A ticket is being created based on the email correspondence with Ivy
Primary Issue: Display not working.
Display: Radxa Display 10FHD
AD003N-V1000
20230809400
SBC: RockPi 4B+
Compatibility ref: RADXA Display 10 FHD – ALLNET China
OS:
root@rock-pi-4b-plus:/home/rock# cat /etc/os-release
PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
NAME="Debian GNU/Linux"
VERSION_ID="11"
VERSION="11 (bullseye)"
VERSION_CODENAME=bullseye
ID=debian
HOME_URL="https://www.debian.org/"
SUPPORT_URL="https://www.debian.org/support"
BUG_REPORT_URL="https://bugs.debian.org/"
Kernel:
rock@rock-pi-4b-plus:~$ uname -a
Linux rock-pi-4b-plus 5.10.110-35-rockchip #5db04e2aa SMP Fri Apr 26 10:03:46 UTC 2024 aarch64 GNU/Linux
Update state:
rock@rock-pi-4b-plus:~$ sudo apt full-upgrade
Reading package lists... Done
Building dependency tree... Done
Calculating upgrade... Done
The following package was automatically installed and is no longer required:
yq
Use 'sudo apt autoremove' to remove it.
The following packages will be DOWNGRADED:
libdvbv5-0 libv4l2rds0 libv4lconvert0
0 upgraded, 0 newly installed, 3 downgraded, 0 to remove and 0 not upgraded.
Need to get 0 B/380 kB of archives.
After this operation, 0 B of additional disk space will be used.
rock@rock-pi-4b-plus:~$ cat /boot/hw_intfc.conf
# hw_intfc.conf has been retired.
# Please use `rsetup` command to confiure device overlays.
rsetup overlay:
dmesg
rock@rock-pi-4b-plus:~$ sudo dmesg | grep FTS
[ 72.711341] [FTS][Info]display x(0 799) y(0 1279)
[ 72.711422] [FTS][Error]Unable to get max-touch-number
[ 72.711693] [FTS][Info]max touch number:10, irq gpio:154, reset gpio:156
[ 72.950168] [FTS][Error][IIC]: i2c_transfer(write) error, ret=-6!!
... 50 times ...
[ 74.079950] [FTS][Info]fw is invalid, need read boot id
[ 74.080237] [FTS][Error]fts_i2c_write: i2c_transfer(write) error, ret=-6
[ 74.087686] [FTS][Error]fts_i2c_write: i2c_transfer(write) error, ret=-6
[ 74.095022] [FTS][Error]fts_i2c_write: i2c_transfer(write) error, ret=-6
[ 74.101602] [FTS][Error]start cmd write fail
[ 74.107953] [FTS][Error]not focal IC, unregister driver
Connections:
(I have checked the Flex cable connection multiple times.)
