Using the Radxa OS image provided, the USB ports don’t seem to be working. Using lsusb provides:
Bus 006 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 005 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
This responses doesn’t change with items (USB hub, keyboard, mouse, etc) being plugged into the ports.
Is there a driver I need to activate to get the ports working as USB Hosts?
I’ve tried both options (independently and together) but they do not seem to be configuring the port to HOST mode.
Is there a different setting in rsetup that I am missing?
Install the rock 5C image on CM5 it works with usb.
Also the cm5-rpi-cm4-io image also has usb support.
The only ‘retardness’ that doesnt has usb working is the cm5-io because its meant for the oficial radxa carrier board I assume… but for the cm4 nano for example… u need the rpi-cm4 image.
Now idk if this your case… but… maybe im not helping.
