请问一下CM5是否支持waveshare的CM4-IO-BASE-A或者B?我有一个CM4-IO-BASE-A地板,我想购买一个CM5来兼容,只需要保证USB HDMI 以及网口工作即可,
Yes, the radxa-cm5-rpi-cm4-io image is compatible with raspberry pi cm4 io board as well as the waveshare boards
好的,谢谢你的回复
我实际测试发现USB和SD卡可以正常识别到,但是HDMI并没有输出 ,使用的镜像是
radxa-cm5-rpi-cm4-io_bookworm_kde_b3.output.img
我是那一步出问题了吗
请问你的 CM5 核心板是什么硬件版本?
What is your CM5 hardware version?
The hardware silk screen says CM5 V2.21
Found the problem,
153PIN, network HDMI_TX0_HPD_M0, the core board has a pull-down resistor, and some HDMI screens cannot pull up because the resistor is too large, causing the HDMI_TX0_HPD_M0 voltage to be too low, and the core or screen cannot recognize it.
https://www.waveshare.com/wiki/CM5-NANO-B
They just released an upgrade:
This is a Raspberry Pi CM5, not a Radxa CM5.
Its for the raspberry pi 5 but works with the radxa cm5.
This helped. My cheap 10" display got no output, but plugged into my 27" Dell monitor then walla!
