I`ve got a question regarding Radxa X4. Will this board work with a battery voltage ranging from 11 to 13 volts?
Is there a specification for what the power supply for this 12-volt board should be?
Thanks,
Andrew
Thanks,
Andrew
Hello friend
X4 can work with battery voltage ranging from 11 to 13 volts, current >=2.5A
Radxa X4 recommends using a power adapter that supports the USB Type-C PD protocol (supports 12V and the current >= 2.5A under 12V), but it does not support the Qualcomm QC protocol.
Radxa recommends using Radxa Power PD30W.
Radxa X4开发板,
如果把供电电压降低到两串锂电池组,供电电压降低到6V—8.4V范围,供电峰值电流5A,可以驱动板子正常工作吗?
Radxa X4需要9v以上才能工作
