So
-Linux radxa-cubie-a7z 5.15.147-14-a733 #14 SMP PREEMPT Mon Jan 19 10:03:49 UTC 2026 aarch64 GNU/Linux
-kde
- did and done, first thing i did and installing the overlays for the camera.
-Pretty much the cmd given, such has : gst-launch-1.0 v4l2src device=/dev/video1 io-mode=dmabuf num-buffers=10 ! video/x-raw,format=NV12,width=1920,height=1080 ! videoconvert ! jpegenc ! filesink location=~/test.jpg
and some variant of it. Resulting to the same issue.
for example :
radxa@radxa-cubie-a7z:~$ DISPLAY=:0 GST_DEBUG_FILE=log.txt GST_DEBUG=4 gst-launch-1.0 v4l2src device=/dev/video0 en-awis
p=1 en-largemode=1 ! video/x-raw,format=NV12,width=3840,height=2160,framerate=24/1 ! xvimagesink
Setting pipeline to PAUSED …
Pipeline is live and does not need PREROLL …
Pipeline is PREROLLED …
Setting pipeline to PLAYING …
New clock: GstSystemClock
[ISP]>>>>>>>>>>>>>>>>>>>> ISP VERSION INFO <<<<<<<<<<<<<<<<<<<
IPCORE: ISP602
branch: libisp-dev
commit: 665dc2e9613716c25abb6b64af145a73b989271e
date : Wed Dec 18 15:26:13 2024 +0800
author: [email protected]
[ISP]video device name is vin_video0
[AWIspApi]: F:awIspGetIspId, L:104, video0 → isp0
[ISP]STITCH_2IN1_LINNER
[ISP]ISP Set Sync Mode = 0x3, isp_sync_mode = 0x20003
And it hangs there.
Or by running it via the rsetup to test video0
(gst-plugin-scanner:8035): GLib-GObject-WARNING **: 12:59:27.194: cannot register existing type ‘GstRtpSrc’
(gst-plugin-scanner:8035): GLib-GObject-CRITICAL **: 12:59:27.195: g_type_add_interface_static: assertion ‘G_TYPE_IS_INSTANTIATABLE (instance_type)’ failed
(gst-plugin-scanner:8035): GLib-CRITICAL **: 12:59:27.195: g_once_init_leave: assertion ‘result != 0’ failed
(gst-plugin-scanner:8035): GStreamer-CRITICAL **: 12:59:27.195: gst_element_register: assertion ‘g_type_is_a (type, GST_TYPE_ELEMENT)’ failed
(gst-plugin-scanner:8035): GLib-GObject-WARNING **: 12:59:27.195: cannot register existing type ‘GstRtpSink’
IPCORE: ISP602
branch: libisp-dev
