Hi everyone,
I’m trying to add eMMC storage to my Radxa A7S by reusing an eMMC chip desoldered from an Orange Pi eMMC Module 64 (part number: ISOCOM MEMDN064G, 64GB).
What happened:
After soldering the eMMC chip onto the Radxa A7S, the board completely stopped functioning and was drawing less than 1mA of current! As soon as I desoldered the chip again, the board returned to normal operation and current draw immediately.
My questions:
- Is the Orange Pi eMMC Module 64 (ISOCOM MEMDN064G) actually compatible with the Radxa A7S eMMC footprint/interface?
- Could the near-zero current draw indicate a short, incorrect pinout alignment, or an incompatible eMMC spec (e.g., voltage, bus width, or timing)?
- Are there any specific things I should keep in mind before attempting to resolder — such as voltage levels (1.8V vs 3.3V), bus width configuration, or required pull-up resistors?
Regarding unpopulated components:
The official Radxa A7S documentation mentions that components near the eMMC footprint are not populated by default. However, I couldn’t locate any unpopulated footprints on my board — everything in that area appears to already be populated. Did I miss something, or is it possible the board revision I have ships with those components already placed? I only soldered the eMMC chip itself and did not add any other components.
Any guidance would be greatly appreciated. Thanks!
