U-Boot 2022.07-meson-g12a (Aug 14 2022 - 18:04:01 +0300) radxa-zero
Model: Radxa Zero
SoC: Amlogic Meson G12A (S905Y2) Revision 28:b (30:2)
DRAM: 3.8 GiB
Core: 383 devices, 23 uclasses, devicetree: separate
MMC: sd@ffe03000: 0, sd@ffe05000: 1, mmc@ffe07000: 2
In: serial
Out: serial
Err: serial
Net: No ethernet found.
switch to partitions #0, OK
mmc2(part 0) is current device
Scanning mmc 2:1...
8023 bytes read in 2 ms (3.8 MiB/s)
## Executing script at 08000000
138 bytes read in 2 ms (67.4 KiB/s)
73912 bytes read in 5 ms (14.1 MiB/s)
26851840 bytes read in 612 ms (41.8 MiB/s)
libfdt fdt_getprop(): FDT_ERR_NOTFOUND
Mainline bootargs: root=UUID=20fc45b9-13a3-41a3-9991-ff9a3f8af0b5 ro rootwait rootfstype=ext4 init=/sbin/init console=ttyAML0,115200n8 console=tty1 consoleblank=0 coherent_pool=2M loglevel=4 usb-storage.quirks=
232 bytes read in 3 ms (75.2 KiB/s)
Applying kernel provided DT fixup script (meson-fixup.scr)
## Executing script at 32000000
2984705 bytes read in 70 ms (40.7 MiB/s)
## Loading init Ramdisk from Legacy Image at 13000000 ...
Image Name: uInitrd
Image Type: AArch64 Linux RAMDisk Image (gzip compressed)
Data Size: 2984641 Bytes = 2.8 MiB
Load Address: 00000000
Entry Point: 00000000
Verifying Checksum ... OK
## Flattened Device Tree blob at 04080000
Booting using the fdt blob at 0x4080000
Loading Ramdisk to 3fd27000, end 3ffffac1 ... OK
Loading Device Tree to 000000003fcac000, end 000000003fd26fff ... OK
Starting kernel ...
[ 0.979286] genirq: Setting trigger mode 3 for irq 17 failed (meson_gpio_irq_set_type+0x0/0x60)
[ 12.082179] panfrost ffe40000.gpu: error -ENODEV: dev_pm_opp_set_regulators: no regulator (mali) found
[ 12.156679] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43456-sdio for chip BCM4345/9
[ 12.443126] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43456-sdio for chip BCM4345/9
[ 12.499190] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/9 wl0: Feb 11 2020 11:54:51 version 7.45.96.61 (be7af2d@shgit) (r745790) FWID 01-a41d86bd es7.c5.n4.a3
CRUX-ARM 64b (radxa-zero) (ttyAML0)
radxa-zero login:
