My first try to boot new Radxa zero 1GB V1.51 to boot was not sucessful.
Image file: radxa-zero-ubuntu-focal-server-arm64-20220801-0346-mbr.img.xz
Serial log from Putty:
G12A:BL:0253b8:61aa2d;FEAT:E0F83180:2000;POC:F;RCY:0;EMMC:800;NAND:81;SD?:0;SD:0;READ:0;0.0
l2_stage_init 0x01
bl2_stage_init 0x81
hw id: 0x0001 - pwm id 0x00
bl2_stage_init 0xc0
bl2_stage_init 0x02no sdio debug board detected
L0:00000000
L1:00000703
L2:00008067
L3:04000000
S1:00000000
B2:00002000
B1:e0f83180TE: 204558
Board ID = 2
Set cpu clk to 24M
Set clk81 to 24M
CPU clk: 1200 MHz
Set clk81 to 166.6M
board id: 2
Load FIP HDR from SD, src: 0x00010200, des: 0xfffd0000, size: 0x00004000, part: 0
fw parse done
Load ddrfw from SD, src: 0x00060200, des: 0xfffd0000, size: 0x0000c000, part: 0
Load ddrfw from SD, src: 0x00038200, des: 0xfffd0000, size: 0x00004000, part: 0
PIEI prepare done
fastboot data load
fastboot data verify
verify result: 266
LPDDR4 probe
ddr clk to 792MHz
Load ddrfw from SD, src: 0x0003c200, des: 0xfffd0000, size: 0x0000c000, part: 0dmc_version 0000
Check phy result
1D training failed
LPDDR4 probe
ddr clk to 792MHz
Check phy result
INFO : End of CA training
INFO : End of initialization
Check phy result
Check phy result
1D training succeed
Load ddrfw from SD, src: 0x00048200, des: 0xfffd0000, size: 0x0000c000, part: 0
Check phy result
INFO : Training has run successfully!channel==0
RxClkDly_Margin_A0==236 ps 12
TxDqDly_Margin_A0==256 ps 13
RxClkDly_Margin_A1==0 ps 0
TxDqDly_Margin_A1==0 ps 0
TrainedVREFDQ_A0==74
TrainedVREFDQ_A1==0
VrefDac_Margin_A0==30
DeviceVref_Margin_A0==40
VrefDac_Margin_A1==0
DeviceVref_Margin_A1==0channel==1
RxClkDly_Margin_A0==256 ps 13
TrainedVREFDQ_A1==0
DeviceVref_Margin_A1==0dwc_ddrphy_apb_wr((0<<20)|(2<<16)|(0<<12)|(0xb0):0004
soc_vref_reg_value 0x 00000018 00000019 0000001a 0000001b 0000001a 0000001a 00000018 0000001b 00000019 0000001a 0000001a 0000001c 0000001d 0000001a 0000001c 0000001a 00000019 0000001a 0000001c 0000001a 0000001b 00000018 0000001b 0000001b 00000018 00000019 0000001a 00000018 00000019 00000018 0000001b 0000001c dram_vref_reg_value 0x 00000062
2D training succeed
auto size-- 65535DDR cs0 size: 1024MB
DDR cs1 size: 0MB
DMC_DDR_CTRL: 00c0002bDDR size: 1024MB
cs0 DataBus test pass
cs0 AddrBus test pass100bdlr_step_size ps== 478
result report
Load FIP HDR from SD, src: 0x00010200, des: 0x01700000, size: 0x00004000, part: 0
Load BL3X from SD, src: 0x0006c200, des: 0x0175c000, size: 0x000ec000, part: 0
0.0;M3 CHK:0;cm4_sp_mode 0
MVN_1=0x00000000
MVN_2=0x00000000
OPS=0x30
ring efuse init
28 0c 30 00 01 17 0e 00 00 06 35 38 37 43 46 50
[0.017149 Inits done]
secure task start!
high task start!
low task start!
run into bl31
NOTICE: BL31: v1.3(release):4fc40b1
NOTICE: BL31: Built : 15:57:33, May 22 2019
NOTICE: BL31: G12A normal boot!
ERROR: Error initializing runtime service opteed_fastU-Boot 2021.07-24136-g50c984a15b (Jun 28 2022 - 21:00:58 +0800) radxa-zero
Model: Radxa Zero
SoC: Amlogic Meson G12A (S905Y2) Revision 28:c (30:2)
DRAM: 1 GiB
MMC: sd@ffe03000: 0, sd@ffe05000: 1, mmc@ffe07000: 2
Loading Environment from nowhere… OK
In: serial
Out: serial
Err: serial
Net: Net Initialization Skipped
No ethernet found.
starting USB…
Starting the controller
USB XHCI 1.10
scanning bus usb@ff500000 for devices… 1 USB Device(s) found
scanning usb for storage devices… 0 Storage Device(s) found
Any ideas and help are welcome, thanks!
Michael
