The latest official Radxa OS I could find is this one, which is based on Debian Bullseye. However, in the official documentation, I noticed that they run grep VERSION_CODENAME /etc/os-release and get VERSION_CODENAME=bookworm .
This suggests that Debian Bookworm might also be officially supported. Of course, it’s possible to modify APT sources and perform a distro upgrade manually, but I’m curious to know if there is official support for Debian 12 (Bookworm) on the Radxa Zero 3W.
Which one have you tests? I can see t1/t2/t3. which of them is more stable? and when will the next stable relesse be published? @Nasca Any changes to Q2 plan?
The latest version only supports full Desktop build. What happened to the CLI?
Also, why there’s no option to build the image from source? We need to customize the OS to the bare minimum for a a Single Application setup, however, is practically impossible.
We have tried other options, like Armbian, but there’s no room for customization. We also tried buildroot (our best best) but it doesn’t work specifically with zero-3W. @Nasca Is there any repository for the source?
It is an absolute pain to build this. I would expect a similar setup to other boards using buildroot, but not.
We followed your steps, but first, downloading from mega.nz requires you to either pay or way for 15 hours to download it
Second, you need an old version of linux, or tweak it so it allows using python2. (which was removed in 2020) Otherwise it will not build.
The error shows specifically in the mk-loader.sh: “Lots scripts in u-boot require python2”
