Radxa Cubie A7A , Radxa 13M 214 Camera
I have the radxa Cubie A7A device and a Radxa 13M 214 Camera.
I have turned on the corresponding overlays on rsetup for the camera.
and ran the commands to capture a picture or video and never succeed.
I do not know what I am not doing in order to make it work.
see the following text
"radxa@radxa-cubie-a7a:~$ gst-launch-1.0 v4l2src device=/dev/video11 io-mode=4 ! videoconvert ! video/x-raw,format=NV12,width=1920,height=1080 ! xvimagesink
Setting pipeline to PAUSED …
ERROR: from element /GstPipeline:pipeline0/GstXvImageSink:xvimagesink0: Could not initialise Xv output
Additional debug info:
…/sys/xvimage/xvimagesink.c(1788): gst_xv_image_sink_open (): /GstPipeline:pipeline0/GstXvImageSink:xvimagesink0:
Could not open display (null)
ERROR: pipeline doesn’t want to preroll.
Failed to set pipeline to PAUSED.
Setting pipeline to NULL …
Freeing pipeline …
radxa@radxa-cubie-a7a:~$"
I do not know what I am missing, in order to make this work.
please help.
I want to tell you a bad news. Radxa hasn’t pass the the Radxa 13M 214 test on A7A. The official online store service told me this. It is too ridiculous.
Try this:
# imx214
DISPLAY=:0 gst-launch-1.0 v4l2src device=/dev/video1 en-awisp=1 en-largemode=1 ! video/x-raw,format=NV12,width=4208,height=3120,framerate=24/1  ! xvimagesink
# imx219
DISPLAY=:0 gst-launch-1.0 v4l2src device=/dev/video0 en-awisp=1 en-largemode=0 ! video/x-raw,format=NV12,width=3280,height=2464,framerate=24/1  ! xvimagesink
# imx415
DISPLAY=:0 gst-launch-1.0 v4l2src device=/dev/video1 en-awisp=1 en-largemode=1 ! video/x-raw,format=NV12,width=3840,height=2160,framerate=24/1  ! xvimagesink
What version of gstreamer you use? Version included in official image don1t support en-awisp=1 en-largemode=1 parameters.Whre can I found yours version of gstreamer?
You can try our latest image. As for the version issue you mentioned, simply install gstreamer1.0-tools in our system.
Image link:
https://github.com/radxa-build/radxa-cubie-a5e/releases/download/rsdk-t8/radxa-cubie-a5e_bullseye_kde_t8.output_512.img.xz
Ok ,but I use radxa A7Z A733.
I’ve also tried to run 13M imx214 camera with A7Z a733 board. I’ve tried various system images and about two images that would get some image from the sensor.
The best image so far has proven to be https://github.com/radxa-build/radxa-a733/releases/download/rsdk-t2/radxa-a733_bullseye_cli_t2.output_512.img.xz .
Saving a still frame (or video) from the camera results with an image that seems to have two issues:
  • incorrect color encoding; NV12 produces near B/W image with some coloration and slight ghosting. I’m getting parts of the image correct when using BGR option, but
  • then 2nd issue comes in where picture doesn’t seem to be well syncronised; part of picture cut vertically.
NV12 picture:
$ gst-launch-1.0 v4l2src device=/dev/video1 en-awisp=1 en-largemode=1 ! video/x-raw,format=NV12,width=4208,height=3120 ! jpegenc ! multifilesink location=file4.jpg
Pipeline is live and does not need PREROLL …
Pipeline is PREROLLED …
Setting pipeline to PLAYING …
New clock: GstSystemClock
[ISP]>>>>>>>>>>>>>>>>>>>> ISP VERSION INFO <<<<<<<<<<<<<<<<<<<
IPCORE: ISP602
branch: libisp-dev
commit: 665dc2e9613716c25abb6b64af145a73b989271e
date : Wed Dec 18 15:26:13 2024 +0800
author: [email protected]
[ISP]video device name is vin_video1
[AWIspApi]: F:awIspGetIspId, L:104, video1 → isp1
[ISP]STITCH_2IN1_LINNER
[ISP]ISP Set Sync Mode = 0x3, isp_sync_mode = 0x20003
[ISP]tdm_rx device name is sunxi_tdm_rx.0
[ISP]open isp device[0] success!
[ISP]get isp_ctx from /mnt/isp1_4208_3120_2_0_imx214_ctx_saved.bin success!!!
[ISP_WARN]cannot find imx214_4208_3120_2_0_0 isp config, use imx214_mipi_4208_3120_30_0_0 → [imx214_mipi_default_ini_a733]
[ISP]create isp0 server thread!
[ISP]tdm_rx device name is sunxi_tdm_rx.1
[ISP]open isp device[1] success!
[ISP_WARN]VIDIOC_VIN_GET_SENSOR_OTP_INFO return error:Invalid argument
[ISP]ISP1 OTP Disable
[ISP_ERR]isp_dev_start, line: 717,unable to subscribe to tdm event: Inappropriate ioctl for device (25).
[ISP]create isp1 server thread!
[ISP_ERR]isp_stat_process_buffer, line: 265,AEWB: stats error, skipping buffer.
[ISP_WARN]imx214 get sensor_flip failed: Invalid argument (22).
[ISP_WARN]imx214 get sensor_temp failed: Invalid argument (22).
[ISP_ERR]isp_sync_debug_info, line: 857,VIDIOC_VIN_ISP_GET_INFO error!
[ISP_WARN]isp debugfs node not support!!!
[ISP_WARN]can not use sync mode.(buffer0 = 0xffffb0045110, buffer1 = (nil))
handling interrupt.:99.
Interrupt: Stopping pipeline …
Execution ended after 0:00:03.924666631
[ISP_ERR]isp_ctx_save_exit, line: 125,open /mnt/isp1_4208_3120_2_0_imx214_ctx_saved.bin failed, err:Permission denied.
Freeing pipeline …
BGR picture:
$ gst-launch-1.0 v4l2src device=/dev/video1 en-awisp=1 en-largemode=1 ! video/x-raw,format=BGR,width=4208,height=3120 ! jpegenc ! multifilesink location=file5.jpg
What can we do, what debug info, etc would you need to get this resolved?
I’d appreciate developers help here, especially as 13M 214 camera is sold as supported.
Kind regards
does it worked now?
I have same issue
Hi. It still doesn’t afaik.
Issue lays in the ISP (image signal processor unit) drivers…
I also bought this camera and I’m also experiencing artifacts on the A5e board. Is there a working solution for getting a normal image?
Are you saying that the photos taken through the camera have incorrect colors? Is it okay to directly capture the camera’s preview effect? First, please refer to the example in our official documentation: Radxa Camera 13M 214 | Radxa Docs
exp:
