No problem! And thanks for taking a look!
sudo dmesg
[ 0.000000] Linux version 4.19.118-v7l+ (dom@buildbot) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611)) #1311 SMP Mon Apr 27 14:26:42 BST 2020
[ 0.000000] OF: fdt: Machine model: Raspberry Pi 4 Model B Rev 1.2
[ 0.000000] cma: Reserved 256 MiB at 0x000000001ec00000
[ 0.000000] On node 0 totalpages: 1012736
[ 0.000000] DMA zone: 1728 pages used for memmap
[ 0.000000] HighMem zone: 816128 pages, LIFO batch:63
[ 0.000000] random: get_random_bytes called from start_kernel+0xc0/0x4e8 with crng_init=0
[ 0.000000] percpu: Embedded 17 pages/cpu s36928 r8192 d24512 u69632
[ 0.000000] pcpu-alloc: s36928 r8192 d24512 u69632 alloc=17*4096
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 1011008
[ 0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 cma=64M snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_headphones=1 cma=256M smsc95xx.macaddr=DC:A6:32:5F:7A:14 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 console=ttyS0,115200 console=tty1 root=PARTUUID=8b395f82-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Memory: 3735552K/4050944K available (8192K kernel code, 690K rwdata, 2420K rodata, 2048K init, 860K bss, 53248K reserved, 262144K cma-reserved, 3264512K highmem)
[ 0.000000] Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
vmalloc : 0xf0800000 - 0xff800000 ( 240 MB)
lowmem : 0xc0000000 - 0xf0000000 ( 768 MB)
pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
.text : 0x(ptrval) - 0x(ptrval) (10208 kB)
.init : 0x(ptrval) - 0x(ptrval) (2048 kB)
.data : 0x(ptrval) - 0x(ptrval) ( 691 kB)
.bss : 0x(ptrval) - 0x(ptrval) ( 861 kB)
[ 0.000000] ftrace: allocating 28928 entries in 85 pages
[ 0.000000] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
[ 0.000005] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
[ 0.000021] Switching to timer-based delay loop, resolution 18ns
[ 0.000255] Console: colour dummy device 80x30
[ 0.000719] console [tty1] enabled
[ 0.000772] Calibrating delay loop (skipped), value calculated using timer frequency… 108.00 BogoMIPS (lpj=540000)
[ 0.000809] pid_max: default: 32768 minimum: 301
[ 0.001092] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.001125] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.001899] CPU: Testing write buffer coherency: ok
[ 0.002328] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.002980] Setting up static identity map for 0x200000 - 0x20003c
[ 0.003156] rcu: Hierarchical SRCU implementation.
[ 0.004030] smp: Bringing up secondary CPUs …
[ 0.004853] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.005777] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[ 0.006659] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[ 0.006777] smp: Brought up 1 node, 4 CPUs
[ 0.006845] SMP: Total of 4 processors activated (432.00 BogoMIPS).
[ 0.006869] CPU: All CPU(s) started in HYP mode.
[ 0.006889] CPU: Virtualization extensions available.
[ 0.007691] devtmpfs: initialized
[ 0.018343] VFP support v0.3: implementor 41 architecture 3 part 40 variant 8 rev 0
[ 0.018569] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.018612] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.025984] pinctrl core: initialized pinctrl subsystem
[ 0.026864] NET: Registered protocol family 16
[ 0.029886] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[ 0.031419] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.031450] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.031654] Serial: AMBA PL011 UART driver
[ 0.034886] bcm2835-mbox fe00b880.mailbox: mailbox enabled
[ 0.050023] raspberrypi-firmware soc:firmware: Attached to firmware from 2020-05-11 18:59, variant start
[ 0.060040] raspberrypi-firmware soc:firmware: Firmware hash is 21bfdeee3a6ea823e2113b983390acd1eec8edfb
[ 0.102461] bcm2835-dma fe007000.dma: DMA legacy API manager at (ptrval), dmachans=0x1
[ 0.105597] vgaarb: loaded
[ 0.105975] SCSI subsystem initialized
[ 0.106189] usbcore: registered new interface driver usbfs
[ 0.106257] usbcore: registered new interface driver hub
[ 0.106339] usbcore: registered new device driver usb
[ 0.107688] clocksource: Switched to clocksource arch_sys_counter
[ 0.185666] VFS: Disk quotas dquot_6.6.0
[ 0.185767] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.185962] FS-Cache: Loaded
[ 0.186152] CacheFiles: Loaded
[ 0.186674] simple-framebuffer: probe of 0.framebuffer failed with error -12
[ 0.195915] NET: Registered protocol family 2
[ 0.196575] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes)
[ 0.196621] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.196702] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.196786] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.196922] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.196962] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.197183] NET: Registered protocol family 1
[ 0.197799] RPC: Registered named UNIX socket transport module.
[ 0.197825] RPC: Registered udp transport module.
[ 0.197847] RPC: Registered tcp transport module.
[ 0.197868] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.197896] PCI: CLS 0 bytes, default 64
[ 0.199696] hw perfevents: enabled with armv7_cortex_a15 PMU driver, 7 counters available
[ 0.201822] Initialise system trusted keyrings
[ 0.202026] workingset: timestamp_bits=14 max_order=20 bucket_order=6
[ 0.211086] FS-Cache: Netfs ‘nfs’ registered for caching
[ 0.211618] NFS: Registering the id_resolver key type
[ 0.211660] Key type id_resolver registered
[ 0.211682] Key type id_legacy registered
[ 0.211713] nfs4filelayout_init: NFSv4 File Layout Driver Registering…
[ 0.216262] Key type asymmetric registered
[ 0.216290] Asymmetric key parser ‘x509’ registered
[ 0.216413] bounce: pool size: 64 pages
[ 0.216468] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 250)
[ 0.216654] io scheduler noop registered
[ 0.216678] io scheduler deadline registered (default)
[ 0.216851] io scheduler cfq registered
[ 0.216875] io scheduler mq-deadline registered (default)
[ 0.216897] io scheduler kyber registered
[ 0.248699] brcm-pcie fd500000.pcie: dmabounce: initialised - 32768 kB, threshold 0x00000000c0000000
[ 0.248745] brcm-pcie fd500000.pcie: could not get clock
[ 0.248819] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
[ 0.248872] brcm-pcie fd500000.pcie: MEM 0x600000000…0x603ffffff -> 0xf8000000
[ 0.307718] brcm-pcie fd500000.pcie: link up, 5.0 Gbps x1 (!SSC)
[ 0.308023] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
[ 0.308054] pci_bus 0000:00: root bus resource [bus 00-01]
[ 0.308090] pci_bus 0000:00: root bus resource [mem 0x600000000-0x603ffffff] (bus address [0xf8000000-0xfbffffff])
[ 0.308153] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
[ 0.308293] pci 0000:00:00.0: PME# supported from D0 D3hot
[ 0.311049] PCI: bus0: Fast back to back transfers disabled
[ 0.311081] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 0.311303] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
[ 0.311427] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
[ 0.311744] pci 0000:01:00.0: PME# supported from D0 D3cold
[ 0.314488] PCI: bus1: Fast back to back transfers disabled
[ 0.314518] pci_bus 0000:01: busn_res: [bus 01] end is updated to 01
[ 0.314563] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
[ 0.314599] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
[ 0.314687] pci 0000:00:00.0: PCI bridge to [bus 01]
[ 0.314716] pci 0000:00:00.0: bridge window [mem 0x600000000-0x6000fffff]
[ 0.314937] pcieport 0000:00:00.0: enabling device (0140 -> 0142)
[ 0.315128] pcieport 0000:00:00.0: Signaling PME with IRQ 53
[ 0.315305] pcieport 0000:00:00.0: AER enabled with IRQ 53
[ 0.315492] pci 0000:01:00.0: enabling device (0140 -> 0142)
[ 0.319600] iproc-rng200 fe104000.rng: hwrng registered
[ 0.319836] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
[ 0.320349] vc-sm: Videocore shared memory driver
[ 0.320760] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
[ 0.330957] brd: module loaded
[ 0.340583] loop: module loaded
[ 0.341348] Loading iSCSI transport class v2.0-870.
[ 0.343052] libphy: Fixed MDIO Bus: probed
[ 0.343487] bcmgenet fd580000.genet: failed to get enet clock
[ 0.343518] bcmgenet fd580000.genet: GENET 5.0 EPHY: 0x0000
[ 0.343548] bcmgenet fd580000.genet: failed to get enet-wol clock
[ 0.343578] bcmgenet fd580000.genet: failed to get enet-eee clock
[ 0.343614] bcmgenet: Skipping UMAC reset
[ 0.343864] unimac-mdio unimac-mdio.-19: DMA mask not set
[ 0.357718] libphy: bcmgenet MII bus: probed
[ 0.398201] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus at 0x(ptrval)
[ 0.399121] usbcore: registered new interface driver r8152
[ 0.399204] usbcore: registered new interface driver lan78xx
[ 0.399273] usbcore: registered new interface driver smsc95xx
[ 0.399587] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ 0.399631] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
[ 0.401829] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0000001000000890
[ 0.402175] genirq: irq_chip Brcm_MSI did not update eff. affinity mask of irq 54
[ 0.403059] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[ 0.403092] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.403122] usb usb1: Product: xHCI Host Controller
[ 0.403145] usb usb1: Manufacturer: Linux 4.19.118-v7l+ xhci-hcd
[ 0.403169] usb usb1: SerialNumber: 0000:01:00.0
[ 0.403701] hub 1-0:1.0: USB hub found
[ 0.403795] hub 1-0:1.0: 1 port detected
[ 0.404277] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ 0.404313] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
[ 0.404357] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
[ 0.404776] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 4.19
[ 0.404809] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.404837] usb usb2: Product: xHCI Host Controller
[ 0.404861] usb usb2: Manufacturer: Linux 4.19.118-v7l+ xhci-hcd
[ 0.404885] usb usb2: SerialNumber: 0000:01:00.0
[ 0.405386] hub 2-0:1.0: USB hub found
[ 0.405454] hub 2-0:1.0: 4 ports detected
[ 0.406677] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 0.406883] dwc_otg: FIQ enabled
[ 0.406892] dwc_otg: NAK holdoff enabled
[ 0.406901] dwc_otg: FIQ split-transaction FSM enabled
[ 0.406914] Module dwc_common_port init
[ 0.407133] usbcore: registered new interface driver uas
[ 0.407242] usbcore: registered new interface driver usb-storage
[ 0.407429] mousedev: PS/2 mouse device common for all mice
[ 0.408658] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[ 0.410291] sdhci: Secure Digital Host Controller Interface driver
[ 0.410317] sdhci: Copyright© Pierre Ossman
[ 0.410725] mmc-bcm2835 fe300000.mmcnr: could not get clk, deferring probe
[ 0.411136] sdhci-pltfm: SDHCI platform and OF driver helper
[ 0.414168] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.414330] hidraw: raw HID events driver © Jiri Kosina
[ 0.414466] usbcore: registered new interface driver usbhid
[ 0.414488] usbhid: USB HID core driver
[ 0.415273] vchiq: vchiq_init_state: slot_zero = (ptrval), is_master = 0
[ 0.417043] [vc_sm_connected_init]: start
[ 0.425826] [vc_sm_connected_init]: end - returning 0
[ 0.426937] Initializing XFRM netlink socket
[ 0.426979] NET: Registered protocol family 17
[ 0.427085] Key type dns_resolver registered
[ 0.427473] Registering SWP/SWPB emulation handler
[ 0.428111] registered taskstats version 1
[ 0.428142] Loading compiled-in X.509 certificates
[ 0.435056] uart-pl011 fe201000.serial: cts_event_workaround enabled
[ 0.435136] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 34, base_baud = 0) is a PL011 rev2
[ 0.440302] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
[ 0.440840] brcmstb_thermal fd5d2200.thermal: registered AVS TMON of-sensor driver
[ 0.441506] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
[ 0.441534] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
[ 0.467574] sdhci-iproc fe340000.emmc2: Linked as a consumer to regulator.3
[ 0.467713] sdhci-iproc fe340000.emmc2: Linked as a consumer to regulator.4
[ 0.484996] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[ 0.486605] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 0.488210] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 0.491076] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ 0.492678] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 0.500384] mmc0: SDHCI controller on fe340000.emmc2 [fe340000.emmc2] using ADMA
[ 0.502865] of_cfs_init
[ 0.502958] of_cfs_init: OK
[ 0.503548] Waiting for root device PARTUUID=8b395f82-02…
[ 0.548215] random: fast init done
[ 0.562915] mmc1: new high speed SDIO card at address 0001
[ 0.602142] mmc0: new ultra high speed DDR50 SDHC card at address 0001
[ 0.603278] mmcblk0: mmc0:0001 EB1QT 29.8 GiB
[ 0.604389] mmcblk0: p1 p2
[ 0.626484] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 0.626555] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 0.631547] devtmpfs: mounted
[ 0.638817] Freeing unused kernel memory: 2048K
[ 0.677945] Run /sbin/init as init process
[ 0.767738] usb 1-1: new high-speed USB device number 2 using xhci_hcd
[ 0.950359] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21
[ 0.950400] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 0.950428] usb 1-1: Product: USB2.0 Hub
[ 0.952261] hub 1-1:1.0: USB hub found
[ 0.952603] hub 1-1:1.0: 4 ports detected
[ 1.074420] systemd[1]: System time before build time, advancing clock.
[ 1.160167] NET: Registered protocol family 10
[ 1.161398] Segment Routing with IPv6
[ 1.193305] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 1.194033] systemd[1]: Detected architecture arm.
[ 1.204668] systemd[1]: Set hostname to .
[ 1.598609] random: lvmconfig: uninitialized urandom read (4 bytes read)
[ 2.157327] systemd[1]: /lib/systemd/system/rpc-statd.service:13: PIDFile= references path below legacy directory /var/run/, updating /var/run/rpc.statd.pid → /run/rpc.statd.pid; please update the unit file accordingly.
[ 2.203461] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.226468] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.226938] systemd[1]: Listening on udev Kernel Socket.
[ 2.228044] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[ 2.228714] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ 2.229490] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ 2.230592] systemd[1]: Listening on Journal Socket.
[ 2.240527] systemd[1]: Starting Create list of required static device nodes for the current kernel…
[ 2.361863] Installing knfsd (copyright © 1996 [email protected]).
[ 2.953898] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 3.047457] systemd-journald[143]: Received request to flush runtime journal from PID 1
[ 3.578644] rpivid-mem feb00000.hevc-decoder: rpivid-hevcmem initialised: Registers at 0xfeb00000 length 0x0000ffff
[ 3.579677] rpivid-mem feb10000.rpivid-local-intc: rpivid-intcmem initialised: Registers at 0xfeb10000 length 0x00000fff
[ 3.580222] rpivid-mem feb20000.h264-decoder: rpivid-h264mem initialised: Registers at 0xfeb20000 length 0x0000ffff
[ 3.581822] Driver for 1-wire Dallas network protocol.
[ 3.582388] rpivid-mem feb30000.vp9-decoder: rpivid-vp9mem initialised: Registers at 0xfeb30000 length 0x0000ffff
[ 3.586012] gpio-4 (onewire@0): enforced open drain please flag it properly in DT/ACPI DSDT/board file
[ 3.645573] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
[ 3.647591] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
[ 3.647607] [vc_sm_connected_init]: start
[ 3.650527] [vc_sm_connected_init]: installed successfully
[ 3.656411] media: Linux media interface: v0.10
[ 3.710525] videodev: Linux video capture interface: v2.00
[ 3.742188] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
[ 3.772479] bcm2835_audio soc:audio: card created with 8 channels
[ 3.782581] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 3.830116] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
[ 3.857083] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
[ 3.881134] bcmgenet: Skipping UMAC reset
[ 3.908314] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
[ 3.908349] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
[ 3.929635] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
[ 3.929678] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
[ 3.963071] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
[ 3.963102] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
[ 3.978513] bcmgenet fd580000.genet: configuring instance for external RGMII (no delay)
[ 3.978793] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 4.052588] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 0
[ 4.089549] [drm] No displays found. Consider forcing hotplug if HDMI is attached
[ 4.089652] vc4-drm soc:gpu: bound fe600000.firmwarekms (ops vc4_fkms_ops [vc4])
[ 4.090103] [drm] Initialized vc4 0.0.0 20140616 for soc:gpu on minor 1
[ 4.090115] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 4.090124] [drm] No driver support for vblank timestamp query.
[ 4.090134] [drm] Setting vblank_disable_immediate to false because get_vblank_timestamp == NULL
[ 4.252650] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 4.302926] cfg80211: Loaded X.509 cert ‘sforshee: 00b28ddf47aef9cea7’
[ 4.356503] brcmfmac: F1 signature read @0x18000000=0x15264345
[ 4.366145] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 4.366905] usbcore: registered new interface driver brcmfmac
[ 4.613497] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 4.626173] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Mar 2 2020 23:30:41 version 7.45.202 (r724630 CY) FWID 01-72f6ece2
[ 5.047976] bcmgenet fd580000.genet eth0: Link is Down
[ 7.637369] uart-pl011 fe201000.serial: no DMA platform data
[ 8.034420] Adding 102396k swap on /var/swap. Priority:-2 extents:1 across:102396k SSFS
[ 8.418602] NFSD: starting 90-second grace period (net f0000041)
[ 8.619078] random: crng init done
[ 8.619093] random: 7 urandom warning(s) missed due to ratelimiting
[ 9.207825] bcmgenet fd580000.genet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[ 9.207844] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 9.259190] i2c /dev entries driver
[ 14.548465] Bluetooth: Core ver 2.22
[ 14.548540] NET: Registered protocol family 31
[ 14.548551] Bluetooth: HCI device and connection manager initialized
[ 14.548571] Bluetooth: HCI socket layer initialized
[ 14.548587] Bluetooth: L2CAP socket layer initialized
[ 14.548630] Bluetooth: SCO socket layer initialized
[ 14.564648] Bluetooth: HCI UART driver ver 2.3
[ 14.564662] Bluetooth: HCI UART protocol H4 registered
[ 14.564743] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 14.564977] Bluetooth: HCI UART protocol Broadcom registered
[ 14.702412] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 14.702422] Bluetooth: BNEP filters: protocol multicast
[ 14.702437] Bluetooth: BNEP socket layer initialized
