Radexa Camera 4K only 1080p resolution on Rock5ModelB
Hello I have two Rock 5B and 2 Radxa Camera 4K.
Unfortunately none of the camera works.
I have done all the steps as in the wiki. (https://wiki.radxa.com/Rock5/hardware/camera/)
OS used: Debian 11 from Radexa
ls /dev/video* shows the video11 device.
v4l2-ctl --device /dev/video11 --list-formats-ext
does not show the same resolutions as linked in the following forum (How to use Radxa Camera 4K)
If no camera is connected the command
v4l2-ctl --device /dev/video11 --list-formats-ext gives the same result.
When I run the command to launch the camera ( gst-launch-1.0 v4l2src device=/dev/video11 ! video/x-raw,format=NV12,width=3840,height=2160, framerate=30/1 ! xvimagesink ) the following error message appears:
I think the camera is connected correctly. The Radexa camera even has a line on the ribbon cable connector. Thanks for the help.
I got the camera to work by selecting the video device 12. unfortunately, the maximum resolution displayed is 1920 x 1080 and not the 4k resolution that the camera should have. The output of the resolution of Video Device 11 is unchanged
Interesting.
Can you try /dev/video11 with the resolution shown in your output?
Also, can you save the output to a text file instead of a print screen?
Please, type in a command line:
sudo dmesg|grep -i imx
Try this one:
sudo dmesg|grep -i ov
16-megapixel (4672 x 3504 pixels)
dmegs-output.zip (1.3 KB) thank you for the quick reply.
Dev Video11 also works with the Fullhd resolution.
I have once increased the resolution to 4k in dev video11 that also worked.
The command also works gst-launch-1.0 v4l2src device=/dev/video11 ! video/x-raw,format=NV12,width=4672,height=3504, framerate=30/1 ! xvimagesink
i will see only a preview image and no video this is surely intended i guesslist-formats-ext.zip (580 Bytes)
Thanks for the help. My problem is solved.
