Setting pipeline to PLAYING …
ERROR: from element /GstPipeline:pipeline0/GstV4l2Src:v4l2src0: Internal data stream error.
New clock: GstSystemClock
Additional debug info:
…/libs/gst/base/gstbasesrc.c(3127): gst_base_src_loop (): /GstPipeline:pipeline0/GstV4l2Src:v4l2src0:
streaming stopped, reason not-negotiated (-4)
Execution ended after 0:00:00.002009663
Setting pipeline to NULL …
Freeing pipeline …
[video4linux2,v4l2 @ 0xaaaafd953100] ioctl(VIDIOC_G_INPUT): Inappropriate ioctl for device
[video4linux2,v4l2 @ 0xaaaafd953100] ioctl(VIDIOC_G_PARM): Inappropriate ioctl for device
[video4linux2,v4l2 @ 0xaaaafd953100] Time per frame unknown
If i use your suggested resolution it hangs here, 4k will continue…
Duration: N/A, start: 29145.357268, bitrate: N/A
Stream #0:0: Video: rawvideo (I420 / 0x30323449), yuv420p, 3840x2160, 1000k tbr, 1000k tbn
[out#0/flv @ 0xaaab0cd6c6b0] Codec AVOption preset (Set the encoding preset (cf. x264 --fullhelp)) has not been used for any stream. The most likely reason is either wrong type (e.g. a video option with no video streams) or that it is a private option of some encoder which was not actually used for any stream.
Stream mapping:
Stream #0:0 -> #0:0 (rawvideo (native) -> h264 (h264_rkmpp_encoder))
Press [q] to stop, [?] for help
[h264_rkmpp_encoder @ 0xaaab0cd6d1d0] Picture format is yuv420p.
[h264_rkmpp_encoder @ 0xaaab0cd6d1d0] Rate Control mode is set to VBR
[h264_rkmpp_encoder @ 0xaaab0cd6d1d0] Bitrate Target/Min/Max is set to 8000000/500000/8500000
[h264_rkmpp_encoder @ 0xaaab0cd6d1d0] Profile is set to HIGH
[h264_rkmpp_encoder @ 0xaaab0cd6d1d0] 8x8 Transform is enabled
[h264_rkmpp_encoder @ 0xaaab0cd6d1d0] Level is set to 30
[h264_rkmpp_encoder @ 0xaaab0cd6d1d0] Coder is set to CABAC
[h264_rkmpp_encoder @ 0xaaab0cd6d1d0] Quality Min/Max is set to 50%(Quant=30) / 100%(Quant=10)
Have you tried to run apt update && apt upgrade ? Radxa released new IQ files in the beginning of September and they contain 4k resolution. The previous version didn’t contain it so 4k didn’t work.
Hi, can you help me with Radxa 3W mpp && rockchip media please? What is OS version for Radxa are you using? I’m starting with Debian last release and it have not support of mpph264enc.
