I have the Radxa Zero 2 Pro with 16gb eMMC. I am trying to install linux to the eMMC from my windows PC. The erase guide online says to hold the boot button and plug the usb-c into my PC to start the bootloader and use RZ USB Helper Tool to load a bin file. But I cannot tell if my zero2 is in the correct boot mode. I have used the Zadig driver tool to install the libusb-win32 driver, and if I just plug it in normally to the power usb port closest to the edge of the board, I can see the GX-CHIP in the Windows Device manager. It doesn’t seem to matter which button I hold. The zero2 has a constant red light, and when i hit Run the RZ Helper Tool, it shows successful, but there is no activity on the zero2
Hi, you can refer to this wiki page to flash the image
Thank you so much!
