RADXA X4 Intel N100 boot From USB
Great day to all the community members.
I would like to know if it is bossible to boot from a USB. I usualy boot from USB an iso image that burn the OS automaticly on the ssd/eMMC.
Some BIOS settings don’t persist when set to always boot from USB, requiring manual selection each time the USB is connected. Does the X4 support persistent booting from USB without the need to reconfigure the BIOS each time?
I saw in one of the posts an image of the bios and it looked similar to Odroid bios which doesnt support USB boot persistant. I hope its the case with X4.
Thank you for your wisdom sharing.
Hello friend, X4 support boot from USB, and support multiple operating systems
For USB boot persistent, connect bootable USB disk, RTC battery, boot into bios by del key, goto Boot page, set the boot option #1 your UEFI USB disk, F4 to save the changes. it should be work for everytime power on.
i was only able to install windows to m.z and emmc not the USB and make it boot
https://www.youtube.com/watch?v=uiYRR7ERvmA&t=354s
Windows can not install to USB disk directly, you need make it by WTG. FYI
