So I’m gonna try to make a proper easy tidy forum post about my experience on this board with off course as usual cloud gaming in mind ChromeOS Flex and who knows.. maybe SteamOS with Bazzite for it despite its limitations for what it can be possible.
Bazzite is interesting because its the closest to what valve is providing on SteamOS so you can pretty much install anything that you can on steam deck into your linux using bazzite it is optimised and mantained by the community that follows valve so its redirected for gaming.
radxa is sleeping for long time… even the x2l cooler must bee better than the cooler from x4… use a Radxa 8418B heatsink with big base… There is nothing to inovate… just use a laptop heatsink…
Not needed. And even if I did… it wouldnt solve the fact I need a shell protecting its components. But its indeed a good suggestion for a proper heatsink fan.
Sorry for the late reply due to the Chinese Spring festival holiday.
We will use embedded copper sheets to replace thermal conductive silicone to improve heat dissipation. The next batch of heatsink will be imported, and we will update the instructions at the same time.
FYI: Here is sample pic and comparison results
