Quad SATA HAT SSD not detected
In open média vault i cant see my SSD, i formated to Ext4 but still not detected, my ssd works well in windows…
Any idea can help me please ?
Post output of lsusb command, is HAT found in system?
which product ?
This product:
https://shop.allnetchina.cn/products/dual-sata-hat-open-frame-for-raspberry-pi-4?_pos=2&_sid=89a47353d&_ss=r&variant=31200524697702
i dont use any command i use open média vault interface
Capture%20d'%C3%A9cran%202024-07-19%20130453
You can turn on ssh access and perform needed checkup,
dmesg will show You errors, lsusb (You need usb-utils package) will show You usb devices,
omv has diagnostic tab, but usb information are not included there,
raspberrypi@raspberrypi:~ $ lsusb -t
/: Bus 02.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/4p, 5000M
/: Bus 01.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/1p, 480M
|__ Port 1: Dev 2, If 0, Class=Hub, Driver=hub/4p, 480M
there is no SSD wish size is 240GB :confused:
why the wiki: https://wiki.radxa.com/Dual_Quad_SATA_HAT
dosntt exist ?
i think i need to install a package who turn on the sata connectors on the QUAD SATA bard, but i cant find any link
i come to try to install the .deb so i use this command:
wget https://github.com/radxa/rockpi-quad/releases/download/0.3.0/rockpi-quad.deb
then
sudo dpkg -i rockpi-quad.deb
and here i get problems :( i think because depenceses, what should i do ?
this link have all the package but i dont know how to install it:
https://github.com/NGS99/rockpi-sata/tree/master
Aa far as I remember You don’t need any special driver, it’s usb mass storage, present on almost everything.
The megabytes are not about any size, but speed, for now we are checking if USB device is found, recognized and working, this is preliminary step.
The output should look like this:
dominik@pi:~ $ lsusb -t
    |__ Port 1: Dev 3, If 0, Class=Mass Storage, Driver=uas, 5000M
    |__ Port 2: Dev 2, If 0, Class=Mass Storage, Driver=uas, 5000M
You should see two usb devices,
with -v option You should get information about JMicron (JMS 551 maybe, which is not exactly the one used here, but it doesnt matter for now)
Please post dmesg message - are there anything about usb initializing? any errors?
triple check USB bridge, is it all way inserted? Try same lsusb command without sata drive connected, You don’t need it yet to check usb connectivity.
raspberrypi@raspberrypi:~ $ dmesg
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd083]
[ 0.000000] Linux version 6.1.21-v8+ (dom@buildbot) (aarch64-linux-gnu-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #1642 SMP PREEMPT Mon Apr 3 17:24:16 BST 2023
[ 0.000000] random: crng init done
[ 0.000000] Machine model: Raspberry Pi 4 Model B Rev 1.1
[ 0.000000] efi: UEFI not found.
[ 0.000000] Reserved memory: created CMA memory pool at 0x000000000ec00000, size 512 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000000000000-0x000000003fffffff]
[ 0.000000] DMA32 [mem 0x0000000040000000-0x000000007fffffff]
[ 0.000000] Normal empty
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000000000000-0x000000003b3fffff]
[ 0.000000] node 0: [mem 0x0000000040000000-0x000000007fffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x000000007fffffff]
[ 0.000000] On node 0, zone DMA32: 19456 pages in unavailable ranges
[ 0.000000] percpu: Embedded 29 pages/cpu s78504 r8192 d32088 u118784
[ 0.000000] pcpu-alloc: s78504 r8192 d32088 u118784 alloc=29*4096
[ 0.000000] Detected PIPT I-cache on CPU0
[ 0.000000] CPU features: detected: Spectre-v2
[ 0.000000] CPU features: detected: Spectre-v3a
[ 0.000000] CPU features: detected: Spectre-v4
[ 0.000000] CPU features: detected: Spectre-BHB
[ 0.000000] CPU features: kernel page table isolation forced ON by KASLR
[ 0.000000] CPU features: detected: Kernel page table isolation (KPTI)
[ 0.000000] CPU features: detected: ARM erratum 1742098
[ 0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
[ 0.000000] alternatives: applying boot alternatives
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 496944
[ 0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 smsc95xx.macaddr=DC:A6:32:33:A7:A8 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 console=ttyS0,115200 console=tty1 root=PARTUUID=b7e3f89e-02 rootfstype=ext4 fsck.repair=yes rootwait cfg80211.ieee80211_regdom=GB
[ 0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] software IO TLB: area num 4.
[ 0.000000] software IO TLB: mapped [mem 0x0000000037400000-0x000000003b400000] (64MB)
[ 0.000000] Memory: 1365148K/2019328K available (11776K kernel code, 2106K rwdata, 3688K rodata, 4160K init, 1077K bss, 129892K reserved, 524288K cma-reserved)
[ 0.000000] ftrace: allocating 39744 entries in 156 pages
[ 0.000000] ftrace: allocated 156 pages with 4 groups
[ 0.000000] trace event string verifier disabled
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4.
[ 0.000000] Trampoline variant of Tasks RCU enabled.
[ 0.000000] Rude variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] Root IRQ handler: gic_handle_irq
[ 0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[ 0.000000] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
[ 0.000001] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
[ 0.000311] Console: colour dummy device 80x25
[ 0.000903] printk: console [tty1] enabled
[ 0.000970] Calibrating delay loop (skipped), value calculated using timer frequency… 108.00 BogoMIPS (lpj=216000)
[ 0.001010] pid_max: default: 32768 minimum: 301
[ 0.001153] LSM: Security Framework initializing
[ 0.001356] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
[ 0.001411] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
[ 0.002690] cgroup: Disabling memory control group subsystem
[ 0.004937] cblist_init_generic: Setting adjustable number of callback queues.
[ 0.004973] cblist_init_generic: Setting shift to 2 and lim to 1.
[ 0.005162] cblist_init_generic: Setting shift to 2 and lim to 1.
[ 0.005351] cblist_init_generic: Setting shift to 2 and lim to 1.
[ 0.005796] rcu: Hierarchical SRCU implementation.
[ 0.005821] rcu: Max phase no-delay instances is 1000.
[ 0.007143] EFI services will not be available.
[ 0.007679] smp: Bringing up secondary CPUs …
[ 0.008840] Detected PIPT I-cache on CPU1
[ 0.008991] CPU1: Booted secondary processor 0x0000000001 [0x410fd083]
[ 0.010125] Detected PIPT I-cache on CPU2
[ 0.010245] CPU2: Booted secondary processor 0x0000000002 [0x410fd083]
[ 0.011344] Detected PIPT I-cache on CPU3
[ 0.011466] CPU3: Booted secondary processor 0x0000000003 [0x410fd083]
[ 0.011612] smp: Brought up 1 node, 4 CPUs
[ 0.011701] SMP: Total of 4 processors activated.
[ 0.011722] CPU features: detected: 32-bit EL0 Support
[ 0.011741] CPU features: detected: 32-bit EL1 Support
[ 0.011763] CPU features: detected: CRC32 instructions
[ 0.011905] CPU: All CPU(s) started at EL2
[ 0.011985] alternatives: applying system-wide alternatives
[ 0.013739] devtmpfs: initialized
[ 0.025666] Enabled cp15_barrier support
[ 0.025733] Enabled setend support
[ 0.025960] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.026011] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.039413] pinctrl core: initialized pinctrl subsystem
[ 0.040360] DMI not present or invalid.
[ 0.041061] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.044625] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
[ 0.044943] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.045902] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.046011] audit: initializing netlink subsys (disabled)
[ 0.046306] audit: type=2000 audit(0.044:1): state=initialized audit_enabled=0 res=1
[ 0.046917] thermal_sys: Registered thermal governor ‘step_wise’
[ 0.047007] cpuidle: using governor menu
[ 0.047410] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.047620] ASID allocator initialised with 32768 entries
[ 0.047798] Serial: AMBA PL011 UART driver
[ 0.061452] bcm2835-mbox fe00b880.mailbox: mailbox enabled
[ 0.084318] raspberrypi-firmware soc:firmware: Attached to firmware from 2023-03-17T10:50:39, variant start
[ 0.088333] raspberrypi-firmware soc:firmware: Firmware hash is 82f3750a65fadae9a38077e3c2e217ad158c8d54
[ 0.104247] KASLR enabled
[ 0.138305] bcm2835-dma fe007000.dma: DMA legacy API manager, dmachans=0x1
[ 0.144071] SCSI subsystem initialized
[ 0.144342] usbcore: registered new interface driver usbfs
[ 0.144415] usbcore: registered new interface driver hub
[ 0.144494] usbcore: registered new device driver usb
[ 0.144893] usb_phy_generic phy: supply vcc not found, using dummy regulator
[ 0.145138] usb_phy_generic phy: dummy supplies not allowed for exclusive requests
[ 0.145511] pps_core: LinuxPPS API ver. 1 registered
[ 0.145536] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti [email protected]
[ 0.145577] PTP clock support registered
[ 0.146715] vgaarb: loaded
[ 0.147450] clocksource: Switched to clocksource arch_sys_counter
[ 1.309105] VFS: Disk quotas dquot_6.6.0
[ 1.309227] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 1.309430] FS-Cache: Loaded
[ 1.309715] CacheFiles: Loaded
[ 1.320742] NET: Registered PF_INET protocol family
[ 1.321144] IP idents hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 1.324191] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes, linear)
[ 1.324255] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 1.324295] TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 1.324423] TCP bind hash table entries: 16384 (order: 7, 524288 bytes, linear)
[ 1.324992] TCP: Hash tables configured (established 16384 bind 16384)
[ 1.325199] UDP hash table entries: 1024 (order: 3, 32768 bytes, linear)
[ 1.325257] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes, linear)
[ 1.325499] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 1.326301] RPC: Registered named UNIX socket transport module.
[ 1.326333] RPC: Registered udp transport module.
[ 1.326353] RPC: Registered tcp transport module.
[ 1.326372] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.326406] PCI: CLS 0 bytes, default 64
[ 1.329012] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[ 1.329415] kvm [1]: IPA Size Limit: 44 bits
[ 1.330758] kvm [1]: vgic interrupt IRQ9
[ 1.331007] kvm [1]: Hyp mode initialized successfully
[ 1.333243] Initialise system trusted keyrings
[ 1.333630] workingset: timestamp_bits=46 max_order=19 bucket_order=0
[ 1.341158] zbud: loaded
[ 1.344073] NFS: Registering the id_resolver key type
[ 1.344134] Key type id_resolver registered
[ 1.344155] Key type id_legacy registered
[ 1.344280] nfs4filelayout_init: NFSv4 File Layout Driver Registering…
[ 1.344310] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering…
[ 1.345747] Key type asymmetric registered
[ 1.345778] Asymmetric key parser ‘x509’ registered
[ 1.345874] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[ 1.346186] io scheduler mq-deadline registered
[ 1.346215] io scheduler kyber registered
[ 1.348604] irq_brcmstb_l2: registered L2 intc (/soc/interrupt-controller@7ef00100, parent irq: 27)
[ 1.357039] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
[ 1.357105] brcm-pcie fd500000.pcie: No bus range found for /scb/pcie@7d500000, using [bus 00-ff]
[ 1.357209] brcm-pcie fd500000.pcie: MEM 0x0600000000…0x063fffffff -> 0x00c0000000
[ 1.357307] brcm-pcie fd500000.pcie: IB MEM 0x0000000000…0x007fffffff -> 0x0400000000
[ 1.358327] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
[ 1.358360] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 1.358389] pci_bus 0000:00: root bus resource [mem 0x600000000-0x63fffffff] (bus address [0xc0000000-0xffffffff])
[ 1.358479] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
[ 1.358747] pci 0000:00:00.0: PME# supported from D0 D3hot
[ 1.362559] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 1.362849] pci_bus 0000:01: supply vpcie3v3 not found, using dummy regulator
[ 1.363042] pci_bus 0000:01: supply vpcie3v3aux not found, using dummy regulator
[ 1.363166] pci_bus 0000:01: supply vpcie12v not found, using dummy regulator
[ 1.413546] brcm-pcie fd500000.pcie: link up, 5.0 GT/s PCIe x1 (SSC)
[ 1.413726] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
[ 1.413863] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
[ 1.414357] pci 0000:01:00.0: PME# supported from D0 D3cold
[ 1.415110] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[ 1.415168] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
[ 1.415203] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
[ 1.415260] pci 0000:00:00.0: PCI bridge to [bus 01]
[ 1.415291] pci 0000:00:00.0: bridge window [mem 0x600000000-0x6000fffff]
[ 1.428585] iproc-rng200 fe104000.rng: hwrng registered
[ 1.429168] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
[ 1.430747] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
[ 1.443967] brd: module loaded
[ 1.452727] loop: module loaded
[ 1.453622] Loading iSCSI transport class v2.0-870.
[ 1.458931] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000
[ 1.519609] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus
[ 1.520784] usbcore: registered new interface driver r8152
[ 1.520872] usbcore: registered new interface driver lan78xx
[ 1.520945] usbcore: registered new interface driver smsc95xx
[ 1.522567] pci 0000:00:00.0: enabling device (0000 -> 0002)
[ 1.522621] xhci_hcd 0000:01:00.0: enabling device (0000 -> 0002)
[ 1.522754] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ 1.522797] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
[ 1.523601] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0000e40000000890
[ 1.524281] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ 1.524316] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
[ 1.524352] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
[ 1.524746] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.01
[ 1.524782] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.524809] usb usb1: Product: xHCI Host Controller
[ 1.524831] usb usb1: Manufacturer: Linux 6.1.21-v8+ xhci-hcd
[ 1.524854] usb usb1: SerialNumber: 0000:01:00.0
[ 1.525599] hub 1-0:1.0: USB hub found
[ 1.525708] hub 1-0:1.0: 1 port detected
[ 1.526701] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.01
[ 1.526738] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.526765] usb usb2: Product: xHCI Host Controller
[ 1.526787] usb usb2: Manufacturer: Linux 6.1.21-v8+ xhci-hcd
[ 1.526809] usb usb2: SerialNumber: 0000:01:00.0
[ 1.527522] hub 2-0:1.0: USB hub found
[ 1.527602] hub 2-0:1.0: 4 ports detected
[ 1.529333] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 1.529680] dwc_otg: FIQ enabled
[ 1.529691] dwc_otg: NAK holdoff enabled
[ 1.529701] dwc_otg: FIQ split-transaction FSM enabled
[ 1.529720] Module dwc_common_port init
[ 1.530300] usbcore: registered new interface driver uas
[ 1.530420] usbcore: registered new interface driver usb-storage
[ 1.530673] mousedev: PS/2 mouse device common for all mice
[ 1.536776] sdhci: Secure Digital Host Controller Interface driver
[ 1.536815] sdhci: Copyright© Pierre Ossman
[ 1.537503] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.541148] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.541511] hid: raw HID events driver © Jiri Kosina
[ 1.541740] usbcore: registered new interface driver usbhid
[ 1.541766] usbhid: USB HID core driver
[ 1.550586] NET: Registered PF_PACKET protocol family
[ 1.550748] Key type dns_resolver registered
[ 1.552153] registered taskstats version 1
[ 1.552247] Loading compiled-in X.509 certificates
[ 1.553152] Key type .fscrypt registered
[ 1.553179] Key type fscrypt-provisioning registered
[ 1.568985] uart-pl011 fe201000.serial: there is not valid maps for state default
[ 1.569744] uart-pl011 fe201000.serial: cts_event_workaround enabled
[ 1.569933] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 36, base_baud = 0) is a PL011 rev2
[ 1.579073] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[ 1.579618] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
[ 1.580943] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
[ 1.580976] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
[ 1.609447] of_cfs_init
[ 1.609591] of_cfs_init: OK
[ 1.643029] mmc0: SDHCI controller on fe340000.mmc [fe340000.mmc] using ADMA
[ 1.643383] Waiting for root device PARTUUID=b7e3f89e-02…
[ 1.695948] mmc1: new high speed SDIO card at address 0001
[ 1.777765] mmc0: new ultra high speed DDR50 SDHC card at address 0002
[ 1.778802] mmcblk0: mmc0:0002 USD00 30.0 GiB
[ 1.779526] usb 1-1: new high-speed USB device number 2 using xhci_hcd
[ 1.782239] mmcblk0: p1 p2
[ 1.782880] mmcblk0: mmc0:0002 USD00 30.0 GiB
[ 1.794927] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
[ 1.794974] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
[ 1.930069] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21
[ 1.930129] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 1.930157] usb 1-1: Product: USB2.0 Hub
[ 1.932194] hub 1-1:1.0: USB hub found
[ 1.932462] hub 1-1:1.0: 4 ports detected
[ 2.034296] EXT4-fs (mmcblk0p2): recovery complete
[ 2.040728] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
[ 2.040837] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 2.046928] devtmpfs: mounted
[ 2.055324] Freeing unused kernel memory: 4160K
[ 2.055572] Run /sbin/init as init process
[ 2.055595] with arguments:
[ 2.055604] /sbin/init
[ 2.055614] with environment:
[ 2.055622] HOME=/
[ 2.055631] TERM=linux
[ 2.438000] systemd[1]: System time before build time, advancing clock.
[ 2.628241] NET: Registered PF_INET6 protocol family
[ 2.630125] Segment Routing with IPv6
[ 2.630195] In-situ OAM (IOAM) with IPv6
[ 2.705723] systemd[1]: systemd 247.3-7+deb11u5 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +ZSTD +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=unified)
[ 2.706777] systemd[1]: Detected architecture arm64.
[ 2.718446] systemd[1]: Set hostname to .
[ 2.764066] systemd[1]: Using hardware watchdog ‘Broadcom BCM2835 Watchdog timer’, version 0, device /dev/watchdog
[ 2.764155] systemd[1]: Set hardware watchdog to 14s.
[ 3.924345] systemd[1]: Queued start job for default target Multi-User System.
[ 3.941256] systemd[1]: Created slice system-getty.slice.
[ 3.943143] systemd[1]: Created slice system-modprobe.slice.
[ 3.944605] systemd[1]: Created slice system-systemd\x2dfsck.slice.
[ 3.945777] systemd[1]: Created slice User and Session Slice.
[ 3.946628] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ 3.947392] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 3.948868] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 3.949417] systemd[1]: Reached target Local Encrypted Volumes.
[ 3.949981] systemd[1]: Reached target Paths.
[ 3.950403] systemd[1]: Reached target Slices.
[ 3.950805] systemd[1]: Reached target Swap.
[ 3.951199] systemd[1]: Reached target System Time Set.
[ 3.952102] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[ 3.955884] systemd[1]: Listening on LVM2 poll daemon socket.
[ 3.957070] systemd[1]: Listening on Syslog Socket.
[ 3.958107] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 3.958870] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ 3.960478] systemd[1]: Listening on Journal Audit Socket.
[ 3.961659] systemd[1]: Listening on Journal Socket (/dev/log).
[ 3.963021] systemd[1]: Listening on Journal Socket.
[ 3.964612] systemd[1]: Listening on Network Service Netlink Socket.
[ 3.969285] systemd[1]: Listening on udev Control Socket.
[ 3.970616] systemd[1]: Listening on udev Kernel Socket.
[ 3.972071] systemd[1]: Condition check resulted in Huge Pages File System being skipped.
[ 3.995969] systemd[1]: Mounting POSIX Message Queue File System…
[ 4.001251] systemd[1]: Mounting RPC Pipe File System…
[ 4.007233] systemd[1]: Mounting Kernel Debug File System…
[ 4.013159] systemd[1]: Mounting Kernel Trace File System…
[ 4.014374] systemd[1]: Condition check resulted in Kernel Module supporting RPCSEC_GSS being skipped.
[ 4.015197] systemd[1]: Finished Availability of block devices.
[ 4.022206] systemd[1]: Starting Restore / save the current clock…
[ 4.028059] systemd[1]: Starting Set the console keyboard layout…
[ 4.034195] systemd[1]: Starting Create list of static device nodes for the current kernel…
[ 4.039770] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling…
[ 4.050129] systemd[1]: Starting Load Kernel Module configfs…
[ 4.056287] systemd[1]: Starting Load Kernel Module drm…
[ 4.067275] systemd[1]: Starting Load Kernel Module fuse…
[ 4.079908] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[ 4.085267] systemd[1]: Starting File System Check on Root Device…
[ 4.109381] systemd[1]: Starting Journal Service…
[ 4.125483] systemd[1]: Starting Load Kernel Modules…
[ 4.129984] fuse: init (API version 7.37)
[ 4.131611] systemd[1]: Starting Coldplug All udev Devices…
[ 4.169738] systemd[1]: Mounted POSIX Message Queue File System.
[ 4.170977] systemd[1]: Mounted RPC Pipe File System.
[ 4.185137] systemd[1]: Mounted Kernel Debug File System.
[ 4.186257] systemd[1]: Mounted Kernel Trace File System.
[ 4.193332] systemd[1]: Finished Restore / save the current clock.
[ 4.199635] systemd[1]: Finished Create list of static device nodes for the current kernel.
[ 4.202185] systemd[1]: [email protected]: Succeeded.
[ 4.203777] systemd[1]: Finished Load Kernel Module configfs.
[ 4.206269] systemd[1]: [email protected]: Succeeded.
[ 4.207931] systemd[1]: Finished Load Kernel Module fuse.
[ 4.209619] i2c_dev: i2c /dev entries driver
[ 4.236077] systemd[1]: Mounting FUSE Control File System…
[ 4.248203] systemd[1]: Mounting Kernel Configuration File System…
[ 4.271037] systemd[1]: Starting pNFS block layout mapping daemon…
[ 4.300860] systemd[1]: Started File System Check Daemon to report status.
[ 4.341587] systemd[1]: [email protected]: Succeeded.
[ 4.343056] systemd[1]: Finished Load Kernel Module drm.
[ 4.352314] systemd[1]: Finished Load Kernel Modules.
[ 4.353591] systemd[1]: Mounted FUSE Control File System.
[ 4.354530] systemd[1]: Mounted Kernel Configuration File System.
[ 4.364388] systemd[1]: Started pNFS block layout mapping daemon.
[ 4.366988] systemd[1]: Finished File System Check on Root Device.
[ 4.393032] systemd[1]: Starting Remount Root and Kernel File Systems…
[ 4.398430] systemd[1]: Starting Apply Kernel Variables…
[ 4.484989] systemd[1]: Finished Apply Kernel Variables.
[ 4.530887] systemd[1]: Started Journal Service.
[ 4.551309] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
[ 4.658446] systemd-journald[157]: Received client request to flush runtime journal.
[ 4.689473] systemd-journald[157]: File /var/log/journal/429ca66708f44107bb81e2ac3e3e9458/system.journal corrupted or uncleanly shut down, renaming and replacing.
[ 5.863236] mc: Linux media interface: v0.10
[ 5.928335] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
[ 5.959596] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
[ 5.959637] [vc_sm_connected_init]: start
[ 5.960930] [vc_sm_connected_init]: installed successfully
[ 5.970060] videodev: Linux video capture interface: v2.00
[ 6.022405] rpivid_hevc: module is from the staging directory, the quality is unknown, you have been warned.
[ 6.026555] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 6.063411] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
[ 6.079552] rpivid feb10000.codec: Device registered as /dev/video19
[ 6.085945] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
[ 6.103851] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
[ 6.103935] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
[ 6.109170] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
[ 6.109225] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
[ 6.116977] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
[ 6.117043] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
[ 6.127298] bcm2835-codec bcm2835-codec: Device registered as /dev/video18
[ 6.127366] bcm2835-codec bcm2835-codec: Loaded V4L2 image_fx
[ 6.134410] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
[ 6.149897] bcm2835-codec bcm2835-codec: Device registered as /dev/video31
[ 6.149957] bcm2835-codec bcm2835-codec: Loaded V4L2 encode_image
[ 6.168148] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
[ 6.197772] bcm2835_audio bcm2835_audio: card created with 8 channels
[ 6.216117] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
[ 6.221633] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
[ 6.221829] brcmstb-i2c fef04500.i2c: @97500hz registered in polling mode
[ 6.222226] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
[ 6.222683] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
[ 6.222720] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
[ 6.222742] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
[ 6.222772] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
[ 6.222790] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
[ 6.227833] brcmstb-i2c fef09500.i2c: @97500hz registered in polling mode
[ 6.231166] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video20
[ 6.232025] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video21
[ 6.232523] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video22
[ 6.232957] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video23
[ 6.232993] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
[ 6.233027] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
[ 6.233062] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
[ 6.233079] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
[ 6.235612] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
[ 6.433596] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 0
[ 6.699632] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 6.733521] cfg80211: Loaded X.509 cert ‘sforshee: 00b28ddf47aef9cea7’
[ 6.746823] cfg80211: loaded regulatory.db is malformed or signature is missing/invalid
[ 6.952857] vc4-drm gpu: bound fe400000.hvs (ops vc4_hvs_ops [vc4])
[ 7.005104] brcmfmac: F1 signature read @0x18000000=0x15264345
[ 7.012050] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 7.013230] usbcore: registered new interface driver brcmfmac
[ 7.065164] Registered IR keymap rc-cec
[ 7.104773] rc rc0: vc4-hdmi-0 as /devices/platform/soc/fef00700.hdmi/rc/rc0
[ 7.193503] input: vc4-hdmi-0 as /devices/platform/soc/fef00700.hdmi/rc/rc0/input0
[ 7.216994] vc4-drm gpu: bound fef00700.hdmi (ops vc4_hdmi_ops [vc4])
[ 7.286133] Registered IR keymap rc-cec
[ 7.286438] rc rc1: vc4-hdmi-1 as /devices/platform/soc/fef05700.hdmi/rc/rc1
[ 7.286664] input: vc4-hdmi-1 as /devices/platform/soc/fef05700.hdmi/rc/rc1/input1
[ 7.296858] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Nov 1 2021 00:37:25 version 7.45.241 (1a2f2fa CY) FWID 01-703fd60
[ 7.309408] vc4-drm gpu: bound fef05700.hdmi (ops vc4_hdmi_ops [vc4])
[ 7.310042] vc4-drm gpu: bound fe004000.txp (ops vc4_txp_ops [vc4])
[ 7.310546] vc4-drm gpu: bound fe206000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 7.311007] vc4-drm gpu: bound fe207000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 7.318697] vc4-drm gpu: bound fe20a000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 7.319096] vc4-drm gpu: bound fe216000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 7.355647] vc4-drm gpu: bound fec12000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 7.399217] [drm] Initialized vc4 0.0.0 20140616 for gpu on minor 1
[ 7.400315] vc4-drm gpu: [drm] Cannot find any crtc or sizes
[ 12.248151] uart-pl011 fe201000.serial: no DMA platform data
[ 12.279353] 8021q: 802.1Q VLAN Support v1.8
[ 12.425307] Adding 102396k swap on /var/swap. Priority:-2 extents:1 across:102396k SSFS
[ 12.686347] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
[ 13.098220] bcmgenet fd580000.ethernet: configuring instance for external RGMII (RX delay)
[ 13.108846] bcmgenet fd580000.ethernet eth0: Link is Down
[ 18.063424] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 19.240721] ICMPv6: process `dhcpcd’ is using deprecated sysctl (syscall) net.ipv6.neigh.wlan0.retrans_time - use net.ipv6.neigh.wlan0.retrans_time_ms instead
[ 19.847181] Bluetooth: Core ver 2.22
[ 19.847271] NET: Registered PF_BLUETOOTH protocol family
[ 19.847277] Bluetooth: HCI device and connection manager initialized
[ 19.847299] Bluetooth: HCI socket layer initialized
[ 19.847308] Bluetooth: L2CAP socket layer initialized
[ 19.847324] Bluetooth: SCO socket layer initialized
[ 19.864324] Bluetooth: HCI UART driver ver 2.3
[ 19.864346] Bluetooth: HCI UART protocol H4 registered
[ 19.864414] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 19.864614] Bluetooth: HCI UART protocol Broadcom registered
[ 20.132134] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 20.132154] Bluetooth: BNEP filters: protocol multicast
[ 20.132170] Bluetooth: BNEP socket layer initialized
[ 20.139105] Bluetooth: MGMT ver 1.22
[ 20.148217] NET: Registered PF_ALG protocol family
raspberrypi@raspberrypi:~ $ lsusb -v
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Couldn’t open device, some information will be missing
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 3.00
bDeviceClass 9 Hub
bDeviceSubClass 0
bDeviceProtocol 3
bMaxPacketSize0 9
idVendor 0x1d6b Linux Foundation
idProduct 0x0003 3.0 root hub
bcdDevice 6.01
iManufacturer 3 Linux 6.1.21-v8+ xhci-hcd
iProduct 2 xHCI Host Controller
iSerial 1 0000:01:00.0
bNumConfigurations 1
Configuration Descriptor:
bLength 9
bDescriptorType 2
wTotalLength 0x001f
bNumInterfaces 1
bConfigurationValue 1
iConfiguration 0
bmAttributes 0xe0
Self Powered
Remote Wakeup
MaxPower 0mA
Interface Descriptor:
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
bInterfaceClass 9 Hub
bInterfaceSubClass 0
bInterfaceProtocol 0 Full speed (or root) hub
iInterface 0
Endpoint Descriptor:
bLength 7
bDescriptorType 5
bEndpointAddress 0x81 EP 1 IN
bmAttributes 3
Transfer Type Interrupt
Synch Type None
Usage Type Data
wMaxPacketSize 0x0004 1x 4 bytes
bInterval 12
bMaxBurst 0
Bus 001 Device 002: ID 2109:3431 VIA Labs, Inc. Hub
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.10
bDeviceClass 9 Hub
bDeviceSubClass 0
bDeviceProtocol 1 Single TT
bMaxPacketSize0 64
idVendor 0x2109 VIA Labs, Inc.
idProduct 0x3431 Hub
bcdDevice 4.21
iManufacturer 0
iProduct 1 USB2.0 Hub
iSerial 0
bLength 9
bDescriptorType 2
wTotalLength 0x0019
bNumInterfaces 1
iConfiguration 0
bmAttributes 0xe0
Self Powered
Remote Wakeup
MaxPower 100mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 3
Synch Type None
Usage Type Data
wMaxPacketSize 0x0001 1x 1 bytes
bInterval 12
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 9 Hub
bDeviceSubClass 0
bMaxPacketSize0 64
idProduct 0x0002 2.0 root hub
bcdDevice 6.01
bLength 9
bDescriptorType 2
wTotalLength 0x0019
bNumInterfaces 1
iConfiguration 0
bmAttributes 0xe0
Self Powered
Remote Wakeup
MaxPower 0mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 3
Synch Type None
Usage Type Data
bInterval 12
my drive is formated with EXT4 AOMEI software and i changed my drive in all SATA slot :woozy_face: its the same thing, ill take pictures for raspberrypi 4 maybe i miss something
Your problem is somehow related to usb connection,
maybe this whit usb bridge is damaged, maybe some of ports?
For now You can remove Your sata drive, it’s not needed until You get usb connection, unconnect this white bridge and connect one of usb ports of pi to one of hat ports - it should register new device with ID:
Bus 002 Device 002: ID 152d:0561 JMicron Technology Corp. / JMicron USA Technology Corp. JMS551 - Sharkoon SATA QuickPort Duo
You can also try to connect it via cable to pc to see i fit come up and its recognized. It need to work as usb device before You can try to find drives connected to it.
something wrong with my raspberry OS.
i come to buy this modul to test my drive on raspberry without using QUAD SATA
i get this information using lsusb -t
there is no 240go of my SSD
and there is no 4Go of my USB Flash
It is ok, you got two mass storage devices and You should be able to see them via lsblk and blkid commands (or in omv interface)
You can verify if there are those usb devices just by disconnecting them, they should disappear from this list
For quad sata hat You should see same thing - new entries on connect, also new entry in dmesg
