still.
Is still Debian the only image with working wifi on AW-CM2568M?
I tested Manjaro on my sample boards lately, and they could not boot for some reason…I’m still investigating this.
Hello Yuntian,
maybe I can help out here. I had this issue also. In my case the bootloader seems to try to boot from an older boot partition, that is no longer on the card. Maybe that’s your issue too. You need to modify one particular file from rescue mode and remove one line with the old partition there. Unfortunately I don’t know the filename anymore.
Maybe this helps you out.
could you try this?
Check latest Armbian images. They have been recreated two days ago, but can’t 100% confirm if they work as don’t have this hardware. Waiting for confirmation from our maintainer Radxa Zero - Armbian … but its worth trying.
Hello Naoki,
sry for the late answer. This works for me :+1:
Thank you very very much for finally getting this to work.
Unfortunately it is still not included in the newest manjaro-image as I’m writing this.
