Yes, 3.5 drives are supported via extension sata cables and there was also external cage available for those. Obviously 3.5 drives won’t fit directly into board like 2.5 can.
Here is photo from wiki:
You can use molex to sata power connector from board. Also there is one extra esata port for 3.5 drive.
The Radxa Penta SATA HAT can use 3.5-inch hard disks. And we have updated the power selection section of the usage document[1] to help users choose the right power supply mode.
I checked the specifications[2] for the WD84PURZ and I couldn’t find its peak current, so I wasn’t quite sure it would work with the Penta SATA HAT.
We generally recommend that users use a hard disk with a peak current of less than 1.8A, and a hard disk with a capacity of less than 12T on the market will generally have a peak current of less than 1.8A.
The average read/write power consumption of the WD84PURZ is relatively low, and I suspect its peak current will not be very high.
But You don’t need to limit yourself to this particular one, almost any sata backplane and cage should work. Browse local market for server components and You will find more cheap (4 bays) options (great for quat sata hat) and for penta sata hat if You are using fifth drive somewhere.
