hello.
I am coming to buy the DUAL/QUAD SATA HAT FOR RASPBERRY PI 4, and I want to use it to host my website. Which Ubuntu (or OS) distribution do I need to install? Are there any videos that I can follow ? Thank you.
Seems that dual/quad hat is deprecated for now, only penta sata kit is described on page.
For installation just any of those found in installation script:
echo '*** - Raspberry Pi 4B+'
echo '*** Raspbian Buster 32-bit/64-bit'
echo '*** Raspbian Bullseye 32-bit/64-bit'
echo '*** Raspbian Bookworm 32-bit/64-bit'
echo '*** DietPi RPi ARMv8 Bullseye'
echo '*** DietPi RPi ARMv8 Bookworm'
echo '*** Ubuntu Server 20.04 armhf/arm64'
On wiki You will find some video tutorials with installation:
https://wiki.radxa.com/Dual_Quad_SATA_HAT
Should be the same on newer releases, but it’s also not that big problem to modify installation scripts and add whatever is needed (on untested releases).
