Radxa Rock 5B OS
The installation of Debian Bullseye kde b39 on the Radxarock 5b, there is an infinite boot loop issue.
How can we solve this issue.
The last command lines looks like:
The root filesystem on /dev/mmcbIk1p3 requires a manual fsck
(initramfs)
Install armbian or Joshua Riek’s Ubuntu
Then try this manual fsck :smiley:
fsck /dev/mmcblk1p3
Did you try any other images?
no we didn’t.
Only debian different versions
I am using windows to flash the image into the SD card. Will there be any problem because of this?
we tried this manual fsck
but its not working. Is tehre any other alternatives
Did you buy one of these 256 TB flash drives to store your image? :smiley: I would try different storage medium first. I installed b39 two weeks ago without problems (for hdmi-in and 4k-camera). Is the bootloop before or after apt update / upgrade?
you may try to compile your own image through the scripts in radxa official repo
