Thank you - will give it a go. But I can’t see any activity in that GitHub repo? I guess you made changes to the AIC8800 WiFi / BLE driver and firmware, I want to look into it and see if I can patch it for the Radxa Zero3W which ships with the same WiFi / BLE chip too.
I can confirm the official images are working both WiFi and Bluetooth.
But the AIC8800 WiFi chip does not work with my Unifi AP U6-LR which has WiFi 6. It’s fairly well documented that the Unifi WiFi 6 APs do not work with certain WiFi6 client chips and the behaviour is strange: It can ping both internal IP and Internet IP, but it does not sustain the connection, but it will not disconnect. I cannot even ssh to my board.
But I do not have another WiFi 6 AP / router to test if AIC8800 works with another WiFi
I have found if you do a direct connect to your network and do a complete update the wireless connection will begin to work. You can get then unplug the wired connection. I did this o n two 4C+s.
