Another newbie here trying to power a Rock 5B+ via PoE. According to the documentation, the 5B+ requires around 40W , which is noticeably more than the standard Rock 5B that works fine with 25W .
Regarding IEEE PoE standards, here’s what we have:
802.3af – up to ~15W (definitely not enough)
802.3at (PoE+) – up to 25W
802.3bt (PoE++) – goes above 60W
So clearly, I’ll need a PoE+ or PoE++ compatible switch or injector that can meet the higher power requirements. The issue is, the existing PoE HAT seems to be designed specifically for the Rock 5B and may not be sufficient for the 5B+. On top of that, it’s currently out of stock — so if I manage to get one, I might even need to consider a DIY upgrade.
Since I’m still new to PoE, I had a few questions:
Why isn’t there a more generic PoE HAT or module that can tap into the 4 standard PoE pins and provide higher power output — kind of like how PoE splitters work?
I’ve browsed AliExpress for generic PoE boards, but haven’t had much luck finding anything suitable for this use case.
I also came across these two official Radxa PoE HATs:
They seem to offer similar power specs, so I’m also curious: Why can’t the same HAT be used across both the X4 and the Rock 5B/5B+? Are there hardware differences (e.g. pin layouts, power delivery paths) that require separate designs?
Any insights or recommendations for powering the Rock 5B+ over PoE — including any community projects, generic solutions, or tips for DIY options — would be super helpful.
Why would Rock 5B+ require 40 watts? The CPU is the same, there aren’t any differences between them significant enough to require 40 watts… I wonder what Radxa says.
…plus built in wifi, ddr5, extra mipi and for some soldered eMMC.
probably bare board would not take so much extra energy, but for sure more is needed with two nvme drives and more ports.
Well, I thought that DDR5 was supposed to be more power efficient. And I doubt you need more than 25W if using just 1 NVME SSD (still, going above 25W is quite difficult on this board)
At same time it should be clocked higher than DDR4 and for sure more power efficient if there is right support. ASAP for now no real performance gain
My Rock 5B idles at 1.5W with both m.2 slots occupied. On high load I saw up to 14W and I’m sure I can get even more with something in USB ports. Higher estimate for 5B+ seems to be reasonable, that doesn not mean it will not run on previous POE, it would be just easier to hit the limit.
What is the exact difference between the 25W PoE HAT and the one designed for the X4? Is the X4 version compatible with the 5B+? Since the 25W PoE HAT is out of stock, can I use the X4 version to power a 5B+?
Thanks!
Just out of curiosity, how does the original HAT know whether to output 5V or 12V? The documentation mentions that the voltage is selected based on the load. Does that mean the board measures something like impedance to make this decision?
Also, as far as I know, the Rock 5B Plus only accepts 5V as input, not 12V. So, does the X4 HAT provide both 5V and 12V outputs simultaneously(pin header output is always 12V), like using two buck converters? It seems like the header always provides 12V, so what happens to the 5V output in that case?
For the X4, I could not find any schematic for the original version. I checked here:
and I got more confused. Apparently, we create 5V with a step down from 12V which is fine, but what I don’t understand is “Shouldn’t we have another step down for POE?”, for example from 40 to 50V down to 12V?
